raafbloke Posted June 24, 2021 Share Posted June 24, 2021 Apologies, I first posted this in 'Airbrushes'. Then realised it was probably the wrong spot, so it copied here where I hope it reaches more members. Cheers, raafbloke. G'day folks, I've just finished setting up a new modelling room in a converted shed near my house. It would be a 'granny flat' if it had running water, but then, I don't have a granny! My concern is I've just discovered there is no physical way for me to install a fume cabinet/extractor. The shed was lined on the outside with brick and a builder has told me that fitting an extractor would be difficult and cost ten arms and legs! So, chaps, I need some advice on respirators. I can set up a paint booth but it won't have any kind of extraction. I haven't got a clue about respirators, apart from the ones we used to use in the RAAF, many years ago and they were terrible, plus expensive, I guess. Even though I try to use only water based paints, like Vallejo, I reckon it's best to avoid breathing in any kind of paint or dust particles. Like I do some resin work and I've heard that's problematic. So, using your collective wisdom, could I get the lowdown on what kind of respirator best suits modellers? Bearing in mind I'm in the colonies, Australia... I guess it should be a well known 'name' brand that's widely available. Also, I have a beard, does this present a problem? Any advice or examples for me to look at would be greatly appreciated. Cheers, raafbloke Bill Halliwell Tasmania Link to comment Share on other sites More sharing options...
JoostV Posted June 25, 2021 Share Posted June 25, 2021 I am in more or less the same situation and recently bought a Moldex respirator mask (MDX7002) and P100 filters (MDX7940). P100 filters are used for both oil and non-oil based particulates. The mask is available in 3 sizes and is comfortable. Also pricing is very reasonably (at least in Canada ...). The Moldex site (www.moldex.com) provides a lot of information is one of the more common manufacturers of PPE. The site also gives a list of local distributors including a bunch of them in Australia, I bought mine through Grainger who have locations all over the globe. Hope this helps ! Link to comment Share on other sites More sharing options...
Stef N. Posted June 25, 2021 Share Posted June 25, 2021 3M make some very good masks. As they are a big, international brand they should be available over there. A bit pricey but worth it. A beard does affect the fit a little bit unfortunately as the rubber can't seal fully. Also if you need a paint booth they come with a flexible extraction hose which can be stuck out a window or door. Maybe worth looking into. Hope some of that helps. Link to comment Share on other sites More sharing options...
