bar side Posted July 9, 2021 Author Share Posted July 9, 2021 Out with the superglue again tonight. Needless to say with my brass work at least 2 steps came off the ladder tonight. They are back on along with the hand rail And I started on the anti static tags on the tail. I used stretched sprue on my last F-16s but they kept getting knocked & snapped off. So I have gone for wire & superglue this time They are too long but once set I will cut them down. On the rudder too 4 Link to comment Share on other sites More sharing options...
bar side Posted July 10, 2021 Author Share Posted July 10, 2021 Test fitting most parts now. She is sitting on her wheels which are held in place with blutac. I didn’t add the airbrakes but they are about finished too. The anti static wires have had the superglue reinforced & that just needs sanding back to remove and lumps. Slats are on & dry. The canopy prop is just there to hold it open. The flaps will go on after the body sides are painted but before the dark grey goes on top. Just have the chin ariel stump to put on It was only when I put Dutch Viper next to her i realised that I never fitted her with anti static, despite leaving space for them, so I now have fitted them. And finally for today some green stuff in the gap between the wing & slats. Just to hide any gaps & make things appear a bit tighter than they are So slats & flaps down, horizontal stabilisers at an angle & airbrakes open. Tick, tick & tick. Nearly paint then 1 Link to comment Share on other sites More sharing options...
bar side Posted July 11, 2021 Author Share Posted July 11, 2021 Found an ALQ pod but not a 131. I am sure I have one somewhere but this one may get fitted until it turns up. The anti static tags are are shorted to length & sanded down and the chin antenna has gone on. The blade antenna fitting point under the intake has been filled as I can’t see any evidence of anything there on the C models. The tanks and middle pylons fit without fouling the slats, which is good. Outer pylons need fitting and tip rails still to go on. And I need to find a good pylon for the ECM pod. Otherwise I really should get on with some paint 1 Link to comment Share on other sites More sharing options...
bar side Posted July 11, 2021 Author Share Posted July 11, 2021 Decided it was primer time. I picked up a couple of tins of grey primer in Poundland the other day. It’s really not bad stuff. Not much in a tin but for the price I am happy Think that is ok to spot gaps, flat points etc. Bit more filler, it of tidying up & then can preshade 1 Link to comment Share on other sites More sharing options...
bar side Posted July 12, 2021 Author Share Posted July 12, 2021 Test fitting the primed airbrakes. Not looking to bad And the ladder in primer. I think it may well stay grey anyway Dug out the outer rails to go on the furthest underwing points. The middle pylons for the Shrikes needs a rail and I thought an out a spare set of tip rails But looking at the photos I think they are short square ended rails that don’t extend past the pylon tip. Probably going to scratch them along with the central pylon for the ECM pod 1 Link to comment Share on other sites More sharing options...
bar side Posted July 13, 2021 Author Share Posted July 13, 2021 (edited) Nothing new tonight so a quick recap on the cockpit. I did that a while back when I was building my batch of Vipers. I like resin cockpits, I do, honest. But taking a kit pit and checking references means that I have to work out what should be where and I enjoy that bit of research. So ESCI gives you he left one. I had some resin seats from a batch I picked up, so a new back plate & rails starts to look better And a bit further on And another one. The difference here is that the one on the left is the Monogram pit. I kept the kit seat there but the rest done the same. So that is what is in the Viper. Interesting to compare the Monogram and ESCI kits. To me the Monogram one looks like a cheap knock off of the ESCI kit. Really wasn’t too impressed with it, although I have seen it praised by others. But many of the parts look as though the came from the same mould. It was interesting building them side by side Edited July 14, 2021 by bar side 1 Link to comment Share on other sites More sharing options...
bar side Posted July 19, 2021 Author Share Posted July 19, 2021 Hopefully I will get some time on this build now & get it over the line. Few bits together today. Some new rails for the Shrikes and the ECM pod and the Aim-9s together. Outer rails in primer too and the instrument panel together for paining / decalling 1 Link to comment Share on other sites More sharing options...
bar side Posted July 20, 2021 Author Share Posted July 20, 2021 Quick test fit of the new & modified pylons & rails and a quick coat of white on the missiles These are the kit Aim-9Ls - they look ok to me 1 Link to comment Share on other sites More sharing options...
bar side Posted July 21, 2021 Author Share Posted July 21, 2021 On to the painting. First the preshade. Most of this gets lost, but why not The nose has already been done & tapes up. I started underneath The intake & flaps still have to be fitted, but the top of the intake know has its darker grey coat. And the top of the horizontal stabilisers & flaps have the dark grey on Mid grey to go on in front of the cockpit and the tail and side flat sections between the back edge of the wing and the exhaust. Will do these tomorrow although the temperature means paint is very quick drying. On checking the decals I am short of the stars & bars so have ordered some of those & should have all the bits by the start of next week 1 Link to comment Share on other sites More sharing options...
bar side Posted July 22, 2021 Author Share Posted July 22, 2021 The three share of grey are on (well 4 if you count the nose cone) The dark grey comes further forward on the F-16Cs than the European As but still I got it an bit too far forward Quick touch up & correction Flaps are attached and the exhaust is on. The horizontals are still just pushed in. I will fit them once the air brakes are on. That might wait until the wheels are fitted though. The whole thing has had a black and a white wash to highlight the panels. Link to comment Share on other sites More sharing options...
bar side Posted July 22, 2021 Author Share Posted July 22, 2021 I put on the top half of the airbrakes. The ventral fins are painted & ready to go but could do with the wheels on. That would allow the lower airbrake halves to go on too. So better get on with the undercarriage tomorrow 1 Link to comment Share on other sites More sharing options...
bar side Posted July 23, 2021 Author Share Posted July 23, 2021 Got a shot of the airbrakes in the daylight today. Not sure if they need a brush of aluminium over as I dusted them with gunmetal Blutac test of the load out Need to get on to the undercarriage but I think the bays look ok 2 Link to comment Share on other sites More sharing options...
bar side Posted July 24, 2021 Author Share Posted July 24, 2021 Undercarriage is now painted - wheels first using the cordless drill method And the rest fitted. Only the doors to go on now & can start to think about decals. Not looking forward to them as the Xtradecal sets have a nasty tendency to break up. Oh and need to fix on the horizontal stabilisers- just noticed they are not on! 1 Link to comment Share on other sites More sharing options...
bar side Posted July 24, 2021 Author Share Posted July 24, 2021 Up on her wheels test fitting remaining parts And with her ESCI cousin Reminds me that I need to make up the probe just behind the nose cone 2 Link to comment Share on other sites More sharing options...
stevehnz Posted July 25, 2021 Share Posted July 25, 2021 That has gone together very nicely. 👍 Steve 1 Link to comment Share on other sites More sharing options...
bar side Posted July 25, 2021 Author Share Posted July 25, 2021 (edited) Cheers @stevehnz the basic ESCI kits is a nice easy build. I just keep making it harder for myself. Now I was worried about the Spang decals. I still don’t have the stars & bars and they are coming with a set of walkway lines & refueling markings, so while I would normally start with them I started with the shark mouth! Went on well. Now this should really have a white panel behind it but the decal background is clear. So not quite right but they went on nicely, as did the tail markings. I started on the stencils too The canopy is only balanced on but the undercarriage doors are glued in place. So lots more to do but she has her identity and the decals worked well Edited July 25, 2021 by bar side 2 Link to comment Share on other sites More sharing options...
bar side Posted July 25, 2021 Author Share Posted July 25, 2021 A quick shot underneath Think she might eat the other planes on my shelf! 1 Link to comment Share on other sites More sharing options...
bar side Posted July 26, 2021 Author Share Posted July 26, 2021 Got the rest of the decals on today, but got some slivering & lifting decals, so leave it over night & see if there is anything to be done. Anyway, this is where things are at Tanks still need decals and the canopy is only balanced on. Weapon load is only held on with blutac, so not done yet Link to comment Share on other sites More sharing options...
bar side Posted July 27, 2021 Author Share Posted July 27, 2021 Well the recovery on the decals seems to have gone ok. Went for some serious decal adhesive over a series of cuts in the decal surface. Then a load of micro sol to soften it up Let it dry & then decorated with Humbrol matt varnish. Not perfect but a lot better Did a bit of running repair with the Dutch Viper whose decals were lifting a bit too. And got the tank details on So this is her just about there. Still needs to look at an intake FOD cover and RBF tags, but here she is And with the rest of the Vipers nest I will set up the HAS on a dry day soon (I hope!) and do an RFI then. Thanks for watching! 2 Link to comment Share on other sites More sharing options...
stevehnz Posted July 28, 2021 Share Posted July 28, 2021 Looks good, I like how you've handled this build, a good recovery with the decals, probably why I use this method. Steve. Link to comment Share on other sites More sharing options...
bar side Posted July 28, 2021 Author Share Posted July 28, 2021 Cheers Steve. I have some Klear but don’t often use it. It has been interesting to see how different decal sets have gone on to different F-16s. Some of the Xtradecal Viper set have been very frail & prone to breaking up badly, sometime in the sheet before going near water. Some of the ESCI chunky old decals have settled nicely, some have not. Some have needed micro set / sol, others not so much. I do agree that a good glossed coat of klear would give a far more reliable surface to work from though 1 Link to comment Share on other sites More sharing options...
Cookenbacher Posted July 28, 2021 Share Posted July 28, 2021 Wonderful F-16 collection! I love how you've posed the control surfaces on your two latest. I'm planning a Spang and Dutch viper build as well. I guess you're very influential! Link to comment Share on other sites More sharing options...
bar side Posted July 28, 2021 Author Share Posted July 28, 2021 Cheers @Cookenbacher good luck with your builds! I have a Spang F-4G to do as well. Still torn between Euro One and Hill schemes 1 Link to comment Share on other sites More sharing options...
bar side Posted July 30, 2021 Author Share Posted July 30, 2021 Got the HAS out today and have put an RFI together. Thanks for the support along the way By the way I was looking at some nieces HASes still in use yesterday 1 Link to comment Share on other sites More sharing options...
darthspud Posted July 30, 2021 Share Posted July 30, 2021 Yay!, another Viper nut. Nice work to refurb those earlier kits. The air brake is the next mod I'm doing on my next single seater The next F16 build will be a Vista Viper. Just need to battle the A7-E into submission. 1 Link to comment Share on other sites More sharing options...
