I think I can squeeze this one in...
I have better decals than the Airfix contribution so I may use those.
The kit decals are excellent.  I'll save the fancy sheet for another day!
--John
Hi John,
Nice Choice, can never have too many Blunty's :thumbsup:
I built the Airfix one too  (seems like a life time ago now), still have
packed away in my collection
look forward to seeing yours progressing
Here's NZ6374 off your model box top
(RNZAF Museum - RNZAF Museum - Used with Permissions)
Regards
Alan
3 hours ago, JOCKNEY said:
Great stuff John
Best of luck with this one.
Thanks Pat.  I'll have to rename it a bit...I found some very nice resin pieces in the box and the kit decals are in excellent shape.
  • John Masters changed the title to Airfix BAC Strikemaster...almost OOB...
  • John Masters changed the title to Airfix BAC Strikemaster...OOB...as it should be!
Changed my mind again!  After looking at the box contents and then the calendar, I figured, 'Why not?'  Straight OOB it shall be!  None of this fancy resin or whatnot from foreign parts.  Goode olde English mouldings...
Bag o' stuff...
Nifty decals...
I'll jump in tonight!
--John
36 minutes ago, Corsairfoxfouruncle said:
One of these are on my wants list
OK.  Just so you know, I found my first surprise.
The cockpit area is fine...
Looking ahead to the next stage, I decided to clean up the fuselage halves.  I discovered this...
Funny looking rudder...looks like they ran out of plastic.  I guess I will have to use a little plasticard to fix it up.  I hope that's the last of the 'surprises'.
--John
  • Sad 3
The basic cockpit will suffice.  I'll give it some Sea Grey afterwards and pick out the IP dials with a hairy brush and black.  This is what i have seen images of, at least.
I also did the nose lights.  Note the piece of lead for the weight. I did not forget it this time!
The rudder fix...Instead of connecting the card piece to the odd shaped rudder, I attached it to the positive piece and it fits like a puzzle.
Once the fuselage halves are one, I will use some Milliput to fill in the remaining gap and sculpt any detail.
--John
Those two fuselage halves with different shaped rudders looked like they came from two different kits for different variants. I must have a look at the kits I’ve got tucked away!
That's what I thought.  Every profile I have seen is the same...the larger rudder is correct.  I think they ran out of plastic.
  • Sad 1
7 hours ago, Andwil said:
Nice idea for fixing the fin/rudder problem.
Thanks AW.  When the time comes I will try to photograph a play-by-play of the repair/puttying.
For what it's worth...play by play...
A ball of Milliput and the problem...
The solution begins.  I will let that dry overnight and then sand and sculpt a bit and fill with PPP if needed.
And some other building.  This is really a lemon of a kit.  Poor moulding, weird, small gaps...It will require a fair amount of filler and fettling to achieve the desired result.
Still, it is looking alright as a labor of love.  I have the more recent Airfix Jet Provost and I will build that eventually.
--John
8 hours ago, Corsairfoxfouruncle said:
True but that's what modeling is all about isn't it.
I agree.  It's always a good reminder that not all kits are designed by Eduard...
1 hour ago, John Masters said:
Does that rear bit need a mask?
Hi John.
Looking really good :thumbsup:
To help answer your query, a some photos of various RNZAF Strikemaster canopies
NZ6376
OhC130-86_1_1.t600f2a96.m600.xeEDX3vSp.j
(RNZAF Official - RNZAF Museum - Used with Permissions)
NZ6373
NZ6366
Hope that helps you?
Regards
Alan
I am using some of the Vallejo US Vietnam Era paint scheme.  It has a nice light grey, dark green, light green and tan.
The light grey underside...
--John
