Hi all
Seat made and painted in humbrol metal cote polished aluminium and a Milliput cushion. The seat is just resting in place to gauge Seatbelt length.
Seat belts under construction,  these are the lap belts so far.
Thanks for looking in
Chris
  • Like 13
Lovely work Chris!
This is coming on a treat Chris, those lap belts are going to be fantastic. Looks like you're having a lot of fun detailing this kit. I'm certainly enjoying seeing it take shape.
Richie
1 hour ago, AliGauld said:
Nicely done.
Serious eye strain inbound?
Alistair
Thanks Alistair.  Crikey, your not wrong there.
57 minutes ago, Dunny said:
Lovely work Chris!
Thanks Roger, very kind fella .
Richie
Thanks Richie,  very kind.  I am enjoying it  I have to say,  nearly ready to button up.
Tamiya Masking tape covered the PE bits
Painted
I have decided to do the earlier style lap belts
Very pleased with this so far, just the joystick to go in, then close up.
Chris
  • Like 11
Cockpit finished, wahoo, very pleased with this.
Fuselage is now buttoned up and the lower wing fettled ready to fit.  I have had to use CA and Talc to fill parts of the fuselage and will rescribe the panel lines as yhe raised ones were destroyed when joints sanded. I will finish tidying up later and move onto the wing hopefully.
Chris
  • Like 13
  • Thanks 2
Terrific work on the interior Chris, you have every right to be pleased with your work.
Richie
Richie
Thanks Richie  that means a lot fella after your amazing work on your scout, thanks
Chris
Hi all
Panel lines removed using my home made micro chisel.  Rivets retained and panel lines rescribed, lower wing on and fuselage struts fettled and added.
I can't seem to put this one down
Chris
  • Like 16
Looking lovely Chris - good to see that all that work in the cockpit will still be visible,
Roger
Roger
Thanks Roger,very kind fella and very much appreciated , yes it's quite a wide appeture.
Chris
Hi all
Not much progress as I had a night off last night but did get the upoer wing cleaned up after work yesterday  and assembled.
Here it is on my home made high tech jig
And here it is dry fitted to the model
Not too bad at all.  It is sitting square too so pleased with this.
The rigging holes are already present just got to do some control cable holes at the rear end and the tailplane  can be assembled and the air frame can then be painted.  Really enjoying this old  kit,  I also have the Bulldog, Gladiator and Fury too.
Chris
  • Like 11
Nice work Chris - jig is probably stretching it a bit 🤣
Roger
Roger
😄 Yes I think you are right there Roger .  Thanks fella.
Chris
Nicely done. Jig works for me but then I though Heath Robinson was a brilliant Engineer.
Alistair
  • Haha 2
4 minutes ago, AliGauld said:
Nicely done. Jig works for me but then I though Heat Robison was a brilliant Engineer.
Alistair
Thanks Alistair , yes very  Heath Robinson , I do have a wooden jig but it has a half finished Camel on it, so the home made version it is !!!
Chris
Hi all
Some further work, undercarriage legs and struts cleaned up and assembled.  Had a short shot front stay on the Port side so used brass tubes and a bit of plastic rod to sort out
That's it for today, I am off for a kip.
Thanks for looking
Chris
  • Like 12
Good rectification work there Chris - a fiddly looking assembly too!
Roger
Roger
Thanks Roger,  yes bloomin fiddly and that was almost my whole modelling session last Night!!!
Chris
2 hours ago, Team Aer Lingus said:
Outstanding work so far Chris very impressive keep up the good work  mate
thanks for sharing
Eamonn
Thanks Eamonn,  very kind of you fella, I am enjoying these.
Chris
