Mike Posted May 13, 2021 Share Posted May 13, 2021 Mig-15Bis Update Sets (For Bronco/Hobby 2000) 1:48 Eduard This new tooling has popped out from partners Bronco and Hobby 2000 recently, and Eduard have been hard at it creating some detail improvements over and above what’s available in the box. Eduard's new range of sets are here to improve on the kit detail in the usual modular manner. Get what you want for the areas you want to be more of a focal point. As usual with Eduard's Photo-Etch (PE) and Mask sets, they arrive in a flat resealable package, with a white backing card protecting the contents and the instructions that are sandwiched between. Interior SPACE (3DL48016) Part of Eduard’s new range of combination 3D Printed decals with a pre-painted PE sheet to complement the details. The 3D Printed sheet contains a brand-new multi-part instrument panel with glossy dial faces plus a number of dials, additional instruments on the side consoles and a few more for the sidewalls. The PE set has a set of four-point seatbelts; rudder pedals with straps; a substantial change to the kit seat, which has the stirrups, side supports and headrest removed before adding new parts that are more accurate. The rear deck is skinned with a new part and the sills are lined too, then an opener is glued to the port side of the canopy. Seatbelts STEEL (FE1179) These belts are Photo-Etch (PE) steel, and because of their strength they can be etched from thinner material, which improves realism and flexibility in one sitting. Coupled with the new painting method that adds perceived extra depth to the buckles and other furniture by shading, they are more realistic looking and will drape better than regular brass PE. These belts are for use with the kit seat, a caveat you’ll understand better if you read the review of the SPACE cockpit set first. Masks (EX775) Supplied on a sheet of yellow kabuki tape, these pre-cut masks supply you with a full set of masks for the canopy, with compound curved handled by using frame hugging masks, while the highly curved gaps are in-filled with either liquid mask or offcuts from the background tape. In addition you get a set of hub/tyre masks for the wheels, allowing you to cut the demarcation perfectly with very little effort. Masks Tface (EX776) Supplied on a larger sheet of yellow kabuki tape, these pre-cut masks supply you with everything above, but also give you another set of canopy masks tailored to fit the interior of the glazing so that you can paint the interior and give your model that extra bit of realism. Mig-15 Wheels (648622) Kit wheels are generally in two halves, which means you have the resultant joins to deal with, possible mould-slip issues on single part wheels, and sometimes less than stellar detail due to the moulding limitations of styrene injection technology, especially in the tread department. That's where replacement resin wheels come in, with their lack of seamline and superior detail making a compelling argument. They are also usually available at a reasonable price, and can be an easy introduction to aftermarket and resin handling, as they are usually a drop-in replacement. This set includes three new wheels in grey resin, and a nose wheel leg in tougher white resin, plus a set of kabuki tape masks (not pictured) that makes cutting the demarcation between the tyres and hubs cleanly and with no fuss. Review sample courtesy of 1 Link to comment Share on other sites More sharing options...
