ReccePhreak Posted June 26, 2021 Share Posted June 26, 2021 On 6/21/2021 at 7:01 PM, Julien said: The air starter unit is only fitted to the left side, the kit has on on both sides. For an RAF Aircraft the vast amount of photos we have in the walkaround section is without a doubt the best set we have for a single type. I'm going to show my ignorance, do you have any pics showing the Air Starter Unit? Larry Link to comment Share on other sites More sharing options...
Phone Phixer Posted June 26, 2021 Share Posted June 26, 2021 A couple of pictures from the large library in the BM walkaround section. https://www.britmodeller.com/forums/index.php?/topic/70916-sepecat-jaguar-gr1-gr3/ Port airbrake bay with micro turbo air starter. Starboard airbrake bay, with refueling coupling. Not a second micro turbo as Kitty Hawk have. I highly recommend looking through the pictures. There is every bit of information you need for a Jaguar. 1 Link to comment Share on other sites More sharing options...
ReccePhreak Posted June 26, 2021 Share Posted June 26, 2021 (edited) Thanks for the pics, and especially the descriptions @Phone Phixer I had taken a look through the walkarounds, but they weren't labelled as being the Air Starter Unit. That's why I asked. Larry Edited June 26, 2021 by ReccePhreak More info 1 Link to comment Share on other sites More sharing options...
Julien Posted June 26, 2021 Share Posted June 26, 2021 No worries Larry, its called a Micro turbo, unlike other aircraft its not an APU all it does is provide for starting the engines. Not sure if this link will work here; https://www.facebook.com/100002623534559/videos/1173265969437510/ Link to comment Share on other sites More sharing options...
ReccePhreak Posted June 26, 2021 Share Posted June 26, 2021 49 minutes ago, Julien said: No worries Larry, its called a Micro turbo, unlike other aircraft its not an APU all it does is provide for starting the engines. Not sure if this link will work here; https://www.facebook.com/100002623534559/videos/1173265969437510/ Thanks for the link, and the description Julien. But, as I previously mentioned, I absolutely refuse to ever have anything to do with Fakebook. I assume that is a picture of you on the opening page? Glad to finally see what you look like, after all these years. Link to comment Share on other sites More sharing options...
Julien Posted June 26, 2021 Share Posted June 26, 2021 3 hours ago, ReccePhreak said: Thanks for the link, and the description Julien. But, as I previously mentioned, I absolutely refuse to ever have anything to do with Fakebook. I assume that is a picture of you on the opening page? Glad to finally see what you look like, after all these years. That could be me Larry, dont know what you saw, video on the link is just the startup of the micro turbo Try this; 1 1 Link to comment Share on other sites More sharing options...
ReccePhreak Posted June 26, 2021 Share Posted June 26, 2021 Cool video @Julien ! I would imagine you wouldn't want to be too close to it when it starts up? 1 Link to comment Share on other sites More sharing options...
Julien Posted June 26, 2021 Share Posted June 26, 2021 29 minutes ago, ReccePhreak said: Cool video @Julien ! I would imagine you wouldn't want to be too close to it when it starts up? It does get a bit warm. This was one of the first times it had run for a while so the start was a bit wet. Normally its better. Link to comment Share on other sites More sharing options...
dov Posted June 27, 2021 Author Share Posted June 27, 2021 Hallo I wonder. What is actually this micro turbo for? If it is noot an APU, is it a valve for engine bleed? Can you explain me that? Thank you. Happy modelling Link to comment Share on other sites More sharing options...
Julien Posted June 27, 2021 Share Posted June 27, 2021 10 hours ago, dov said: Hallo I wonder. What is actually this micro turbo for? If it is noot an APU, is it a valve for engine bleed? Can you explain me that? Thank you. Happy modelling It provides air to start the main engines, hence the term Air Starter. It odes not provide electrical power or hydraulic power. Kind of like an on board palouste 2 Link to comment Share on other sites More sharing options...
