pheonix Posted May 23, 2021 Share Posted May 23, 2021 (edited) Evening All, As there is still lots of time left for this GB I thought that I would amaze Ian @Brandy by building a tractor monoplane - just to show him that I can do it! It will not have spare wing but it will have a few wires to help to hold it together, so it can be regarded as authentic aeroplane!! I have chosen this subject because I want to make something simple: in addition this is another type which has been on my "to do" list for a long time. The Morane type L Parasol was widely used by RFC, RNAS and French and Russian forces in the first two years of WW1. The Pfalz Company in Germany also built many of these under license. Perhaps its most famous moment came in June 1915 when Lt Warneford managed to down Zeppelin LZ 37 by dropping small bombs on it. The French pilot R Garros had steel deflector plates fitted to the propellor of his MS L so that he could fire a machine gun forwards along the line of flight and in doing so caused others to investigate more seriously the interruptor mechanism for machine guns firing through the propellor arc. I have made a small start by cutting some 30 thou plastic sheet for the fuselage sides, top and bottom: I have started to modify a cowling from an Airfix Avro 504 which I found in the spares box and did not know I had! I have cut off the rear to narrow the chord and glued a piece of 20 thou card on the inside of the opening to make that smaller. Later I will reshape the front of the cowling: The green stick is an old cocktail stick, (again found in the spares box), which I intend to use to make cylinders for the rotary engine. The other pieces are also for the engine. The engine crank case was made from a disc of 40 thou card and the cylinders were mounted around the edges. A smaller disc of card made up the front of the engine and push rods were made from 20 thou Evergreen rod: [ More to follow in due course. Thanks for looking. P Edited May 31, 2021 by pheonix 10 1 Link to comment Share on other sites More sharing options...
Torbjorn Posted May 23, 2021 Share Posted May 23, 2021 Excellent choice This one is on my to do list too (one of the Swedish copies), so I shall be taking notes. 1 Link to comment Share on other sites More sharing options...
stevehed Posted May 23, 2021 Share Posted May 23, 2021 Very nice. Are you going for single seat or two? 1 Link to comment Share on other sites More sharing options...
Brandy Posted May 24, 2021 Share Posted May 24, 2021 Suitably surprised and following along! Ian 1 Link to comment Share on other sites More sharing options...
pheonix Posted May 24, 2021 Author Share Posted May 24, 2021 It will be a two seater Steve. 1 Link to comment Share on other sites More sharing options...
pheonix Posted May 31, 2021 Author Share Posted May 31, 2021 Evening All, Thanks Torbjorn, Steve and Ian for your kind comments - much appreciated. I have finished painting the interior and rigged the parts of the cockpit sides that will be visible with copper wire. I used strip and rod for most details, some of which I have not shown yet. I will put a bulkhead in the rear fuselage so I have not put any details in there: they will not be visible and I wish to keep this as a fairly quick and simple build. In addition I have painted the engine: as this will be largely obscured by the cowling and propellor I decided that this too would suffice for this model: I have still got to finish shaping the cowling and add a firewall, make some seats and controls and other minor details and then I can assemble the fuselage. I hope to show that stage in the next post. Thanks for looking. P 9 Link to comment Share on other sites More sharing options...
Torbjorn Posted June 1, 2021 Share Posted June 1, 2021 Nicely done. And special kudos for making a rotary/radial, I don’t think I’d even bother to try. 1 Link to comment Share on other sites More sharing options...
Ray S Posted June 1, 2021 Share Posted June 1, 2021 I have a vacform one of these to do for the 'French Fancy' GB later. All the best with this one, Ray 1 Link to comment Share on other sites More sharing options...
pheonix Posted June 6, 2021 Author Share Posted June 6, 2021 Evening All, Thanks Torbjorn and Ray for following and commenting. The engine was not difficult to make but there are excellent examples made by Small Stuff which I could have used but I am a bit short of the readies just at the moment. Ray I hope that this build will help you with yours - it is not a difficult model to build for the most part - I will try to offer advice when I fix the wing, which will be interesting.... The fuselage is assembled and nose added. I decided to put in a couple of pockets for the pilot and observer on the starboard (right) side of the fuselage - not sure why as they can barely be seen and usually I do not bother with such details these days as I consider that if it cannot be seen on the completed model then there is no point in putting it in. I also added seats, an oil and fuel tank, controls for the pilot etc. After the fuselage parts had been glued together a small amount of filler was run along the joints just to ensure that there were no gaps. The images also show the upper decking of the front of the fuselage and engine cowling prior to fixing to the fuselage. The decking is 20 thou card which has been gently bent over a paintbrush handle. The cowling has been modified by sticking some 30 thou card in the front apature and then filing and sanding until I achieved the correct shape. The firewall at the back is 30 thou card. The interior of the cowling assembly was painted in aluminium and some wash of brown/black applied to represent the oil thrown off the engine. The fuselage assembly is now ready for paint: I have cut the wing from 30 thou card which had been bent in an old pipe and plunged into very hot water for about 10 seconds. The ribs have been applied (10 x 20 thou strip) but not sanded when I took the photo. Similarly I cut the horizontal tail surfaces and added the ribs: The model is about ready for paint - just have to make the wheels from discs of 60 thou card and tyres from 40 thou rod. Thanks for looking. P 7 Link to comment Share on other sites More sharing options...
Torbjorn Posted June 6, 2021 Share Posted June 6, 2021 Smallstuffmodels is where I go to as well - I loose all mojo seeing their engines, knowing there is no way I could come close with my hand tools. — Like you I have reduced the amount of detail I put into the interiors. Life’s too short making stuff that won’t be seen. Still looks nice and realistically crowded, these old machines didn’t have that much gadgetry anyway. Were there no fairings behind the cowling? 1 Link to comment Share on other sites More sharing options...
Ray S Posted June 7, 2021 Share Posted June 7, 2021 12 hours ago, pheonix said: Ray I hope that this build will help you with yours - it is not a difficult model to build for the most part - I will try to offer advice when I fix the wing, which will be interesting.... Phoenix, thanks for that, I will certainly take away some ideas. The Scaleplanes vacform was a surprise when I bought it. I only saw the vacform sheet and instrutions when I looked at it on a trade stand at out Gloucester Model Club show a few years ago, but then found it had white metal parts, a sheet of photoetch and transfers too! The struts are all etch, but I was thinking of using them as a template and making them from Aeroclub strut material. If I have read the instructions right, the struts from the fuselage to the wing are all vertical in one plane (sorry!), even though the back ones are angled. But I agree, it will be 'interesting'. All my other Scaleplanes kits had just been the vacform sheet. I love what you have done so far, it is looking fabulous. All the best, Ray 1 Link to comment Share on other sites More sharing options...
pheonix Posted June 7, 2021 Author Share Posted June 7, 2021 21 hours ago, Torbjorn said: Were there no fairings behind the cowling? No the cowling was just left sticking out from the sides of the fuselage, which was unusual for the time. Most aircraft had fairings of one sort or another of course. Thank you for the kind comment. P Link to comment Share on other sites More sharing options...
pheonix Posted June 7, 2021 Author Share Posted June 7, 2021 10 hours ago, Ray S said: If I have read the instructions right, the struts from the fuselage to the wing are all vertical in one plane (sorry!), even though the back ones are angled. But I agree, it will be 'interesting'. All my other Scaleplanes kits had just been the vacform sheet. I love what you have done so far, it is looking fabulous. All the best, Ray Many thanks for the compliments Ray. You have read the instructions correctly: the front struts were vertical on those machines. The tricky bit is going to be drilling the holes in the wing in the correct places - careful measurement and close consultation of the plans is going to be required. P 2 Link to comment Share on other sites More sharing options...
pheonix Posted June 13, 2021 Author Share Posted June 13, 2021 Evening All, I have painted the main parts of the model. I used Humbrol 103, (clear doped linen), mixed with white for the fuselage and flying surfaces, and Humbrol black for the cowling and stripes on the fuselage. I added some 10 x 20 thou strip with the corners rounded with a file to make the frame on the front of the fuselage behind the cowling. The wood was Revell 382, as was the propellor which I found in the spares box: I had made one for another model and reduced it in size to fit this one. The national markings were Humbrol white, red (60) and blue (25) mixed with white. I scribe a circle the diameter of the roundel using a pair of dividers on to the surface I wish to paint. I apply two or three thin coats of white to the circle - the paint is taken to the edge of the circle but not allowed to run into the groove. I then scribe two more circles into the white paint and apply the red and blue - this time the paint is allowed to run into the groove and a nice clean edge results (provided that my hand does not move when I am painting). I rest my and on the desk when painting like this and I use an eye loupe (magnifying lens) on my glasses. The roundels are of the Royal Naval Air Service prior to mid -1916: I have not added a serial as I do not have suitable transfers so this will be a generic representative model. Next I intend to complete the assembly and final details - undercarriage, wing plus struts, engine etc. Thanks for looking. P 9 Link to comment Share on other sites More sharing options...
Ray S Posted June 14, 2021 Share Posted June 14, 2021 Wow, that is great, and it is a new way of painting roundels which I have never heard of! I will not be trying that, my hands are certainly not steady enough. Cheers, Ray 1 1 Link to comment Share on other sites More sharing options...
Torbjorn Posted June 14, 2021 Share Posted June 14, 2021 That’s indeed a neat way of painting roundels. I will have to try - your results are better than what I get using masks. For serials, I’ve used homemade printed on clear decal paper with moderate success. It’s a bit too thick but for serials I can live with it, especially (common for British and Swedish at least) when they are on a painted rectangle that the decal can be matched to. 1 Link to comment Share on other sites More sharing options...
PeterB Posted June 14, 2021 Share Posted June 14, 2021 Whilst I do have sets of black and white numbers/letters in the small sizes for WWII RAF serials I usually print my own if they are black or a dark colour, particularly if they are a non standard size. It is one of the things my bog standard HP deskjet does pretty well and a lot easier than assembling them character by character with my shaky hands. I guess I could do WWI serials if I had/have the right font but I have never tried. Pete 1 Link to comment Share on other sites More sharing options...
pheonix Posted June 14, 2021 Author Share Posted June 14, 2021 Thanks for the comments gents. I too have tried printing serials and assembling them from sheets, but this time I could not find suitable numbers in the correct font from the transfer sheet, and I do not have the correct font or size on my desktop. I will leave that detail out on this occasion. P Link to comment Share on other sites More sharing options...
pheonix Posted June 21, 2021 Author Share Posted June 21, 2021 Evening All, I have completed most of the construction and the model is now well on the way towards completion. The first step was to fit the undercarriage. The tail skid assembly looks complicated but in reality it is 4 outer support struts with a central post on which the skid was mounted. The purpose of the outer struts was to keep the skid rigid. Similarly the main undercarriage legs were simple to make and assemble - I used 30 thou rod, (which is probably a little over scale but needed for strength), with plastic rod for the axle. The V struts for the bracing wires were also made from plastic rod and the undercarriage assemblies were painted after fixing in place: Once it was on its legs I could finish the details in the cockpit and add the windscreens for the pilot and observer. They were cut and shaped from clear acetate. To fix the wing I drilled two holes where the main struts passed through and then enlarged them a little with the end of a round file. The struts were shaped from 20 x 30 thou Evergreen strip which had been filed to remove the corners. After several attempts to get everything correctly aligned I cut the rear struts and cemented these to the sides of the cockpit. The main struts were threaded through the holes in the wing and cemented at the top and where they join the wing. While the cement was still wet I lowered the wing/strut assembly so the the main struts were on the fuselage sides and the rear struts fixed against the rear of the wing. This was set aside to harden properly. When the above had set properly it was a simple task to add the reinforcing front struts: [ All that remains now is to paint the struts, rigging and add the wheels and propellor. Thanks for looking. P 7 Link to comment Share on other sites More sharing options...
Ray S Posted June 21, 2021 Share Posted June 21, 2021 That was a very nice way to get the wing on. Hopefully it has been duly noted in my brainbox! It looks fabulous. Ray 3 Link to comment Share on other sites More sharing options...
pheonix Posted June 22, 2021 Author Share Posted June 22, 2021 It was not as difficult as I had feared it might be Ray. As usual with such parts, when it came to doing it, (as opposed to thinking about it), it all went rather smoothly. Just be sure to get the spacing and size of the holes in the wing right. P 2 Link to comment Share on other sites More sharing options...
Brandy Posted June 25, 2021 Share Posted June 25, 2021 I like your thinking for getting the wing fitted. Added to my "useful ideas stolen from others" file! Ian 1 Link to comment Share on other sites More sharing options...
pheonix Posted June 25, 2021 Author Share Posted June 25, 2021 Evening All, I have finished the Morane. The rigging was fairly straightforward as there is only one wing and the attachment of the wires was relatively easy when compared with rigging multi-winged types. I used rolled 40 SWG copper wire attached with CA. The propellor and wheels were easily fitted too and the model was complete. I will post more photos in the gallery shortly. Thanks for looking. P 7 Link to comment Share on other sites More sharing options...
dnl42 Posted June 26, 2021 Share Posted June 26, 2021 Excellent work! Sorry I missed this in the GB. Especially now as I'm trying to scratch build some replacement wings on a biplane. 1 Link to comment Share on other sites More sharing options...
CliffB Posted June 27, 2021 Share Posted June 27, 2021 Beautiful work 1 Link to comment Share on other sites More sharing options...
