Rock effect painting (the lazy way)
The Great Escape
I’ve not seen this method posted any where before so thought I’d share a very simple way of painting a fairly realistic rock base.
FB554F81-3596-4E30-B209-9CAFAF7BC254
CD149C02-0AC8-445C-8746-192E4C91C6CB
EA4D64EF-E547-4DE3-9CE4-4C222DDDFF45
If you have access to a chiminea or log burner, give this a try:
Grab your base material. I use celotex which is building insulation. If you haven’t used celotex before, give it a go. It’s similar in properties to the oasis florists use but it’s much more workable and you can achieve far better shapes.
Then whack on a rubber glove and smear pva glue all over the base
To make the rock colour, I use... ash!
Grab a handful of ash from your wood burner and just pat it on.
The ash gives a great mottled grey effect and I think it looks more realistic than painting. Plus, it’s a very quick way of covering whole sections in next to no time. It takes a few days to dry back.
No idea how I first discovered this but it worked well so I’ve used it multiple times.
