Coppercat Posted July 19, 2021 Author Posted July 19, 2021 I pasted the previously made side window frames. Frames made from scratch. The idea was that the window on the driver's side was tilted and closed on the passenger's side. In the F250GTO, the windows were sliding, not down. I have made appropriate handles to "maneuver" the shafts. General photos, because the close-ups show traces of "fight" when fitting the frames to the body (oh, it happened ......) The details will show how I can clean the glass at least a little. 9
Coppercat Posted July 24, 2021 Author Posted July 24, 2021 The stand: Photos of the current state of the model. Workshop photos, so dust, fingerprints, etc. There is still a lot of work left, but something is already visible. to be continued 12
Marco F. Posted July 25, 2021 Posted July 25, 2021 Stunning!!! Following your WIP, every new step leaves me speechless again Marco F 1
keefr22 Posted August 4, 2021 Posted August 4, 2021 Don't think we'll see any better Fujimi GTO's than this one - beautiful work! Keith 1
Stef N. Posted August 4, 2021 Posted August 4, 2021 5 minutes ago, keefr22 said: Don't think we'll see any better Fujimi GTO's than this one - beautiful work! Keith I'm moving mine to the bottom of the stash to give people time to forget they've seen this one.😀 Absolute brilliant modelling Jacek. Bravo.👏 1 1
keefr22 Posted August 4, 2021 Posted August 4, 2021 23 minutes ago, Stef N. said: I'm moving mine to the bottom of the stash to give people time to forget they've seen this one.😀 Can you put mine next to it...?? K 1 1
Redstaff Posted August 5, 2021 Posted August 5, 2021 That's stunning mate I had to check the scale as I thought it was 1/12 not 1/24 which makes it even more incredible The finish on the paint has such a deep shine as well 😎 Ian 1
Six97s Posted August 5, 2021 Posted August 5, 2021 14 hours ago, keefr22 said: Don't think we'll see any better Fujimi GTO's than this one - beautiful work! Keith I'm looking at it and imagining the mess I'd have made, trying to work with such fine details. 😐 1 1
chaves pah Posted May 16, 2022 Posted May 16, 2022 front On 6/4/2021 at 11:02 AM, Coppercat said: Frame shape. Any other. Unfortunately, I cannot say which frame is closest to the original one. I chose the Fujimi frame for further work, but only because I like it the most I compared the set rims. The ones from the Gunze set are the best. They have the disadvantage that their diameter is smaller than that of the Revell or the Fujimi. Accordingly, the tires would also have to be Gunze. And here is the problem, because the quality of these tires is, to put it mildly, poor. Revell's tires are more suited to an off-roader than to a sports car. The only possible option is Fujimi tires. The rims will be metal by KA-Models. The spokes are photo-etched, but so delicate you can't see they're flat. The manufacturer makes them in versions for the following models: Fujimi, Revell and Italeri. This is a Revell version, so it will be necessary to add a suitable hub. I will use one Gunze rim with a Revell tire for a spare wheel. Initially, I made wheels with lids with a yellow Ferrari logo: However, after comparing with the photos of the original (I think), I changed the caps to the following: The caste has been cut out a bit (this is not the end of cutting 🙂 I covered the cut elements with 0.2 mm polystyrene strips. To be continued.... Great work going on, Coppercat! but there are some issues on the wheels side... in the image showing all three kits wheels, I am positive that the "Gunze" wheels are in fact the PROTAR rendition, (IMO by far the best plastic wire wheels ever made!) and some 10 years (or more) later launched by Revell who bought the Protar moldings, that lost a little detail ( it might be the chrome versus the Protar painted option ); Revell added 4 more outer sides ( if you rotate the Revell fret you can see they are the same original mold but with the extra outer wheels added), perhaps thinking in an hypotetical future 1957 250 Testa Rossa .... Protar/Revell tires are outrageous and must be replaced... but, if the Academy 250 LM Ferrari tires are used, no aftermarket wheels are needed at all! The tires on the wright are (ridiculously) correct Gunze made, but it's wheels spokes are closed in the back side, one can not see thru it at all... a poor "wash" solution, or then an inevitable subtitution... About these Photoetched wheels, I am affraid you forgot that Ferrari 250 GTOs have rear much deeper (and wider) wheels with a bigger tire diameter, so the correct option for this car is the MFH Ferrari 250 GTO wheels and tires set... Fujimi kit tires are totally wrong (as wheels are)... I think that these KA-Models 4 equal wheels are suited for the 250 SWB...
jacko705 Posted June 6, 2022 Posted June 6, 2022 I can't trace the fuel line of the 250 GTO from the aft fuel pump/filter to where the yellow fuel line goes into the back of the dashboard. Does anyone know where it runs between those two points?
