Early PR Spitfires
dad's lad
I'm testing my limited knowledge of Spitfires now but would I be correct to assume that Mk.I's and Mk.II's were never tropicalized using the Vokes filter and therefore any PR Spitfires with such a filter would have been based upon the Mk.V airframe?
If the latter is true, would I be correct to assume that the Mk.V's rounded oil cooler would be needed plus a Mk.V propellor unit?
I'm using the Pavla set designed for the Airfix Mk.I which only shows to use the supplied resin oil cooler which doesn't look rounded.  If my assumptions are correct, I can use the Airfix Va as the starting point with a spare Vb propellor and spinner.
Regards
Clive
Yes, by the time Spitfires were tropicalised, any operational ones (including PRs) would have had the later style oil cooler (with the "tail", too).
Prop could be variable, so ideally find a subject you've got a photo of.
Thanks, it would help if people would decide what mark an Airframe actually is. Pavla would have BR880 "Flying Scotsman" as a PR MK.VI whilst AIMS Decals would have the same aircraft as a PR.Mk.IV!! As far as I can tell, AIMS are correct.
Clive
Edited by dad's lad
Many of the earlier PR Spitfires were upgraded to Mk.V standard anyway.   The key point being the engine.  However the PR marks are dependent more upon camera fit and fuel capacity.  According to Spitfire The History the Mk.VI should have blisters under the wing for additional fuel tanks and the enlarged oul tank under the nose.  However, STH fails to mention the oiil tank for Mk.IVs...
Thanks as always Graham, I need to invest in some decent reference material.
I've found it doesn't help when researching PR variants that the numbering changed (e.g. PR.IV becoming PR.ID)
Clive.
Wrong way round.  PR Type D became PR Mk.1D which then became PR Mk.IV.  It certainly doesn't help using PR (and Seafire) Mark numbers that don't mean the same thing as the fighter Mark numbers.  Hence the later allocation of individual numbers.
Whoops, was nearly there.
1 minute ago, The wooksta V2.0 said:
Ideal reference for the Merlin PR Spitfires is the two volume set released by Ventura in New Zealand.  Not sure if it's OOP, but it's worth it's pricetag.
Thanks, I'll have a look around.
Clive
A mere £858.87:D  I'm quite for paying for something really useful but that seems a tad excessive.
Righto then, looks like you lot will have to put up with my inane questions for longer then...😁
I have checked in Morgan & Shacklady's 'Spitfire the history' and also Bruce Robertson's 'British Military Aircraft serials' and neirther lists BR880 as being allocated to a Spitfire. Unless somebody cleverer than me knows different or I have misread both books?
10 minutes ago, Troy Smith said:
since there was no PR.VI I assume it's just a typo.
STH thinks that there was such a thing:  The Type F (LR) converted by Heston Aircraft 1941/42, pp241/242.  Gien that there was a Type G or Spitfire PR Mk.VII, this seems reasonable enough.
I've just checked, Pavla has it as BR880 whilst Model Alliance has it as BP880 and AIMS as MP880. To further complicate matters, Pavla and AIMS have it in PRU Blue whilst Model Alliance says "dark blue" which I assume was the so-called "Bosun" blue.
Unless there was more than 1 Flying Scotsman I'm completely confused by now.
Clive.
I suspect it should be BP880 which was a Spitfire PR IV(T) as BR880 in non allocated block as was MP880
First Flight 31.1.1942
1 PRU 6.2.1942
Crash landed en route to Middle East 16.3 1942
Heston Aircraft Limited 20.6.1942
RAF Benson 13.1.1943
India 23.9.1943
Failed to return ops 5.3.1944
All taken from Morgan & Shacklady
Clive.
I'd not trust Model Alliance research, plenty of it was erm, not great.
OK ( I was typing while the above ot posted)
http://www.airhistory.org.uk/spitfire/p028.html
BP880 PRIVT 2551 Super M46 FF 31-1-42 1PRU 6-2-42 crashed en route to Middle East 16-3-42 HAL 20-6-42 Benson 13-1-43 India 23-9-43 Abandoned over Bay of Bengal on PR mission 5-3-44
No Spitfire serialed MP***
sticking Spitfire PR BP880 into a search
http://micklem.com/681/BP880-1.jpg
which looks like other PRU blue Spitfire I have seen taken in India.  "Bosun Blue" or some dark blue means the roundel don't show up, and get ringed, or they use a lighter blue.
PS EDIT
See the link for a lot more very useful PR Spitfire images.
Note, the book "Eyes of the Phoenix"  is a really useful book, far more than might appear from the titles, as it has very good and extensive set of colour references for the types covered in the book, so not just RAF, but FAA and US colors for the Lend Lease types, as well as being a very interesting book in it's own right, and is not bank breakingly expensive
https://www.amazon.co.uk/Eyes-Phoenix-Photo-reconnaissance-Operations-South-East/dp/0951989944
Thanks, hadn't spotted that, though this is a PR VI, not related to the MK.VI fighter.
1 PRU 6.2.1942
India 23.9.1943
Thanks hugely Nigel, so if Model Alliance are right with the serial, do I assume the colour is correct too? The only picture I can find online is a rather grainy one that LOOKS like PRU blue.
EDIT: Was typing this as Troy's reply was coming in.
Clive.
Edited by dad's lad
Thanks Troy, I did find that link but I can't see the pictures.
Edited by dad's lad
According to the RAF census as of end June 1944,
18 mark I in the Mediterranean and another 8 had been lost overseas, some mark I shipped to equip training units, whether they had Vokes filters is unknown, the Middle East preferred the Aboukir filter.
1 Mark II had been shipped to a Dominion Air Force (Canada), otherwise the version stayed in Britain, none listed as overseas or lost overseas.
1 PR.III had been shipped to a Dominion Air Force (Unknown), otherwise the version stayed in Britain, none listed as overseas or lost overseas.
PR.IV, 43 in service overseas, after 61 overseas losses (versus 126 losses at home).
End census information.
The early PR versions were quite experimental with plenty of changes and modifications of changes, and so on.  The first attempt to classify things was using letters, A to G where camera and fuel fit were the main determinants of what letter was allocated.  D was for example the very long range version with leading edge wing tanks.
PR Spitfires began coming off the production/delivery to RAF line in August 1940.  It looks like it was in early/mid 1941 the letters to at least D were standardised and possibly by June 1941 when the first PR.IV came off the production line mark numbers were in use.  The two series eventually reaching "G"/Mark VII.
The earlier production PR types were called mark III and being mostly shorter range had come from "C", based on the mark I fighter, Merlin III engine.  The PR.IV began production 3 months after the mark V fighter and were based on that version, fitted with Merlin 40 series engines and had the wing tanks, "D".
You can see where the A = mark I, G = mark VII come from.
BP880 was one of the first PR.IVT (Tropical) versions built, in January 1942.  BR880 and MP880 did not exist.  There are photographs of mark IV in the Middle East with Vokes and others with Aboukir filters.
I can, perhaps try a different browser, or check your settings?  I'm on Firefox.
Note my comments on Eyes of the Phoenix i added as well, which you may have missed as an edit, as the pictures of BP880 are in there.
PS EDIT
PS EDIT
I'm using Edge so that might be the cause. Thanks for the link to the book, it's straight into my Amazon basket.
Clive.
Seconded, a very good book if you're interested in SE Asia air ops in WW2
