wombat Posted June 29, 2021 Share Posted June 29, 2021 So, rather than faff with masking a hurricane canopy, I’m trying the opposite approach - I’ve painted up clear decal sheet with the requisite colours and am trying to cut that into strips and lay it on. The first shift seemed to go ok but come the second shift48 hours later, I find the decals from the first shift still loose and shifting especially if they get wet. I’ve never had this problem after more than an hour or so with “normal” decals so what might it be? could be the clear decal sheet itself I suppose? Link to comment Share on other sites More sharing options...
lasermonkey Posted June 29, 2021 Share Posted June 29, 2021 I can’t say I ever had that problem. I did always dip the canopy in Klear first and then used Microsol to get the decals snuggled down. It’s been a while since I last used decals for canopy framing though, and I can’t remember which brand of decal I used. Probably something from Hannants. Link to comment Share on other sites More sharing options...
Giorgio N Posted July 1, 2021 Share Posted July 1, 2021 Decal glue does not always work well on bare plastic, reason why if I plan on using decals on a canopy I always dip this in Klear. At that point you'll have a painted surface on which decals will stick much better. One other way to sort your problem is to lay small quantities of gloss clear paint under the decal strip you're applying, so that the paint will act as a glue keeping the stripe in place Link to comment Share on other sites More sharing options...
wombat Posted July 1, 2021 Author Share Posted July 1, 2021 Interesting...will try that on the next one. Cheers. Link to comment Share on other sites More sharing options...
bmwh548 Posted July 1, 2021 Share Posted July 1, 2021 Get the "adhesive" solution for decals and try it like that. Not sure what the Micro equivalent is (Micro Set? ), but Ammo's is the green one (Decal Set). Link to comment Share on other sites More sharing options...
