Operation Granby...1/48 Sepecat Jaguar GR.1A, RAF
The instructions call for adding nose weight but don´t mention how much.
Does anybody know if nose weight is really neccessary? Not much free space in the kit´s nose.
after a lot of sanding the nose halves are closed around the cockpit tub
btw, if you wanna display the canopy closed you have to remove a bit of the seat´s bottom or else the canopy won´t close
51189376558_cb26ca8684_b.jpgDSC_0001 by grimreaper110, auf Flickr
51189927209_90904accae_b.jpgDSC_0002 by grimreaper110, auf Flickr
51189376413_50fbd04fb8_b.jpgDSC_0003 by grimreaper110, auf Flickr
and here´s the front landing gear
51188454242_4706c3e7ef_b.jpgDSC_0004 by grimreaper110, auf Flickr
I had the same issue with my KH SuE. The gunsight and part of the coaming weren't letting me fit the windscreen, so they had to go.
Why didn't KH see that problem when building the prototype model?
Yours is coming along pretty well. Did you glue the nose weight?
 found a big screw that fit perfectly into the nose without fixating, has about 11g
the kit continues to be a PITA, and as far as I´ve read it´s going to be until the end
nothing really fits good, you always have to dry-fit the parts, lots of sanidng and cutting
added the IB cover and the gun covers, especially the latter ones didn´t fit good in the lower area
51199476353_4719ca3d27_b.jpgDSC_0004 by grimreaper110, auf Flickr
51200042369_07051e31f4_b.jpgDSC_0005 by grimreaper110, auf Flickr
the main landing gear is fun, part numbers in the instructions are mixed up or wrong so you have to be very attentive
51200042279_0f9855637e_b.jpgDSC_0006 by grimreaper110, auf Flickr
51199475978_7422ecec56_b.jpgDSC_0007 by grimreaper110, auf Flickr
my dad couldn´t look at the too high seat anymore
could loosen it again and removed some "flesh" from the bottom
51206318063_cbfe4c5a64_b.jpgDSC_0001 by grimreaper110, auf Flickr
51206110926_43492f55fb_b.jpgDSC_0002 by grimreaper110, auf Flickr
some detail with lead wire for the front gear
51206878999_74c45498b9_b.jpgDSC_0003 by grimreaper110, auf Flickr
engines
51206110691_3d1a697f3e_b.jpgDSC_0004 by grimreaper110, auf Flickr
51206317628_2e33fbb294_b.jpgDSC_0005 by grimreaper110, auf Flickr
and the rest of the fight continues too
51206110521_b5391e7da3_b.jpgDSC_0006 by grimreaper110, auf Flickr
also some detail added to the main gear
51206110396_1e5d86a063_b.jpgDSC_0007 by grimreaper110, auf Flickr
Looking great so far!
Modern excursion should be the Norm though uf you ask me :devil:
Be careful with the loadout! It is nearly entirely French or not suitable at all...incl. pylons!
really? Kitty Hawk messed that up too?
my dad´s mojo with this kit is already low, then I think he will put this kit aside soon....
should he do that, a Su-22 is already in waiting position 😉
  • Sad 1
Do not bin it!
Just be careful what you load it with!
Sure you have a full stash of appropriate weapons ;)
The pylon tips need to be made blunter as far as I understand, check some photos!
Granby meas overwing Sidewinders, 1000lb bombs or clusters on tandem pylons or directly to the pylon and a center tank + 2 ECM pods usually.
Not fully sure what it comes with oob  out of my head...
gaining more shape
51217925904_01c2d08e11_b.jpgDSC_0001 by grimreaper110, auf Flickr
51217925749_eb2a103417_b.jpgDSC_0002 by grimreaper110, auf Flickr
the kit is designed to keep all access panels etc. open, when you want to display all closed, it needs some sanding, cutting to make things fit
51217373798_e6d63f06ce_b.jpgDSC_0003 by grimreaper110, auf Flickr
fun to play with PE inserts, sadly no plastic part alternative
there are aftermarket exhausts from reskit but they cost between 16 an 20 Euros..
51217925529_c46cb482ec_b.jpgDSC_0004 by grimreaper110, auf Flickr
51217167451_75c0f82909_b.jpgDSC_0005 by grimreaper110, auf Flickr
oh wonder....the airintake parts don´t fit well either...
there are also aftermarket parts available
51217373498_6d593db6db_b.jpgDSC_0006 by grimreaper110, auf Flickr
First up, if you don´t already know it, Kitty Hawk/Panda Models are closing down, so if you still want some of their models, hurry up.
My dad didn´t give up....yet 😄
exhaust area painted metallic
interesting, one exhaust cover fits more or less, the other not so
51231150658_5b2dd0efb9_b.jpgDSC_0001 by grimreaper110, auf Flickr
51232004145_926b4a1ee0_b.jpgDSC_0002 by grimreaper110, auf Flickr
51230231397_018bfd0233_b.jpgDSC_0003 by grimreaper110, auf Flickr
51230231272_f1c420605d_b.jpgDSC_0004 by grimreaper110, auf Flickr
  • Sad 1
Sadly, some of Kitty Hawks detail was lacking. They did goo stuff i the detail but the instructions etc left something to be desired. I had shads of different departments fighting against each other!
It's a shame because they had in essence a lot going for them!
Colin
