Spitfire Mk.II Cockpit (648621 for Eduard) 1:48
1:48 Eduard Brassin
If you have one of Eduard’s new Spiotfire Mk.IIs in 1:48, this new resin set to upgrade the detail in the cockpit from excellent to exceptional.  The set arrives in the familiar shallow black Brassin cardboard box, and inside, protected by the folded instructions are three bags of resin and Photo-Etch (PE) that make up the set, as well as the aforementioned instruction sheets.
Within the bags are thirty-two resin parts, a sheet of nickel plated and pre-painted PE, a small decal sheet with instrument dials and placards, plus a small slip of acetate sheet with the shapes for the gun-sight glazing printed upon it in duplicate in case you lose one.  Clean-up of the resin should be done carefully with a scalpel or razor saw, and the casting blocks have been sensibly placed to help with this.  Give the parts a bath in warm soapy water (not hot, which might deform them), and they should go together like any other kit.
The instrument panel is made up from a lamination of three layers of PE and one of resin, one early, one late, with an optional resin only panel with decal if you don't like the printed PE.  This fixes to the frame through which the pilot's feet reach for the rudder pedals.  The frame behind his head is backed with a PE armour panel and head cushion, while the cockpit floor is made up by the addition of the rudder pedals and their linkages, the wing spar and other equipment.  The instrument panel frame slots into a groove in the floor, and the control column slots into the linkage assembly.  The pilot's seat is made up from a resin body, PE armour and connectors, with a resin frame, after which yet more PE is added to firm up the connections, adding adjustment handle and the prominent flare rack that sits under the pilot on the front lip of the seat.  The previously built-up frame is added to the floor along with the frame behind it, and the seat is installed on the small mating points along with its belts that slip through the framework.
Attention then turns to the sidewalls, which are based on thin resin skins that have much of the interior detail moulded in, with extra resin and PE parts added to complete each one, including the twin cylinders that typify early Spits.  Before they are added to the sides of the cockpit assembly, a little bottle on a rib is added between the seat and next frame back, after which you have a proper cockpit tub.  The upper sidewalls are detailed inside the fuselage with PE and resin parts, and once complete and painted, the assembly is placed within the fuselage halves.  The roll-over protection frame is outfitted with a resin bracing piece and added behind the pilot's head.  The resin and acetate gun sight fits to the top of the instrument panel, and you have a choice of two types, with circular or rectangular glazing.  A number of additional PE wires are inserted later from outside, and the placard decals that are provided are applied to the sidewalls during construction, with colour call-outs using Gunze codes throughout.
Conclusion
With careful painting you will have the ultimate cockpit for your Spit Mk.II, adding a fantastic focal point to your model.
Very highly recommended.
Review sample courtesy of
