Sandbagger Posted May 16, 2021 Share Posted May 16, 2021 (edited) Hi all, As I'm close to finishing the Hansa-Brandenburg W.20 float plane, I thought I'd start on a 'Planet Models' resin kit. This model represents a Ponnier M.1 ‘Le Vampire’ of the Aviation Militaire Belge, as flown by Abel De Neef from the Ten Bogaerde (Koksijde) airfield in 1915. Before WW1, Louis Alfréd Ponnier was a Director of one of the companies of René Hanriot. In 1913 Hanriot decide to temporarily quit his interest in aviation and Ponnier took over the factory under his ’Avions Ponnier’ trade mark. The Avions Ponnier company attempted to win a pre-WW1 contract from the French military with their 1913 Ponnier L.1 scout, designed by Alfred Pagny, but they were unsuccessful. In 1915 Pierre Dupont was hired as an aircraft designer and in 1916 the Ponnier M.1 was tested by French ‘Aviation Militaire’ pilots, including Jean Navarre and Charles Nungesser. During flight testing, Charles Nungesser was severely injured when the aircraft entered a flat spin. In the ensuing crash, Nungesser had both legs broken as well as his jaw. The crash was thought to have been caused by an incorrect centre of gravity combined with a rudder which was too small. The French lost all interest in the aircraft after this incident. However, the Belgian Air Force were desperate for fighter aircraft and so ordered the type. At least twenty Ponnier M.1s were produced by S.A. Française de Constructions Aéronautiques, Ponnier's successor company to Avions Ponnier. Most of these, probably more than eighteen, were bought by the Aviation Militaire Belge. However, the Belgian ace Willy Coppens found the aircraft to be ineffective, despite modifications, which included a larger empennage and removal of the propeller spinner. The aircraft, like those remaining with the French, were rapidly discarded. Those that were left had their lower wings stripped and were sent to the pilot training school in Etampes, where students used them to learn how to taxi. As an aside, René Hanriot returned to the aviation business and his designer, Emile Dupont was instrumental in bringing about the much better Hanriot HD.1 fighter. Mike Edited June 1, 2021 by Sandbagger 5 Link to comment Share on other sites More sharing options...
Sandbagger Posted May 21, 2021 Author Share Posted May 21, 2021 (edited) Hi all, Some progress on this model. Information on the cockpit detail is non-existent as far as I can tell, so I've built the cockpit as supplied. All I've added rudder control lines and pipe to the priming pump. Getting the two fuselage halves to fully close around the cockpit assembly required some fairly heavy scraping of resin from the cockpit side panels. I also added 1.0 mm thick plastic card strips around one fuselage half to help positive alignment to the other half, as as usual being a resin kit, there are no locating pegs and receptacles. The ailerons in the upper wing were cut out and pinned with 0.5 mm diameter rod, so that the ailerons could be positioned. The tail plane, fin, rudder and elevators were all drilled and pinned with 0.3 mm diameter tube. The elevators are positioned down slightly. As the engine can hardly be seen on the completed model, I decide to use the resin engine supplied in the kit, even though it's not the best representation of the Le Rhone 9c. I've added 0.4 mm diameter Nickel-Silver tubes for valve push rods and tube with copper wire for spark plus and ignition leads. Mike Edited May 30, 2021 by Sandbagger 8 1 Link to comment Share on other sites More sharing options...
Sandbagger Posted May 25, 2021 Author Share Posted May 25, 2021 Hi all, The engine cowl and the two side panels have been added (the engine will fit inside the cowl). Also the kit supplied resin carburettor air intake pipes have been replaced with chamfered 1.8 mm brass tube. This was done as the tubes are angled downwards from the fuselage sides and have chamfered ends, unlike the kit parts. Also added the filler cap as it needed to be sanded away during the fuselage assembly. Finally the lower wings had just one small resin locating stub for locating against the fuselage sides. I replaced them with 1.0 mm diameter rod - the front rod passes through the fuselage into the opposite wing. The rear rods locate the wings at the correct angle to the fuselage, which was not feasible with the original single locating sub. Mike 7 Link to comment Share on other sites More sharing options...
Sandbagger Posted May 28, 2021 Author Share Posted May 28, 2021 Hi all, The landing gear and wing struts supplied in the kit are molded in white metal. Consequently the landing gear in particular bends extremely easily and I suspect may not even take the weight of the model. Therefore I recreated the landing gear struts and axle using brass tube, rod and styrene sheet. The struts are 2.0 mm tube formed around 1.mm rod and soft soldered then filed and sanded to shape. The axle is 2.0 mm tube crushed flat on one aide around 0.8 mm rod. Styrene strips off 0.5 mm thickness were glued to the front and rear of the rod, then sanded to an aerofoil shape. I'm not sure yet whether I'll replace the wing struts - we'll see, Mike 4 Link to comment Share on other sites More sharing options...
Fritag Posted May 29, 2021 Share Posted May 29, 2021 Impressive metalwork Mike. I’ll tag along if I may Link to comment Share on other sites More sharing options...
Sandbagger Posted May 29, 2021 Author Share Posted May 29, 2021 6 Link to comment Share on other sites More sharing options...
Sandbagger Posted May 29, 2021 Author Share Posted May 29, 2021 Hi all, I decided to replace all four interplane struts as the kit parts were also soft white metal alloy. Made from 2.0 mm diameter Brass tube and 0.5 mm diameter rod, soft soldered the profiled, Mike 3 Link to comment Share on other sites More sharing options...
Sandbagger Posted June 1, 2021 Author Share Posted June 1, 2021 Hi all, I've been asked on several forums about making struts from Brass tube and rod. The tool I use is the 'Strutter' made by 'Albion Alloy's' This tool, plus others, was available to purchase on the previous web site, which is no longer online. I contacted 'Albion Alloy's' and this was the reply I received today: "Hi Mike, Many thanks for getting in touch and so pleased to hear your comments regarding the Strutter. We do indeed intend to put the details of how to purchase the hobby tools we do on our website. This will probably happen in the next couple of weeks and I'll keep you informed. Best regards, Matthew at Albion Alloys" There web site: https://www.albionhobbies.com/]https://www.albionhobbies.com/ Video using the 'Strutter': https://www.youtube.com/watch?v=4o10w7aVmIk]https://www.youtube.com/watch?v=4o10w7aVmIk So keep checking their web site if you are interested in the 'Strutter', Mike 1 Link to comment Share on other sites More sharing options...
Sandbagger Posted June 1, 2021 Author Share Posted June 1, 2021 Hi all, Just a few updates. The kit supplied resin propeller was base coated with 'Tamiya' Buff (XF55) then had 'DecoArts' Burnt Umber acrylic brushed on. Finally a sealing coat of 'Alclad' Light Sheen (ALC311) mixed with 'Tamiya' Clear Orange (X26). Forward fuselage and spinner base coated with 'Tamiya' black gloss (X18) then over coated with 'Alclad' Duraluminium (ALC-102). Slot cut forward of the cockpit to house the 'GasPatch' Lewis machine gun. The brass created struts were base coated with 'Tamiya' Buff (XF55) then had 'DecoArts' Burnt Umber acrylic brushed on. The four interplane struts were then clear gloss coated to have 'Xtradecal' 1.0 mm wide black decals applied to represent the linen bindings around the struts. Finally all of the struts were sealed with a coat of 'Alclad' Light Sheen (ALC311). Now it's onto pre-shading the model prior to applying the CDL and plywood effect decals, Mike 3 Link to comment Share on other sites More sharing options...
Sandbagger Posted June 2, 2021 Author Share Posted June 2, 2021 (edited) Hi all, I've pre-shaded the parts ready for applying plywood effect decal to the fuselage and linen effect decal to the flight surfaces. The fuselage if the aircraft was covered in plywood but it's difficult to tell if the plywood was applied as single sheets or as separate panels. One photograph seems to show a panel join, so I've gone for separate panels. Panel lines scribbed with nail lines added each side using a 'Rosie the Riveter' (1.0 mm). Mike Edited June 4, 2021 by Sandbagger 4 Link to comment Share on other sites More sharing options...
Sandbagger Posted June 4, 2021 Author Share Posted June 4, 2021 Hi all, I've applied the decals. The Clear Doped Linen are the '‘Aviattic’ CDL aged varnish (ATT32094), The plywood fuselage are the ‘Lukgraph’ Dark Plywood (DEC004) - from their Friedrichshafen FF.33L kit (32-30). I still have to finish weathering and maybe darken the wood decals, Mike 8 Link to comment Share on other sites More sharing options...
Sandbagger Posted June 6, 2021 Author Share Posted June 6, 2021 Hi all, Just a few updates. I've applied and sealed the weathering ('Flory Models' Dark Dirt clay wash). Also added the pilot's foot plate, made from spare photo-etch) to the lower port wing, which is not in the kit. The replacement 'GasPatch' Lewis Mk.1 machine gun has been fitted. Now onto the pre-rigging, Mike 8 Link to comment Share on other sites More sharing options...
Sandbagger Posted June 10, 2021 Author Share Posted June 10, 2021 Hi all, All of the necessary pre-rigging has been done, using 0.12 and 0.08 mm diameter mono-filament with blackened 0.5 mm diameter Brass tube. The wings were then fitted. The ailerons win the upper wing were controlled from the cockpit by external rods and levers, similar to the French Nieuports. The kit parts had rods that were way too short and would not reach the fuselage openings. I cut the rods away from the levers and fitted 0.6 mm diameter Nickel-Silver tubes with 0.4 mm tube inside. The protruding 0.4 tube fitted into holes drilled through the front end of the levers. Now it's onto final rigging, Mike 7 Link to comment Share on other sites More sharing options...
shortCummins Posted June 11, 2021 Share Posted June 11, 2021 super stuff going on here weathering looks spot on rgds John(shortCummins) Link to comment Share on other sites More sharing options...
Sandbagger Posted June 16, 2021 Author Share Posted June 16, 2021 Hi all, The rigging has now been finished, apart from painting the turnbuckles. Still to do are the wheels, tail skid, windscreen, ailerons, engine assembly and the figure, Mike 7 Link to comment Share on other sites More sharing options...
Sandbagger Posted June 16, 2021 Author Share Posted June 16, 2021 Hi all, Nearly there now. Just the engine/prop assembly with propeller bullet deflector plates to do. Plus of course the pilot figure, Mike 9 Link to comment Share on other sites More sharing options...
Quiet Mike Posted June 16, 2021 Share Posted June 16, 2021 That's an amazing job. The build is excellent as always, but you've really brought that canvas and veneer to life. Link to comment Share on other sites More sharing options...
Sandbagger Posted June 17, 2021 Author Share Posted June 17, 2021 Hi all, The model is now finished. I'm just waiting for the display case to arrive. The last shot for posting is the pilot figure. The next shots will be the completed model, which hopefully will maybe at the weekend. As usual, thanks to everyone for their encouragement and comments throughout this build, Mike 5 Link to comment Share on other sites More sharing options...
Andwil Posted June 17, 2021 Share Posted June 17, 2021 Ah, the famous Belgian flying ace Hercule Poirot! Excellent painting, caps off a wonderful model. AW Link to comment Share on other sites More sharing options...
Sandbagger Posted June 18, 2021 Author Share Posted June 18, 2021 9 hours ago, Andwil said: Ah, the famous Belgian flying ace Hercule Poirot! Excellent painting, caps off a wonderful model. AW And he looks like he's adjusting his 'little grey cells' 😆 Mike 1 Link to comment Share on other sites More sharing options...
