Connected HV wires with ignition coils.
The throttle position control cable.
Connected (working - without glue) the last fuel line (the yellow one towards the cabin).
Arranged power cables of the lighting of the clocks on the dashboard.
Custom seat belts, center tunnel tachometer, handbrake lever etc.
Clocks lighting test:
Shock absorbers are made:
  • Like 15
Thank you very much for your positive comments 🙂
Little progress:
- I put the brake hoses,
- I installed rear shock absorbers,
- I pasted the sides of the engine compartment.
  • Like 12
Amazing work. I am building a 1:12 250 GTO right now as well, and this is inspirational. The detail you are getting in the smaller scale is very impressive.
Regarding details:
Keys in the ignition switch 🙂
:yahoo:
  • Like 11
And I bet when you put some fuel, oil and water in, she'll start first turn of it....!! :)
Lovely work!
Keith
  • Haha 2
I did not know how to modify the tips of the air intakes (under the hood). I found a two-color (aluminum) foil. It is silver on one side and gold on the other side.
It has a nice delicate texture. I thought: why not?
And it turned out like this:
005.jpg.82a9741bfa95cbf7dfe9f99d8c6a44cc
  • Like 10
Preliminary work on the frames of the headlights. After cutting and processing the plates, I caressed them with a stick and an eraser.
It is bent from the flat bezel, but it matches the curvature of the reflector. Now I can drill holes for mounting rivets and then paint the frames (Molotow).
I'm getting the taillights ready. They are weirdly large and I don't know if they will fit
I wanted to create frames imitating frames and seals, but I must forget about it.
002.jpg.6aa3ee264cf7f9108d5b0307abc75554
I "bound" the pins for the production of hinges. There will be some.
Body elements got the first base color layer. Gravity GC-107 Ferrari Rosso Corsa.
I riveted the air intake tunnel on the hood. Master Club rivets 0.4 / 0.6 mm.
to be continued ......
  • Like 14
More superb details - and I'm really impressed by how you managed to curve the headlight frames into that shape!
Keith
Keith
Seconding what Keith said. Using an eraser to form curves is genius!
I did a caste fitting to the chassis.
I tried on all moving parts (bonnet, hatch, radiator cap, doors).
I found out that you can try to put it together, but it won't be easy.
Photos from the fittings (all on the word of honor or Patafix)
  • Like 14
I installed all the lights. There was a lot of it:
- turn signals,
- dipped beam,
- position lights,
- cabin lighting,
- clocks backlight (done earlier).
I glued in all the lampshades of all kinds.
I made all the hinges of the moving parts:
- doors (only one side in the photos below),
- boot / spare wheel cover,
- engine hood,
- radiator cap.
I also worked on details such as:
- nets to mask various holes in the car body,
- engine hood closing fittings,
- matching the glazing,
- air intake on the rear window,
- a million other things that I have already installed or prepared for installation.
and that's it ...
  • Like 12
