Longbow Posted June 23, 2021 Author Share Posted June 23, 2021 These showed up today for a possible Mk V build. 2 Link to comment Share on other sites More sharing options...
bigbadbadge Posted June 23, 2021 Share Posted June 23, 2021 Great progress and looking good, just an extra bit to add to Alan's great idea for the prop, if you take off the locating pin just above the surface of the blade itself you will have be left with a slightly raised area to know whish way to orientate the blades and should slide through the holes in the spinner. I hope that makes sense. Chris 2 1 Link to comment Share on other sites More sharing options...
Corsairfoxfouruncle Posted June 23, 2021 Share Posted June 23, 2021 1 hour ago, Longbow said: LOL... I’m not paying $160+ for a kit Seriously... The chances of me messing up, far outweigh the chances of a successful finish. If I’m going to devolve into a slow train wreck, I’d rather it be on a $40 investment. The Bf 109 in the group build, and this Spit, are just for testing out new things, as I’ve always been primarily an Armor builder. I agree on the cost issue, and add that builds like this helps build up scratch building and other skills. 1 Link to comment Share on other sites More sharing options...
Corsairfoxfouruncle Posted June 23, 2021 Share Posted June 23, 2021 1 hour ago, Longbow said: I gave the canopy a dip in this Pledge, as I couldn’t ding Future... Anyone try this ? Does it work the same ? Thats the stuff I use. 1 Link to comment Share on other sites More sharing options...
Longbow Posted June 23, 2021 Author Share Posted June 23, 2021 6 minutes ago, Corsairfoxfouruncle said: Thats the stuff I use. Excellent !! Good to know !! Thank you Link to comment Share on other sites More sharing options...
Longbow Posted June 23, 2021 Author Share Posted June 23, 2021 Working on the tail wheel doors and assembly. I traced the outline of the curved doors in one piece, and cut a master in 10 thou card. Checking for fit and alignment, I adjusted as necessary onto a new piece of 10 thou. Once happy, this single piece was heat formed around a chop stick, overcompensating for the bend to take into account any spring left in the card. This formed piece was the cut down the center, to separate the two doors. Details will be added with strip. 2 Link to comment Share on other sites More sharing options...
Longbow Posted June 23, 2021 Author Share Posted June 23, 2021 And.... Done. Let’s see how quick I can break them off. I cemented a piece of tube into the well, to take the wheel, once that’s ready. 3 Link to comment Share on other sites More sharing options...
Jasper dog Posted June 23, 2021 Share Posted June 23, 2021 1 hour ago, Longbow said: These showed up today for a possible Mk V build. Hobbyboss do a Vb, correcting it can't be any more work than converting those, surely?? This almost looks like real modelling Lee! 1 Link to comment Share on other sites More sharing options...
Longbow Posted June 23, 2021 Author Share Posted June 23, 2021 11 minutes ago, Jasper dog said: Hobbyboss do a Vb, correcting it can't be any more work than converting those, surely?? This almost looks like real modelling Lee! The Hobby Boss one is really bad, apparently. Way too wide in the body. Link to comment Share on other sites More sharing options...
Jasper dog Posted June 24, 2021 Share Posted June 24, 2021 6 hours ago, Longbow said: The Hobby Boss one is really bad, apparently. Way too wide in the body. Well that's a pain! I knew about the tailplanes, not the extra girth! Still, gives you something to do.....😉 1 Link to comment Share on other sites More sharing options...
Biggles87 Posted June 24, 2021 Share Posted June 24, 2021 There are lots of detail and correction sets ( not least Barracuda ) available for this kit but good for you for doing it yourself. The Revell 1/32 Spitfires are nice kits, the only things I really have a problems with are the cockpit ‘ floor ‘ which is too flat, and the riveted leading edges. You’ve sorted the leading edges and the shape of the ‘ floor ‘ is probably not too noticeable with everything in place. Good job. john 1 Link to comment Share on other sites More sharing options...
Longbow Posted June 24, 2021 Author Share Posted June 24, 2021 2 hours ago, Biggles87 said: There are lots of detail and correction sets ( not least Barracuda ) available for this kit but good for you for doing it yourself. The Revell 1/32 Spitfires are nice kits, the only things I really have a problems with are the cockpit ‘ floor ‘ which is too flat, and the riveted leading edges. You’ve sorted the leading edges and the shape of the ‘ floor ‘ is probably not too noticeable with everything in place. Good job. john Thanks John !! I know thee's probably much easier ways of going around things.... But who needs an easy life, lately 3 hours ago, Jasper dog said: Well that's a pain! I knew about the tailplanes, not the extra girth! Still, gives you something to do.....😉 That's just the little I read, delving into a few reviews, while looking for a 1/32 Mk V. Then I thought.... "What about a challenge ?" 2 Link to comment Share on other sites More sharing options...
Andy J Posted June 24, 2021 Share Posted June 24, 2021 Aha found ya.......🙂👍 2 Link to comment Share on other sites More sharing options...
Andy J Posted June 24, 2021 Share Posted June 24, 2021 On 18/06/2021 at 08:54, Jasper dog said: I'm holding you personally responsible for this, and any flak I'll get for it, but I've just signed up to do a 109..... Just hope no one from the "usual" section spots me flirting with things with a big fan up front! Aha another one tracked down 🙂👍 3 Link to comment Share on other sites More sharing options...
Longbow Posted June 24, 2021 Author Share Posted June 24, 2021 Tail wheel and assembly is complete. Getting closer to paint. 3 Link to comment Share on other sites More sharing options...
bigbadbadge Posted June 24, 2021 Share Posted June 24, 2021 Looking good and nearly ready for paint. The Hobbyboss one is not too wide as the revell cockpit frames fit so it's the same width as the revell kit. The problem is that they have squashed it with a too rounded spine and the cockpit components are a bit wierd. I corrected one using plasticard rod for the spine and used some of the Revell cockpit parts along with aftermarket seat and details. Chtis 1 1 Link to comment Share on other sites More sharing options...
Jasper dog Posted June 24, 2021 Share Posted June 24, 2021 7 hours ago, Andy J said: Aha found ya.......🙂👍 7 hours ago, Andy J said: Aha another one tracked down 🙂👍 Its almost the bomb blast effect, scattered to the four corners. Just thank God we didn't end up in the sci-fi section or worse still.... the "brum-brum" brigade! 3 Link to comment Share on other sites More sharing options...
Jasper dog Posted June 24, 2021 Share Posted June 24, 2021 Must say Lee, that tail wheel looks the doggies! 👍 1 Link to comment Share on other sites More sharing options...
Andy J Posted June 24, 2021 Share Posted June 24, 2021 18 minutes ago, Jasper dog said: Its almost the bomb blast effect, scattered to the four corners. Just thank God we didn't end up in the sci-fi section or worse still.... the "brum-brum" brigade! Finally tracked down the Wright brothers...wonder's will never cease 🙄 14 minutes ago, Jasper dog said: Must say Lee, that tail wheel looks the doggies! 👍 Jeez it's just a wheel for gods sake 🙄 3 Link to comment Share on other sites More sharing options...
Longbow Posted June 24, 2021 Author Share Posted June 24, 2021 Canopy is masked for painting. Unfortunately I’m now in Meansville. Yup, the town is called Meansville.... Have to ask a newb question. Has anyone dipped a canopy After painting ? I may have scuffed it, masking. Link to comment Share on other sites More sharing options...
Corsairfoxfouruncle Posted June 25, 2021 Share Posted June 25, 2021 (edited) 4 hours ago, Longbow said: Canopy is masked for painting. Unfortunately I’m now in Meansville. Yup, the town is called Meansville.... Have to ask a newb question. Has anyone dipped a canopy After painting ? I may have scuffed it, masking. Yes Ive dipped both before and after because of forgetfulness. It makes no difference other than giving you glossy paint. Edited June 25, 2021 by Corsairfoxfouruncle 1 Link to comment Share on other sites More sharing options...
Longbow Posted June 25, 2021 Author Share Posted June 25, 2021 Going to need a little filler and a slight sand, around the canopy. But nothing major. Have to say that I’m actually quite impressed with the fit of the Revell kit. 6 Link to comment Share on other sites More sharing options...
Longbow Posted June 25, 2021 Author Share Posted June 25, 2021 The prop has paint. Ready for assembly and then weathering. Link to comment Share on other sites More sharing options...
Longbow Posted June 25, 2021 Author Share Posted June 25, 2021 I almost forgot to add the slipper tank hooks, which should actually belong to a Pz. III. They looked about right. 4 Link to comment Share on other sites More sharing options...
Longbow Posted June 25, 2021 Author Share Posted June 25, 2021 Spinner is together. A little weathering should bring out the details. 4 Link to comment Share on other sites More sharing options...
