Star Destroyer Maintenance trench size?
A question for the number crunchers out there....
I plan to build a section of the maintenance trench that runs down the side of Star Destroyers. A sort of vertical diorama.
It will be mounted on a redundant 22" x 34" magnetic notice board so it may take a while.
It won't be an exact copy, but very much in the spirit of, with lots of greeblies using whatever the spares boxes yield up.
But I do want to get the size about right in 1/350th scale.
So, The question is, How deep/tall should it be?
Does anyone out there have a Star Destroyer in whatever scale that they can measure and then convert the numbers to suit?
Thanks, Pete
Lots of lookers at this but no numbers yet. I may have to do a rethink and just do a section of 'A Spaceship' along the lines of a Star Destroyer.
Looking at the trench depth on the Bandai Star destroyer they vary from 7mm to 2mm deep so at 1:5000 scale makes them between 35m and 10m deep.
In 1:350 scale that would be 100mm to 28mm deep.
HTH
Warren
Just what I needed, you are a star, Sir!
I'm guessing at around 100 to 150 mm high then, based on that.
I think 125mm should keep the proportions about right.
