The Other Tim's 1/48 Airfix Canberra PR9 - modelled as Shorts SC.9 XH132 Royal Aircraft Establishment, visiting RAF Wyton 1884 - paint scheme RAE ‘Raspberry Ripple’
Tim Moff
Heres the thing - I don't model many things that are unarmed - so I looked at my stash and there was the PR9 I got at a snip some years back, part of building aircraft from my nostalgic youth, living in East Anglia... so I dug it out and looked at the ongoing builds to find a few PR9's in1/48 and 1/72...what can I do different...and found the Alley Cat SC9 conversion - why not I thought.
All kit reviews also hammered the decal quality - not easy to get aftermarkets anymore...
Alley Cat conversion kit:
Then I have seen @DaveJL's build and thought, great another project I can follow and handrail - sorry Dave my last 3 builds have kinda mirrored yours, obviously we have similar tastes, honest I am not a copycat!
The next factor - I am due to jet off to Tokyo with work on 12 July to cover the Olympics (if it goes ahead!) so my initial look at the dates thinking I have til August was thrown into touch!
So what option paint job should I do - looking at Dave's build and the fact a bit of the extra lumps will be omitted, I have thought I can bash it together reasonably quickly as I am off this week (though the suns out!) which would give me the time for the paint job....
Anyone have any preferences?! Depending on the option a number of early decisions will need to be made (with/without tanks, antenna holes etc) - oh and requisitioning paints etc....
Option 1 - High speed Silver would be straightforward paint wise, with the Day-Glo and blue primer - but my building skilz are not perfect so would show the likely many imperfections!
Option 2 - White always a challenge I spose and similar imperfections wise as Silver ....
Option 3 - never done a Raspberry Ripple, would be a challenge I guess, but with Mr Paint Lacquers the drying time is quick meaning the masking etc would not have to wait days as per other paints....
Option 4 - Hemp/LAG would be a bit easier I spose....
So - what will it be....
Next I will get the parts off the sprues, get the cockpit done quickly, believe its not correct and it will be black with a bit of artistic license on the buttons and switches...maybe get some of the other bits off and cleaned up as well.
Edited by Tim Moff
Nice mate! I like the Hemp or the silver scheme myself!
I'm not long after priming mine and looks like it needs some clean up. The fitting of the resin cockpit has definitely gave me more work!
So I am going with the Hemp/LAG scheme, mainly due to time....not many pictures around so will be taking a few guess on some lumps and bumps (lack of) etc...
One day I will do the 'Raspberry Ripple' - but not this time!
Got started, some removing from sprues, priming and test fitting....
Artistic licence with the pit as its not correct and will be hardly seen with the canopy down....
With so much glass knocking about I got some masks...
  • Like 9
But more done
lots of messing with the cockpit and join plus plenty of filler on the seams
also used the masks on the belly
need to get this all sanded, not my best skill ! Adjust the tail fin a bit as per the advice …
You do know that the SC9 never flew in Hemp? The Hemp colour scheme was applied ONLY after the aircraft had been relegated to a ground instructional role at St Mawgan, as  practise for St Mawgan's painters and finishers.
Thats interesting - I didn't - thanks for letting me know....leaves me in a bit of a quandary as I build wheels up! Wondered why I couldn't find any flying picture examples.....
Will need to rethink - just filled the fuel tank holes as well! Easily smoothed off and drilled out.....
So its Raspberry Ripple, High Speed Silver or White!
Bit more done.
Tail shape done
Seams are my nemesis - not perfect but will do....
Need to sort wings next - If fit allows I may leave them off for the painting...
That's coming along well. I'm not a fan of seams either but you've done a good job of dealing with them.
Moving on….typically my flight to Tokyo 20 has been bought forward to the 8th so the pressure is on….or will the IOC or Japanese gov cancel ?!
final building and sanding and priming !
CA glue out having primed and painted the front end of the come etc
instructions for the paint on the tanks is slightly different to the reference pics that show one with a lot less white at the aft end….
got the mr paint white onto the fuselage upper areas ready to mask off for the red stripe…
White takes no prisoners so there are some flaws but hey ho I will drive on now !
next I need to get the wings primed and start on them, also start masking off the white areas to protect them. Will then mist paint seal over the tape to try to prevent any bleed from the red …
black anti glare next, then onto the red.
I then plan to mask and black prime the areas for the blue paint .
some of the stencils from
the kit are not suitable for this scheme so I will start the decal search 🤣
Grand painting plan underway !
white and masking
anti glare and red on
Blue
Unmasked - some areas to touch up but not too much bleed
the issue with these type of schemes is you do what I used to do when I used to zero my rifle on the range when I was serving in the Parachute Regiment - start chasing the small errors !
I will try to sort out each little bit individually then put it down and re asses …
need to get the wings done now and I think I may in with a chance to finish before I get on the plane to Tokyo 20….
Lots of painting, masking, taping, swearing and touch ups etc !!
You get the gist !
Next is decals … @DaveJL is kindly sending me some model alliance spare stencils as many of the kit ones are the wrong colour so hopefully will be able to correct some …
Start on the decals
had to slice a strip out of the wing roundels so I could avoid the wing vortex’s which I will hand paint blue
Not sure the mr paint blue sprayed so well as I’ve got a bit of slivering …don’t normally need to gloss with Mr Paint so I didn’t …
starting to look like a Frankenstein Canberra !
what do people use for panel washing over white ?
I have Grey Tamiya panel accent - would that work ? Same with red/blue -use brown ?
or just leave it clean ?
  • Tim Moff changed the title to The Other Tim's 1/48 Airfix Canberra PR9 - modelled as Shorts SC.9 XH132 Royal Aircraft Establishment, based at RAF Wyton 1976 - paint scheme RAE ‘Raspberry Ripple’
It's really coming alive now Tim - probably the largest Raspberry Ripple model I've ever seen :coolio:
Got the minimal amount of stencils on - it seems the black coloured ones are not available even on the MA sheet kindly passed onto me by @DaveJL so I used yellow where it looked ok…   more work in areas and got the gloss is on
Gonna try the grey wash on the white, brown on red and black on the blue … maybe in some inconspicuous areas first …
then it’s time to join it all up and maybe make up a satin topcote from a mix of gloss and flat  - the pics don’t look properly gloss ?
I’ve used the 3 Tamiya panel line washes - will clean up and see how it looks …
home straight, satin coat, lights and antenna then get the wings on
Final assembly time!!!
Done and dusted....
Sorry to bombard with pics - not sure which background works best for the gallery pics...
Blue background does weird stuff with the red so tried a beige background....
  • Tim Moff changed the title to The Other Tim's 1/48 Airfix Canberra PR9 - modelled as Shorts SC.9 XH132 Royal Aircraft Establishment, visiting RAF Wyton 1884 - paint scheme RAE ‘Raspberry Ripple’
