Julien Posted June 6, 2021 Share Posted June 6, 2021 Mirage F.1 AZ/CZ South African Air Force (72435) 1:72 Special Hobby The Dassault Mirage F.1 has been a successful point defence fighter for over thirty years, and was developed initially as a private venture by Dassault as a replacement to their ageing Mirage III fighters. It is a single-engined, single-seat fighter aircraft with a high-mounted delta wing and capability of reaching mach 2.2 in short order. Power was provided by a single SNECMA Atar turbojet providing about 7 tonnes-force (69 kN; 15,000 lbf) of thrust. Dassault soon found an eager customer in the shape of the French Armée de l'air, who bought various versions over the years starting on 1974. The French retired the Mirage F.1 in 2014. The SAAF flew both the Mirage F1AZ ground-attack version as well as the radar-equipped Mirage F1CZ fighter. The F1AZ has a laser-based rangefinder and features an integrated ground-attack system. Both types we retired in the 1990s. Gabon had purchased 6 ex SAAF aircraft. The Kit This is a reworking of the superb new tool kit from Special Hobby. This boxing has extra parts for the AZ version. There is also some small resin parts for the "lumps & bump" and the engine shock cones. The parts are crisp with engraved panel lines deep enough not to disappear under a coat of paint, but not trench like. From the parts break down on the sprues it is evident more versions are on there way. Construction starts conventionally enough in the cockpit area. The instrument panel and coaming is built up and attached to the front of the cockpit, the rear bulkhead is attached, and the control stick added in. For some strange reason step 3 in the instructions has you placing the cockpit inside the fuselage and closing it up; and step 4 has you adding the front wheel well and exhaust into the fuselage. I would safely say that it's best to reverse these. On the subject of the exhaust, it is a three part affair and the quality of the kit parts is very good. Once the exhaust, front wheel bay, and cockpit are in the main fuselage can indeed be closed up. Once the main fuselage is together the correct nose can be added for your chose decal option. Various nose antenna are added along with the front airbrakes which are moulded in the closed position. The engine intakes are also added at this stage. New parts are provided for the shock cones in resin and some surgery is needed which will be tricky. Next the main wings are added which are of conventional upper/lower construction. Once these are on the rudder, tail planes, and ventral strakes are all added as well. Once the main aircraft is built it is time to switch to the landing gear. All three units are built up and added along with their respective doors. The undercarriage is quite detailed but has been moulded to be in as few parts as possible. The main legs along with their retraction struts are one part, with only a single small section needed for each of the mains. The wheels are one part each and have nice relief for painting. It is then a quick re-visit to the cockpit to build the ejection seat. For the scale this is quite detailed with 4 parts making up the seat. There is a choice of seat back/cushion however no indication of which to use for which option. It is suspected these options are time frame based, and the modeller should check their references. The penultimate step is to add the pylons. A single centre line pylon is added along with wing pylons, &chaff dispensers. Thankfully this time the instructions show which should be added for each decal option. The instructions show only fuel tanks to be attached, although the sprues do contain a nice selection of weapons to be deployed as the modeller sees fit,. Lastly the canopy and front screen are attached. Markings There are four decal options on a sheet from Cartograf so there will be no issues there. 1. F.1AZ 229 No.1 Sqn SAAF, Hoedspruit 1976-1997 (Buff & Green over grey) 2. F.1AZ 229 No.1 Sqn SAAF, Hoedspruit 1990s (Dark Earth & Green over grey) 3. F.1CZ 213 No.3 Sqn SAAF, Ondangwa. On 6th Nov 1981 Maj J Rankin shot down an Angolan MiG-21 in this aircraft. (Buff & Green over Grey) 4. F.1CZ 203 "Le Spectre" No.3 Sqn SAAF, Ondangwa. On 5th October 1982 Maj J Rankin shot down his second Angolan MiG-21 in this aircraft (Grey / blue grey over grey) 5. Slightly different later markings to the aircraft at 4, complete with Angolan Roundel below the cockpit. Conclusion It is great to see more versions of this new tool from Special Hobby becoming available. Highly recommended. Review sample courtesy of 8 1 Link to comment Share on other sites More sharing options...
