Stef N. Posted June 24, 2021 Share Posted June 24, 2021 Does anyone have any tips for this following problem. I have to mask and paint over these louvred shapes on the seat cowling. It's a tough shape to get right anyway without the extra bumps and depressions so any advice would be great. Cheers. Link to comment Share on other sites More sharing options...
Natter Posted June 24, 2021 Share Posted June 24, 2021 Tamiya do a flexible masking tape; it's almost like thin electircal tape, possibly vinyl? Perhaps a thin strip of that could be curved and made to conform to the surface contours? Either that or a circle of masking tape to form the central part of the curve and then separate strips carefully aligned to form the masking for the flowing lines down the sides? Just my two-penneth. 1 Link to comment Share on other sites More sharing options...
dnl42 Posted June 24, 2021 Share Posted June 24, 2021 I would try some putty, like Silly Putty, AK Camouflage Plastic Putty, Blu-Tack, or some such. You can shape it with a smoothed wooden toothpick. 1 1 Link to comment Share on other sites More sharing options...
Alex Gordon Posted June 25, 2021 Share Posted June 25, 2021 Narrow cut insulating tape would do the edge as long as it hasn't been stretched and then fill in with your usual covering of choice. 1 Link to comment Share on other sites More sharing options...
bmwh548 Posted June 25, 2021 Share Posted June 25, 2021 White tack, you just need a lot of patience to get it symmetrical. You don't need to get the entire contour in white tack, just the round part, the rest can be done with tape. 1 Link to comment Share on other sites More sharing options...
Stef N. Posted June 25, 2021 Author Share Posted June 25, 2021 Thanks for the tips. There's no easy cheat for this one. Patience, tape, tack and careful spraying it is. 😀👍 Link to comment Share on other sites More sharing options...
Mike Posted June 25, 2021 Share Posted June 25, 2021 I'd say draw it on from above, and then run tape along the pencil line, ensuring it follows the line from above. Then fill in the rest with masking tape. It might seem simplisitc, but it should work. I'd be cautious of using that smart tak stuff, as it has a habit of spreading under its own weight, so it would splooge over the lines if you didn't get it painted PDQ 1 Link to comment Share on other sites More sharing options...
Stef N. Posted June 25, 2021 Author Share Posted June 25, 2021 I've used the Mig camo paste on tanks as utmost accuracy hadn't been an issue but it probably would be too soft for this. I'll give white tack (or very fresh blu-tac) a go and hopefully this should work. 1 Link to comment Share on other sites More sharing options...
Stef N. Posted June 27, 2021 Author Share Posted June 27, 2021 Thanks again for all the tips. It turned out far better than I was expecting, with only a minimal touching up of any bleed. I tried the flexible tape first but the curve was too sharp for it to handle. So a long piece of fresh tack was used, gently pushing it into the curves and a toothpick to smooth any areas.Worked a treat.👍 5 Link to comment Share on other sites More sharing options...
