Marklo Posted June 5, 2021 Share Posted June 5, 2021 (edited) So my first contribution to the GB will be the Scout F a development for the Scout but I’ve chosen it firstly because I like it’s looks and secondly because it looks much more like an interwar fighter than a WWI plane. First job is to scale these to 1/48. Edited June 25, 2021 by Marklo 11 Link to comment Share on other sites More sharing options...
JOCKNEY Posted June 5, 2021 Share Posted June 5, 2021 Not an aircraft I'm familiar with, but that's great. Best of luck with this one Cheers Pat 1 Link to comment Share on other sites More sharing options...
rob85 Posted June 6, 2021 Share Posted June 6, 2021 Not an aircraft I’ve seen before, and your going for a scratch build in a GB, my hat is off to you! Rob 1 1 Link to comment Share on other sites More sharing options...
Colin W Posted June 8, 2021 Share Posted June 8, 2021 Good choice Marklo. There are plenty of unkitted Bristols for you to work your magic on. Link to comment Share on other sites More sharing options...
Marklo Posted June 8, 2021 Author Share Posted June 8, 2021 (edited) On 6/6/2021 at 7:04 PM, rob85 said: your going for a scratch build in a GB Thank you, I love scratch builds and I find early types are ( mostly) not a lot more demanding than a difficult kit. I did 4 for the interceptor GB and I’m in the final throes of finished my off two for the anything but injection GB. Edited June 8, 2021 by Marklo 2 Link to comment Share on other sites More sharing options...
PeterB Posted June 9, 2021 Share Posted June 9, 2021 I built the Aeroclub Scout D years ago but I have not come cross this one. Pete Link to comment Share on other sites More sharing options...
Marklo Posted June 10, 2021 Author Share Posted June 10, 2021 Started on the scaling wingspan will be 188mm (7.4 inches) so a nice size now I’ve been going through the WWI fighter book and I’m torn between the Arab engined F and the Mercury engined F1 and I’m toying with the idea of building both, hmm. Link to comment Share on other sites More sharing options...
Rabbit Leader Posted June 11, 2021 Share Posted June 11, 2021 This is going to be something to watch! I thought I was quite knowledgeable about Bristols aeroplanes, however this one is definitely new to me. Cheers and all the best.. Dave Link to comment Share on other sites More sharing options...
Marklo Posted June 11, 2021 Author Share Posted June 11, 2021 This is the F1, almost identical excep for the close cowled Mercury engine. 1 Link to comment Share on other sites More sharing options...
Marklo Posted June 17, 2021 Author Share Posted June 17, 2021 First bloods been drawn, er I mean first plastics been cut, two (soon to be) identical vertical tail plane blanks. And using my trusty jigsaw ( alas I don’t own a bandsaw) a fuselage buck cut from plans. As the fuselage has compound shapes I’ll use this as both a cutting guide and an assembly jig for both planes as aft of the firewall they were identical. 2 Link to comment Share on other sites More sharing options...
Marklo Posted June 19, 2021 Author Share Posted June 19, 2021 Two fuselages started. 3 Link to comment Share on other sites More sharing options...
Marklo Posted June 22, 2021 Author Share Posted June 22, 2021 (edited) Wing and horizontal blanks cut. I just need to cut out the middle bits and trim the upper wing chord length by about 2mm. As there is no diehedral on either wing I’m doing them both as a single piece. I’ll probably cut a notch out of the fuselage for the lower wing and set it into the fuselage. Lots of sanding and shaping to do before skinning the blanks. I’ve never scratched two near identical builds together before ( the closest I’ve come was the two kittens for the recent interceptor GB) and it’s proving ( so far) to be only a little bit more work than a single build. Edited June 22, 2021 by Marklo 4 Link to comment Share on other sites More sharing options...
Rabbit Leader Posted June 22, 2021 Share Posted June 22, 2021 Excellent progress, they do look quite neat and identical for scratch builds… you done this before? Cheers.. Dave 1 Link to comment Share on other sites More sharing options...
Marklo Posted June 22, 2021 Author Share Posted June 22, 2021 59 minutes ago, Rabbit Leader said: you done this before? Cheers.. Dave While I’ve done quite a few scratch builds in the last few years I haven’t done two the same. This would be the closest I’ve come where I built a PV7 and a PV8 side by side. This is probably my oddest to date a Supermarine PB31 Nighthawk. But I am currently finishing this off over in the anything but injection GB, an Oertz W6 flying boat, and I think that will take the lead as the oddest thing I’ve built once it’s done 2 Link to comment Share on other sites More sharing options...
Rabbit Leader Posted June 22, 2021 Share Posted June 22, 2021 All amazing work and what I’d call modelling in its truest form. Makes my OOB builds look quite easy and silly in comparison. Cheers.. Dave 1 Link to comment Share on other sites More sharing options...
Marklo Posted June 23, 2021 Author Share Posted June 23, 2021 17 hours ago, Rabbit Leader said: Makes my OOB builds look quite easy and silly in comparison. It’s not about the level of modelling it’s wether you’re enjoying it. Eg the likes of airscale makes my modelling look feeble, but I’m enjoying it 3 Link to comment Share on other sites More sharing options...
Marklo Posted June 23, 2021 Author Share Posted June 23, 2021 (edited) cut the fuselage floors and fitted the lower wing blanks. You may notice they’re marked as each is fitted to a fuselage, as they’re close but probably not identical. Next off I’ll sand these to airfoil section and skin them. Ditto for the upper wings. Edited June 23, 2021 by Marklo 2 Link to comment Share on other sites More sharing options...
Marklo Posted June 26, 2021 Author Share Posted June 26, 2021 Wings sanded to airfoil and bent 10thou skins ruled and cut. Ready for assembly. 1 Link to comment Share on other sites More sharing options...
Marklo Posted June 27, 2021 Author Share Posted June 27, 2021 Wings skinned, shaped and lower wings fitted. Going well so far. Tails and turtledecks next. 2 Link to comment Share on other sites More sharing options...
Marklo Posted June 28, 2021 Author Share Posted June 28, 2021 (edited) Turtle decks on Tailplanes attached. Next the interiors and upper decking. From there they start to diverge between the two types. Edited June 28, 2021 by Marklo 6 Link to comment Share on other sites More sharing options...
Rabbit Leader Posted June 29, 2021 Share Posted June 29, 2021 How good are these things looking?? Excellent work mate, top shelf modelling. Cheers.. Dave 1 Link to comment Share on other sites More sharing options...
AdrianMF Posted July 2, 2021 Share Posted July 2, 2021 Nice going. What do you use to stick the skins on the wings? Regards, Adrian 1 Link to comment Share on other sites More sharing options...
Marklo Posted July 2, 2021 Author Share Posted July 2, 2021 (edited) Double sided sticky tape ( from Dealz) and ca or Tamiya thin ( you get a sharper trailing edge with Tamiya or contacta but i find it doesn’t always stick properly) for the trailing edges and tips. It’s my variation of the Harry Woods method. Edited July 6, 2021 by Marklo 2 Link to comment Share on other sites More sharing options...
Marklo Posted July 12, 2021 Author Share Posted July 12, 2021 (edited) As I had the airbrush out and quite a bit of sky blue left in the cup after spraying my Flanker, I decided to give the scouts a coat of paint to see what filler etc they needed. The join to the turtle deck and the wing tips need a bit of work but not too bad all over. Edited July 12, 2021 by Marklo 1 Link to comment Share on other sites More sharing options...
Marklo Posted September 20, 2021 Author Share Posted September 20, 2021 (edited) As they currently are. Upper decking shaped and cut. Noses next. Ready to mold some noses. I’m still hoping to get both of these done by the end of the GB. For some reason I always drag my heels on interiors, but once I get them done the rest of the build should be very straight forward. Edited September 20, 2021 by Marklo 1 Link to comment Share on other sites More sharing options...
