ivan-o Posted June 26, 2021 Share Posted June 26, 2021 Hi guys, This is my next project it is the very old Leopard from Revell/Italerie, The kit was an attic find that I got off ebay, Legend conversion kit and Bronco AS90 tracks are being used. The tracks are the right type for this Leopard. If this is of any interest I will put up the WIP cheers Ivan 9 Link to comment Share on other sites More sharing options...
BillyB Posted June 26, 2021 Share Posted June 26, 2021 A wip would be great. Bill B. 1 Link to comment Share on other sites More sharing options...
Hamden Posted June 27, 2021 Share Posted June 27, 2021 Look forward to seeing what you do with this one! Stay safe Roger 1 Link to comment Share on other sites More sharing options...
ivan-o Posted June 27, 2021 Author Share Posted June 27, 2021 Thanks Roger, it’s going to be OOB with the conversion kit😀no cutting or scratch building 👍 1 Link to comment Share on other sites More sharing options...
ivan-o Posted June 27, 2021 Author Share Posted June 27, 2021 Just a bit of waffle before I start,although this kit is nearly 40 yrs old it still stands up to the Meng kit it many ways! There is a review on the Leopard Club site that goes through the pro,s and conn,s of both kits.😀 I have started with a bit of track bashing and to say this is time consuming is an understatement🙄 These are the parts for one link! One run done but I think I might cheat on the next side as the top will be under the side skirts.😉 cheers Ivan 7 Link to comment Share on other sites More sharing options...
ivan-o Posted June 27, 2021 Author Share Posted June 27, 2021 Some done today on the running gear,it’s supposed to have working suspension but the plastic seems much to hard for it to work. All the detail are parts to put on not moulded. that’s all for now obviously the other side is the same😉 cheers Ivan 7 Link to comment Share on other sites More sharing options...
Hamden Posted June 28, 2021 Share Posted June 28, 2021 Nice start, don't envy you the track bashing though! Track does look good built up Stay safe Roger 1 Link to comment Share on other sites More sharing options...
ivan-o Posted June 29, 2021 Author Share Posted June 29, 2021 Hi, just some minor work on the hull at the moment, what passed for anti slip on the front of the hull has been replaced and the tropical grill put in,this bit comes with the Meng kit but luckily enough my nephew has a 3D printer 😀👍(mmm what else do I need) before! after! and the grill that’s all for now cheers, Ivan 6 Link to comment Share on other sites More sharing options...
ivan-o Posted July 4, 2021 Author Share Posted July 4, 2021 Hi, another small update, rear hull done some very nice fiddly bits there😏 here are the contents of the Legend kit parts of which will now start to come into play😀 cheers Ivan 6 Link to comment Share on other sites More sharing options...
ivan-o Posted July 5, 2021 Author Share Posted July 5, 2021 Rights, some more done on the hull sides,tool boxes and the pads for laser sensors I believe they are. cheers , Ivan 12 Link to comment Share on other sites More sharing options...
ivan-o Posted August 2, 2021 Author Share Posted August 2, 2021 Hi guys, After all this heat I have managed a bit more etch work,rear mud flaps on😀 hopefully a bit more soon, Ivan 8 Link to comment Share on other sites More sharing options...
Terry1954 Posted August 5, 2021 Share Posted August 5, 2021 Great thread which I will follow with some interest. I have two of these in the stash, along with a Meng 1 A5 (cast turret and bolted on armor) and a C2 Mexus. As you rightly suggest they stand up to the very latest releases from Meng/Takom very well for their age. My two Italeri Leopards are destined to become one Danish 1A5DK (welded Turret) and open Australian AS1 (welded turret), using respective add on conversion sets. You have made a brilliant start. Terry 1 1 Link to comment Share on other sites More sharing options...
ivan-o Posted August 8, 2021 Author Share Posted August 8, 2021 Hi, a bit more done today on the glacis plate, a mix of the kit parts and from the conversion kit. the lip of the mud flaps has been removed,strengthening plates put on and all the bits for engineer attachments from the Legend kit used. cheers Ivan 6 Link to comment Share on other sites More sharing options...
ivan-o Posted August 15, 2021 Author Share Posted August 15, 2021 Hi, update time😀 I have had to do a bit of surgery on the back mud flaps! The ‘wings’ were supposed to fold and fit down the hull but wouldn’t fit so off they came and plastic used instead. Tracks and running gear done. Those Bronco tracks were a right pain and I have unashamedly cut them short as you won’t see them under the skirts😉 and now the shortened tracks👍 its starting to come together now BUT I won’t be doing those tracks again😀 cheers Ivan 8 Link to comment Share on other sites More sharing options...
Bullbasket Posted August 15, 2021 Share Posted August 15, 2021 Coming along OK Ivan, despite those tracks. I know what you mean though. Once bitten......... John. 1 Link to comment Share on other sites More sharing options...
ivan-o Posted August 15, 2021 Author Share Posted August 15, 2021 3 hours ago, ivan-o said: Hi, update time😀 I have had to do a bit of surgery on the back mud flaps! The ‘wings’ were supposed to fold and fit down the hull but wouldn’t fit so off they came and plastic used instead. Tracks and running gear done. Those Bronco tracks were a right pain and I have unashamedly cut them short as you won’t see them under the skirts😉 and now the shortened tracks👍 its starting to come together now BUT I won’t be doing those tracks again😀 cheers Ivan Link to comment Share on other sites More sharing options...
ivan-o Posted August 15, 2021 Author Share Posted August 15, 2021 Oops double post above🙄 Anyway side skirts on after cutting out the mud holes in them. that’s all for now, cheers Ivan 8 Link to comment Share on other sites More sharing options...
Hamden Posted August 16, 2021 Share Posted August 16, 2021 Coming together very nicely, starting to look like a Leopard now. Those tracks look good as well! Stay safe Roger 1 1 Link to comment Share on other sites More sharing options...
Terry1954 Posted August 16, 2021 Share Posted August 16, 2021 41 minutes ago, Hamden said: starting to look like a Leopard now. My thoughts exactly Roger. There is no mistaking that wavy hemline! Looking good indeed. Terry 1 1 Link to comment Share on other sites More sharing options...
ivan-o Posted August 17, 2021 Author Share Posted August 17, 2021 Right guys, Hull done😀 thanks for your likes and posts etc anything you can see I have missed please do tell😀 cheers Ivan 12 Link to comment Share on other sites More sharing options...
ivan-o Posted September 5, 2021 Author Share Posted September 5, 2021 Hi guys, After a bit of a break a bit of scratch building to start with😀 this Commanders sight is not included in the Revell kit so l have had a go! just two bits or sprue glued and sanded together I think it has worked. Just added the comparison shot🙄 cheers, Ivan 9 Link to comment Share on other sites More sharing options...
ivan-o Posted September 19, 2021 Author Share Posted September 19, 2021 Hi, another long overdue update this build seems to be talking forever😀 some work on the top of the turret using the conversion parts and a bit of scratch for the commander’s sight and the ring behind the loaders hatch. turret sides and basket next(eventually😉) cheers Ivan 9 Link to comment Share on other sites More sharing options...
ivan-o Posted September 23, 2021 Author Share Posted September 23, 2021 Hi, more lumps and bumps on,again a mix of kit and conversion parts for this side of the turret and chains on the mantle plugs😀 cheers Ivan 7 Link to comment Share on other sites More sharing options...
ivan-o Posted September 30, 2021 Author Share Posted September 30, 2021 Well this the turret all but finished,I hollowed out the searchlight front and put a lense from the spares box in,just the basket on the back and a general tidy up to go😀 cheers, Ivan 8 Link to comment Share on other sites More sharing options...
Jasper dog Posted September 30, 2021 Share Posted September 30, 2021 Doing a great job of dragging this golden oldie up to date Ivan, nice work! 1 Link to comment Share on other sites More sharing options...
