Longbow Posted June 13, 2021 Share Posted June 13, 2021 Hi guys.... After completing the 109 F4 in the Group Build, I wanted to work on something while waiting on the Hellcat GB. I’d like to preface this by saying that my AC knowledge is extremely limited, as I’ve focused on armor since getting back into the hobby a few years ago. Anyway, the Revell kit is pretty well known, so I’ll forego the usual box and sprue shots. First thing to tackle is the incorrect wing bulge issue. After doing the first one, and losing some surrounding detail, I had to re-scribe and re-rivet a little. This is the first time I’ve done scribing, and used a sharp dental pick for the task. Then some Tamiya Extra thin. At that point, I suddenly thought... “Idiot... Should have masked off the surround !!” Once again, a little detail had to be replaced, but nothing drastic. The masking turned out to be a benefit. So, with the wings at an acceptable level, and multiple touch ups... We ended up with this. Not great by any standards, but at least the ghost of the bulge, is just a ghost, and should be less visible with primer and paint. Next up we’re the upper leading edge. I understand, from what I’ve read, that the rivets were filled, so the upper leading edges were sanded, primed, sanded again, and primed again, with Mr. Surfacer 1000. And then sanded again. The wing mounted fuel tanks will be scribed, and sanded, and primed, once the wing upper and lower are joined. Thanks for looking in, and any suggestions are always welcome !! Lee. 10 Link to comment Share on other sites More sharing options...
Longbow Posted June 13, 2021 Author Share Posted June 13, 2021 (edited) Next up is the cockpit wall step, which seems to be a problem, and places the rear section of the canopy behind the cockpit seat mounting bulkhead. So, this was corrected, by adding a mil or so to the fuselage, and losing the step at the cockpit door. I have no idea if this is correct, so any comments are welcome. If it alters the rear canopy section compared to known measurements, please let me know, but it should be covered by the open canopy. Thanks for stopping by... More to follow. Once a bit more is done. Lee. Edited June 13, 2021 by Longbow 9 Link to comment Share on other sites More sharing options...
bigbadbadge Posted June 13, 2021 Share Posted June 13, 2021 Nice, will tag along, not an expert either myself but there are some very knowledgeable person here. It looks a nice kit, got a couple if Revell MkIXs in the stash one to be as is and the other to convert to a MkXIV using AA Productions kit. Good luck with your build Great start so far. Chris 1 Link to comment Share on other sites More sharing options...
Longbow Posted June 13, 2021 Author Share Posted June 13, 2021 9 minutes ago, bigbadbadge said: Nice, will tag along, not an expert either myself but there are some very knowledgeable person here. It looks a nice kit, got a couple if Revell MkIXs in the stash one to be as is and the other to convert to a MkXIV using AA Productions kit. Good luck with your build Great start so far. Chris Thanks, Chris. It’s not going to be perfect by a long shot, but we’ll see where it goes... 1 Link to comment Share on other sites More sharing options...
Longbow Posted June 13, 2021 Author Share Posted June 13, 2021 With the wings together, and wingtips on. Waiting for everything to set up for sanding, filling, and more sanding LOL... Started working on the horrendous Revell cockpit. The only thing Not lacking, are the sink holes.... Once the wings are set, I can cut the flaps to the correct VIII size. Then I have to think about the tail wheel opening, and scratch the doors. 6 Link to comment Share on other sites More sharing options...
Corsairfoxfouruncle Posted June 13, 2021 Share Posted June 13, 2021 You have my attention sir. 1 Link to comment Share on other sites More sharing options...
Longbow Posted June 13, 2021 Author Share Posted June 13, 2021 7 minutes ago, Corsairfoxfouruncle said: You have my attention sir. Don’t expect miracles !! 1 Link to comment Share on other sites More sharing options...
Corsairfoxfouruncle Posted June 13, 2021 Share Posted June 13, 2021 1 minute ago, Longbow said: Don’t expect miracles !! Don't knock yourself your Bf.109 was pretty good. 1 Link to comment Share on other sites More sharing options...
Longbow Posted June 13, 2021 Author Share Posted June 13, 2021 The IP and bulkheads are drilled out, and tidied up a little. I have to fabricate the seats armored plate, yet. I should probably remove the headrest too. I don’t “think” the VIII had them (?) 5 Link to comment Share on other sites More sharing options...
spitfire Posted June 13, 2021 Share Posted June 13, 2021 I like they way you build, it's nice to be 100% accurate but it's a hobby and you should enjoy the build not fret over the little things, just do your best. I am not an expert but I have a lot of notes from the late Edgar who was, so looking at his notes I found that the head rest was discontinued on all marks from 20/07/1942, he did go on to say that this did not include Seafires. Cheers Dennis 2 1 Link to comment Share on other sites More sharing options...
Longbow Posted June 13, 2021 Author Share Posted June 13, 2021 19 minutes ago, spitfire said: I like they way you build, it's nice to be 100% accurate but it's a hobby and you should enjoy the build not fret over the little things, just do your best. I am not an expert but I have a lot of notes from the late Edgar who was, so looking at his notes I found that the head rest was discontinued on all marks from 20/07/1942, he did go on to say that this did not include Seafires. Cheers Dennis I shall remove the offending object Thank you !! Link to comment Share on other sites More sharing options...
Longbow Posted June 13, 2021 Author Share Posted June 13, 2021 The wing leading edge is finished with filling and sanding. The joint has also been sanded smooth 2 Link to comment Share on other sites More sharing options...
Longbow Posted June 13, 2021 Author Share Posted June 13, 2021 Dang !! 5 attempts at the seat armor. This last one is good enough for me 7 Link to comment Share on other sites More sharing options...
Alan P Posted June 13, 2021 Share Posted June 13, 2021 Hey, very nice work Lee, you have a knack of picking just the right details to add or correct to make an accurate conversion without making a meal of it. I'll be watching from now on 2 Link to comment Share on other sites More sharing options...
Longbow Posted June 13, 2021 Author Share Posted June 13, 2021 Just now, Alan P said: Hey, very nice work Lee, you have a knack of picking just the right details to add or correct to make an accurate conversion without making a meal of it. I'll be watching from now on Thanks, Alan !! Im quite enjoying researching little changes. Link to comment Share on other sites More sharing options...
Longbow Posted June 13, 2021 Author Share Posted June 13, 2021 Getting ready to mark out the cut for the rear wheel opening. 3 Link to comment Share on other sites More sharing options...
Longbow Posted June 13, 2021 Author Share Posted June 13, 2021 Okay, I couldn’t resist it. Pretty sure I’ll need a spreader in the fuselage, or a 5 thou filler strip. Not sure yet. 4 Link to comment Share on other sites More sharing options...
Longbow Posted June 13, 2021 Author Share Posted June 13, 2021 Tail wheel cut is done. Have to fill a few panel lines, and RE-scribe for the VIII. 8 Link to comment Share on other sites More sharing options...
Hamden Posted June 14, 2021 Share Posted June 14, 2021 Room for one more? Very nice start on this one I'll follow along if I may. Stay safe Roger 1 Link to comment Share on other sites More sharing options...
SafetyDad Posted June 14, 2021 Share Posted June 14, 2021 Lovely neat work here. And, as others have said, you've got a refreshingly honest and realistic approach to corrections and improvements. SD 1 Link to comment Share on other sites More sharing options...
Fritag Posted June 14, 2021 Share Posted June 14, 2021 And room for me too? Impressive (and rapid) start and I agree with t’others about your judgment on the corrections to make (and skill in making them). 1 Link to comment Share on other sites More sharing options...
Longbow Posted June 14, 2021 Author Share Posted June 14, 2021 4 hours ago, Hamden said: Room for one more? Very nice start on this one I'll follow along if I may. Stay safe Roger 4 hours ago, SafetyDad said: Lovely neat work here. And, as others have said, you've got a refreshingly honest and realistic approach to corrections and improvements. SD 3 hours ago, Fritag said: And room for me too? Impressive (and rapid) start and I agree with t’others about your judgment on the corrections to make (and skill in making them). Thank you, Gentlemen... The more the merrier I was able to get a few things completed last night, but I’m at work now. I was able to clean up the tale wheel cut, and fill and sand, re-scribe, around the tale area. The ting fuel tanks were also scribed, and will have to be filled and sanded later. They are a little hard to see in the pix. 5 Link to comment Share on other sites More sharing options...
Longbow Posted June 14, 2021 Author Share Posted June 14, 2021 If anyone has a good suggestion for an easily available filler, for large flat surfaces, and easily sandable, id appreciate the suggestions. Thanks !! Lee. Link to comment Share on other sites More sharing options...
spitfire Posted June 14, 2021 Share Posted June 14, 2021 Not sure what you are after but to cure loads of micro bubbles in a resin kits wings I airbrushed Mr Surfacer, thinned with Mr Color thinner over the wings and sanded it down, worked a treat. The relevant section of the build is below. Cheers Dennis 1 Link to comment Share on other sites More sharing options...
Longbow Posted June 14, 2021 Author Share Posted June 14, 2021 4 minutes ago, spitfire said: Not sure what you are after but to cure loads of micro bubbles in a resin kits wings I airbrushed Mr Surfacer, thinned with Mr Color thinner over the wings and sanded it down, worked a treat. Cheers Dennis Thank you, Dennis !! Link to comment Share on other sites More sharing options...
