F-14D Trumpeter...
...in 1/144 scale.
Hi y'all!
Felt like building a jet. Quickly though, it's only a jet. Something small, and fast.
Took me longer than I thought though... But here it is. Hope you'll like it.
Ciao
Iwik
  • Like 28
Hi manuel.
Pretty easy actually, but time consuming.
It's just a matter of spraying different layers of slightly different grays, applying masking fluid with a sponge between each layers. Make sure you don't remove all the masking fluid between each steps. Thus the last masking fluid parts to be removed will show the very first layer of paint you've applied.
Add a few marbling effects with very light grey and very dark one between layers (and masking fluid! Again).
Finalize with a pin wash with black oil paint.
And voilà!
(basically... :) )
ciao
Iwik
5 hours ago, iwik said:
Hi manuel.
And voilà!
(basically... :) )
ciao
Iwik
Thanks for sharing. 👍👏
On 6/3/2021 at 4:23 PM, Paintychops said:
If you're that good at such a small scale, would love to see what you're capable of at a larger scale! Top work 👏
No thank you!!!😜
Or it will be a kitty without any weapons and landing gears in the up position. Waaaayyyy too boring to do.
Thanks all for the kind comments!
Ciao
IWik
