Tim R-T-C Posted May 23, 2021 Share Posted May 23, 2021 So a little late entry, but hopefully I'll get it finished in time (and my other open build too...) This is set in Spanish occupied Morocco during the 1920s Rif War, considered the last war of colonial occupation. The centrepiece is a Spanish F2B which hasa handsome green livery. However it must be acknowledged that these were used in terrible attacks on local populations including the use of poison gas. The Valom kit is one of the better entries to their Great War collection, with locating pins, something of a cockpit and avoiding the bizarre resin engines they insisted on in the earlier productions. Like all their Great War planes though, there is going to be a lot of photoetch in use here - all the struts are brass as is the undercarriage. Made a start tonight - painted and built up the cockpit and completed the fuselage. 4 Link to comment Share on other sites More sharing options...
Col. Posted May 24, 2021 Share Posted May 24, 2021 An interesting subject choice Tim and what sounds to be an interesting kit to realise it with. I'm looking forward to your progress reports with this one 1 Link to comment Share on other sites More sharing options...
Tim R-T-C Posted May 25, 2021 Author Share Posted May 25, 2021 (edited) So buttoned up the fuselage and painted the plane. Went for a nice Bronze Green based on the profile included with the decals. These schemes were not necessarily for planes deployed to Spainish Morocco but its the right year and right type so probably as close as I'm going to get. Decided to decal up before putting the wings on as I think it is going to be rather delicate! The LF decals require individually cutting oout but go down nicely. The tail colours were provided as a square decal so will need cutting to shape once its dry. Edited May 25, 2021 by Tim R-T-C 6 Link to comment Share on other sites More sharing options...
Col. Posted May 29, 2021 Share Posted May 29, 2021 I've just realised you're working in 144th scale here Tim! Well done sir Link to comment Share on other sites More sharing options...
Tim R-T-C Posted May 30, 2021 Author Share Posted May 30, 2021 On 5/29/2021 at 6:58 AM, Col. said: I've just realised you're working in 144th scale here Tim! Well done sir There are other scales? 3 Link to comment Share on other sites More sharing options...
Tim R-T-C Posted June 2, 2021 Author Share Posted June 2, 2021 Started on the accessories... 1 Link to comment Share on other sites More sharing options...
Tim R-T-C Posted June 2, 2021 Author Share Posted June 2, 2021 Tiny tank 2 Link to comment Share on other sites More sharing options...
Col. Posted June 5, 2021 Share Posted June 5, 2021 Your eyesight must be phenomenal Tim! 1 Link to comment Share on other sites More sharing options...
exdraken Posted June 6, 2021 Share Posted June 6, 2021 Great subjects!! 1 Link to comment Share on other sites More sharing options...
Tim R-T-C Posted June 8, 2021 Author Share Posted June 8, 2021 (edited) The Valom kit comes with tiny bits of plastic to use for raising the fuselage over the lower wing. These simply did not hold, so with quite a lot of work I used brass tube in its stead. EDIT - since this post, the lower wing decided to seperate again. So I think I will have to cheat and use some sprue in the middle of the raised section to hold it securely, with styrene rod for cosmstic support. Edited June 9, 2021 by Tim R-T-C 3 Link to comment Share on other sites More sharing options...
Col. Posted June 9, 2021 Share Posted June 9, 2021 Do you think a piece of clear sprue may add more support without looking too obvious Tim? Link to comment Share on other sites More sharing options...
Tim R-T-C Posted June 9, 2021 Author Share Posted June 9, 2021 (edited) 4 hours ago, Col. said: Do you think a piece of clear sprue may add more support without looking too obvious Tim? Thanks, might work, or I might try to paint it in the bronze green to blend in. All my vignettes are designed for display tables so from a normal viewing angle, given how small it is, hopefully won't be visible! Edited June 9, 2021 by Tim R-T-C Link to comment Share on other sites More sharing options...
Tim R-T-C Posted June 13, 2021 Author Share Posted June 13, 2021 Moving along now. 1 Link to comment Share on other sites More sharing options...
Tim R-T-C Posted June 15, 2021 Author Share Posted June 15, 2021 Here comes the Cavalry 1 Link to comment Share on other sites More sharing options...
Tim R-T-C Posted June 15, 2021 Author Share Posted June 15, 2021 Rigging 😕 2 Link to comment Share on other sites More sharing options...
Col. Posted June 17, 2021 Share Posted June 17, 2021 Rigging in 144th scale! Link to comment Share on other sites More sharing options...
Tim R-T-C Posted June 17, 2021 Author Share Posted June 17, 2021 12 hours ago, Col. said: Rigging in 144th scale! Yes this was certainly the most complex I have done, with bracing and control cables, but it is well worth the effort... Although you might have to wait until seeing it in person for the full effect - if SMW goes ahead I will certainly take it! So with that I'm calling this one complete Somewhere deep in the Rif Republic, 1925 - an aerial observer reports tribal positions to a Spanish column. 4 Link to comment Share on other sites More sharing options...
Col. Posted June 18, 2021 Share Posted June 18, 2021 Impressive work again Tim. There's certainly a lot going on in this diorama Link to comment Share on other sites More sharing options...
Colin W Posted July 24, 2021 Share Posted July 24, 2021 Excellent work for modelling and storytelling. The pictures look a little dark but it dosnt detract. 1 Link to comment Share on other sites More sharing options...
