+++ FINISHED!! +++ USS Greeneville (Hobby Boss 1/350)
Dear All,
While building my He 178 V1, which fought me every step of the build, I decided to build something really simple to have some breaks from the fight. I opted for a submarine.
So, here is the build thread of my first modern submarine: the Hobby Boss 1/350 USS Greeneville.
For starters, here are the mandatory pictures of the box art and box contents:
y4mnrAofVr8jhsuPX1cr_UbNnONtSQuZ-nP0v6-7
IMAG7236
Apart from the hull halves and stand, there are only two sprues:
y4myZ7VDkCowrBwaJz-7MgQDz19JyUhr4ab35LPB
IMAG7237
There's also a small PE fret:
y4mhSzv7vp4zhMyIgWNNe8RK9yjDJJl2Osn8d5vo
IMAG7238
Finally, a small decal sheet. However, according to the painting and decal instructions, decals 1, 6 and 7 are not used.
y4mFIIEA4uJZ-Qk_0Slm33-lUVdIJbzvyKb_gGgu
IMAG7399
The build started with the sail and the horizontal tailplanes:
y4mmjPRo-RFSm4fLwqDPr6uhj-y50YabDUO5Kgy2
IMAG7267
It was necessary to carve out indents for the foreplane. I overdid it, as only the curved indents were needed:
y4mKlCw_zopZpxPORelENbVeYP0t44Qceq9cdJ8a
IMAG7268
The foreplane was glued in place:
y4m7HNmYnTDQHqYYHJcQ-dfafl_WrX0pS6gvxUC3
IMAG7269
Indents were also carved out for the horizontal tailplanes:
y4mHFSxtIweo4pTd47rAqL_dh8fhAA5lZOlLpOy1
IMAG7270
The small submarine that piggybacked on the bigger sub was glued together:
y4mPDAckiFiyitCgm-oyyDTuS14N-4b_r5YrUEql
IMAG7271
A few holes had to be drilled out on the top hull half. These holes are for installing the pads on which the small submarine is installed:
y4mHxwZXnzneVvz8c9f8jIUIYAHX3mDec8ppFQTx
IMAG7272
The hull halves were glued together:
y4mssJRVxUdMRspVSIK0KPH5kUhFosXc6TRdGhPP
IMAG7273
There are a few spots demanding attention. For instance, this rectangular depression near the horizontal fin of the small sub needs a piece of plasticard:
y4mBhdmKyMsSxi4dbYxFkkjLJomUGPhsx_iaWMs3
IMAG7274
The areas around the foreplane also need attention, due to the excessive carving out:
y4mDQSStsxj2mzQLPePwHzTZ1ip_PAHafJbbjRfw
IMAG7291
y4mOWoR73pe7dfXs4KFiM-vMCZtU5UnSsAnGa-eC
IMAG7292
The sail was glued in place:
y4msYJxIDjanmjfhYlnm9Si3HUrafcmUW8nEL_JG
IMAG7302
The pads for the small sub were then installed, as well as the mooring bollards :
y4mRYDhYfGv10SKwU8lj1HSFfgN4cZPvtwmRRAoN
IMAG7303
y4mFJaUPeOj_zbyhXVcXYWL_WeIUcU1rr9WjjvX8
IMAG7305
Finally, the tailplanes were glued in place:
y4mKudNUP-v6QFnKI_nlw0TLLXN7FbfjH4WFAxrm
IMAG7310
That's all for now. Thanks for looking.
Jaime
Hello again,
This kit is simple assembly-wise and there aren't significant fit problems. The horizontal seam between the two hull-halves was almost completely eliminated with sanding and polishing sticks. I had to use bits of thin plasticard sheet to fill in a few gaps I myself created when carving out the slots for the fins. The only gap due the kit parts was in the join between one of the tail planes and the hull:
y4mKVVaR62VOYzekbi4eRSLRCI-tkMpRP7Th26vO
IMAG7359
y4mt0BkkJKTQJkKeDsshzPr7PbxZnNqYRcy6IgQZ
IMAG7362
The narrower gaps and seams were taken care of with PPP:
y4mviQlkSMS0Ldxcf4BL1yXduVLOD8auQjFe1x2b
IMAG7363
The few PE parts were, then, dealt with. There's one for the propellers of the piggy-backed sub. Here is a comparison with the plastic version:
y4m4bhM6j14eDYlmIYS4aabcNsW79ZO0AQ_DGPhAIMAG7360
IMAG7360
There are PE parts for the hatch on the sail:
y4mipGxO-kc5inUEaJEpbOoQ0ma9ZR2JxzcgIdAZ
IMAG7364
And there's a pair of PE parts for the sub propellers. I guess they should be glued together for increased strength. So, I cut one off the frame and CA-glued it to the other:
y4m9jn625ETvITVHWeDgH-CGrLTDEYuMS2gII9GH
IMAG7365
Here's the end result:
y4mlV-HzuRCMgN08wRzPCefngpqePzVvlKbtby1X
IMAG7366
The smaller parts were cleaned of moulding marks and glued to toothpicks for painting:
y4mzklSpJ3Yxl1QDZ-wNpmibqxK3Z9jdzig6oyR0
IMAG7367
The sub and the smaller parts were all primed with Alclad's Black Primer and Microfiller:
y4mzqXWiCnFIvLgeEraUAxsq9nkVq97xxhdch1ap
IMAG7374
PPP was used again to tackle small seams along the hull joins. This wasn't very successful and in the end these seams were made to vanish with thin layers of primer:
y4mdOijCy0_X5fE3J6kOB1t_g5laZFZwK_Ks1N2Z
IMAG7376
y4m6-DUr3qQ0C4BiBtUt1DvTf9oRai7eKY5HEnaL
IMAG7382
The propellers were painted brass:
y4mpiyEsycFc2m0YX5wjrVTS-HfMMWAnQ2yk3uPN
IMAG7383
The same for the holders of the stand:
y4mjh_L8RndyIS8qMTuBGfA7U3DUKHh17syXxrMT
IMAG7384
Next, I used Gunze's Rousset to paint the hull:
y4m05SdzUjTNXciVwoubmirsSNNRk9vHVx32at_9
IMAG7385
The hull was masked using a combination of masking tape and kitchen cling-film:
y4mookTjZHlJNRGF8IBd6ogorPp2am4JYP3PTHDZ
IMAG7386
The rest of the sub should be black but a real sub is never like that. I used several pictures of the real thing for inspiration for the choice of colours. This was especially interesting for showing several tones of grey on the hull, walkways and sail:
I chose RLM66 for the lighter grey tones on the sail, Gunze's ocean grey for the walkways and Tamiya's NATO Black for the hull. I initially chose Gunze's Tire Black for the darker greys of the sail but it proved too dark for my likings and was painted NATO Black as well.
Here's the application of the RLM66 grey on the sail and ocean grey on the walkways:
y4ma7_gwev3pEv9QQADXA5F5-QFeZYXURBN7rqV3
IMAG7391
Next, I masked these areas before applying the NATO Black to the hull:
y4mMgko43oOmeK88lWxMKYPho2kU0piKV5q6XTB6
IMAG7392
y4mrDf6IFZfmC_PASwTcpaQp0MUX3fDMNykEZ05z
IMAG7393
The Tire Black intended for the sail proved to be too dark but I used it to cover the oversprays of rousset and greys before proceeding:
y4mxgWGZdv7jbBmImMZDN9RItqnY99Jrtc310i3W
IMAG7394
Jaime
Hello again,
Continuing with the build, I took some time to think about how best to weather the model. I opted to keep it subtle and decided to create some tonal variation on the dark top half of the hull. For that, I applied a pre-shading layer using white, along the lines of water flow when the sub is floating on the surface:
y4mBi4ZJh0_a2KFOo0-fklSRSCej9e47SBJB9Da3
IMAG7395
This was followed by thin layers of NATO Black:
y4m8DDZvlsh1JH3CRcuCQ1czun54WhdrGE4EzjQd
IMAG7396
After removing the masking, I got this:
y4mrLf1F4EWLr5yVhRaDEeyh0xqDJ3l2pTz1e25R
IMAG7397
y4mSakzbUF4B6uCXWeJRWih5X6yRSvg2q_kBLGNy
IMAG7398
A microgloss coat was applied in preparation for the decals. Here's the setup for decaling:
y4mJ4y-UBkPGajSobWPujlWlCKxRM1Y3jy9otPSP
IMAG7400
There are few decals to apply, only the ID number on the sail and the water line scales on the bow and rudder:
y4mCKMhs0zTFBdEN7t8RBkyL9vVcwRqamhIieQEk
IMAG7401
I also decided to try and replicate a would finish for the base of the stand. First, I gloss coated the base and, next, I applied spots of dark brown oil, which were spread with a flat brush to simulate the wood grain.
Here's the mahogany-painted and microgloss-coated base:
y4mOQzMJe7LbPp7-blZO5xqwOYP5OYABmP8kmIo1
IMAG7402
After spreading the dark brown oil:
y4mC8K5OciCvYI4LCcDtunsF116mg5OqoRxTCkoy
IMAG7414
y4m7xi4H7-APDTXYDm_aHctGRrzBsSGEioAPnaoL
IMAG7415
I still wanted to weather the model a bit more, in order to reproduce the weathering below from the waterline, as seen in this picture:
800px-USS_Greeneville_(SSN_772)_-_dry_do
My first approach was to use a grey wash by Vallejo. Here's the set-up (the model had another microgloss coat to seal the decals):
y4mbsiJFH6F0FgXQgAV_q_H7EY_Jg7IsDxZ3nsKn
IMAG7416
Before applying the wash, I applied masking tape along the waterline:
y4mg_Ma2iAUmNASNIhFHxWRAZ9ruZxgV9d70s-Ch
IMAG7417
The tape was loosely held to the hull, in order to allow the wash to spread unevenly below the waterline.
y4mXHwgfXOrmyq8Z29M_Fsst8_QvrUkeeh7RKWvd
IMAG7418
The wash was applied vertically from the walkway to the waterline. The excess was removed with damp cotton buds shortly after. It worked but the wash tone was too dark and didn't stand out from the top hull's tone. In order to produce a better result, I decided to apply highly diluted Sky with a sponge over the matt wash. I didn't remask along the waterline.
Here's the tool:
y4mNntUDYt8f1Dk2ROksSRRSmOHNYtp1m3E4yH9E
IMAG7421
The resulting weathering:
y4muOzRXr_kPGsHJWIIZ45zBnpeYOdmhah37AvPy
IMAG7422
A flat coat (Alclad) was applied to the model, mini-sub and small parts.
Next, I glued the propeller of the mini-sub:
y4mrcHw8VlqsXhGHQR3RwQ8vySX14nNUEVLMzFno
IMAG7423
The same for the main model:
y4m-ixgXgOvxdSrTLGLesD72xWcwtsNLTNYO2T0X
IMAG7425
The pointy thingies where glued in place on top of the sail:
y4mVQFbihunGbJT5xfMpxNhQxr0lKFgAVi93Uwru
IMAG7425
Finally, the mini-sub was piggy-backed on the submarine:
y4mUMbrOyndhISJuecf8F87xSShpl2tsrj0rwOJJ
IMAG7426
The completed model on the stand:
y4mjFbeMamxATTGwHC42ipaQJx3KilLecNMGhcx0
IMAG7427
I'll post better pictures latter in the RFI area.
Thanks for looking.
Jaime
NOTE: the RFI photos can be found here.
Edited by jrlx
Added link to RFI photos
51 minutes ago, S-boat 55 said:
Very nice weathering, great build imo
Thank you very much. Much appreciated!
Gidday Jaime, this has come up very well, the weathering near the waterline, and also the display stand. It definitely looks like wood to me. When I saw that first photo in your last post I thought "They have a REAL problem with very big seagulls in that part of the world"😁 But like I said, she looks very good. Regards, Jeff.
Thanks Jeff! Much appreciated!
I couldn't find much information on weathering submarine models,, so I had to improvise in order to try and reproduce what I saw in the pictures of the real thing.
JR
Tha's a very realistic finish JR.
Unfortunately the links to the images are broken but Pierre's @Kagou RFI thread gives a good descripton of the materials and techniques he used to weather his submarine models and @Roger Newsome also applied a very realistic finish to his Alpha Class build.
Unfortunately the links to the images are broken but Pierre's @Kagou RFI thread gives a good descripton of the tools and techniques he used to weather his submarine models and @Roger Newsome also applied a very realistic finish to his Alpha Class build.
Thank you very much Richard, and thanks for the links. I'll take that into account for my next subs. I have the Zvezda 1/350 Kursk in the stash for a future build.
Jaime
  • jrlx changed the title to +++ FINISHED!! +++ USS Greeneville (Hobby Boss 1/350)
I added a link to the RFI photos in the last post of the build.
It can also be accessed here.
Jaime
