Another beauty Chris - I'm really liking your series of Naval aircraft builds
Thanks Chris, very kind, got loads of FAA builds to do still.
Chris
On 4/27/2023 at 4:38 AM, AliGauld said:
Looks absolutely splendid.
The paintwork is up to your usual sublime standards.
Yes that goes for me too.  Just take as read my usual praise for your brushwork, Chris ;)
Thanks Steve, that's really kind of you.   Getting exciting now as getting towards the finish of this one.
Just got to be careful not to break  any bits off now😬
Chris
11 hours ago, mark.au said:
I can hear that Hurricane's engine start...
😄 nearly there now Mark.  Pleased with it , every time I pick it up I am worried that I will damage it now due to all the sticky out bits.
Hi all
Further progress on the Sea Hurricane
I put a matt varnish (Windsor and Newton) and it went glossy, even after a long shake in the bottle, a tad annoying.
The undercarriage bay doors have been cut down, I could only find one photo  so it may be correct or incorrect ?
The Vacform sliding canopy section was cut and the photo etch handles added inside, exhausts added too.
Thanks gor looking in
Chris
  • Like 13
11 minutes ago, bigbadbadge said:
a tad annoying.
Just a bit  - I've had that happen when spraying the stuff too Chris.....
Hopefully another coat may kill the shine.
Keith
Keith
Crikey, that is annoying Keith, just when you think your getting to yhe finish!!!🙄 I did try a second coat and it reduced a bit, I will wait for 24 hours to try again , if that doesn't work will try some Humbrol matt varnish. Fingers crossed 😉
Chris
A bit more on the Corsair too, finished the main painting and now ready for some decals.
Doesn't look too bad.
Thanks for looking
Chris
  • Like 11
Chris,
Nothing more frustrating than a matt coat that isn't... matt 😡 I'm sure if you try again all will be fine. Hurri and Corsair are both looking lovely,
Roger
The gloss matt varnish must have been highly annoying but the model does look excellent. You'll soon have the finish sorted out.
Richie
9 hours ago, Dunny said:
Chris,
Roger
Thanks Roger, yes very annoying will give it another coat later today and see what happens, so fingers crossed.
Richie
Thanks Richie, yes definitely annoying,  however, will see how another coat goes later.  If it does the same will have to switch to enamel varnish.
Thanks guys
Chris
No it looks flippin' great! I like the different shades on the wings - nice touch!
Wasn't too bad tbh Chris, I just re-sprayed with a laquer varnish I knew would work, I just wanted to use the W&N to avoid the smell....!!
K
K
Thanks Keith, I am quite pleased with the Corsair, will get the decals on and see how it looks then.
Ahh yes, I see what you mean , I am so used to the smell of the enamels I don't notice it, I've gone noseblind😉
Chris
Looks good Chris,
I've never had a problem with their varnishes.
That must be a tad annoying.
The Corsair is looking excellent.
Alistair
3 hours ago, AliGauld said:
Looks good Chris,
Alistair
Thanks Alistair,  the Corsair now has decals and quite pleased with it.  Yes it is a bit frustrating,  however it's only a model I suppose.  I have got it to more of a satin finish now, but may try some Humbrol matt on a small area to see how that goes, fingers crossed
Chris
I’ve just had the same when spraying Tamiya lacquer matt clear (over a previous coat of semi-gloss).  Hoping that a second or third light coat will fix it.  I hate that with Matt clear coats.  Yet to find a 100% reliable one.  Thought I had with the Tamiya lacquer,
Have to say that the Hurricane is looking marvellous; that vacform canopy is a fine addition.
Thanks Steve , yes it is frustrating,  I hope the next coats work.  I have gone over it with Humbrol enamels matt varnish and it is slightly more matt now so might try a second coat of that later on as well.
I nearly screwed up the vacform canopy but have just about got away with it, just painting the framing  now.
Thanks
Chris
Hi all
I have very nearly finished the Sea Hurricane with the prop added, canopy added, some chipping and exhaust staining,  still got to add the carb air intake grill and aerial wire and matt varnish the fabric section of the fuselage. I managed to get the rest of it matt varnished again after two coats of Humbrol enamel varnish I went back over it with the Windsor and Newton Galeria matt and it worked thankfully.
Last images of this one before an RFI thread.
The Corsair has all the decals on, not many thankfully as always ground Revell decals quite unyielding but they weren't too bad.
Now got to start weathering😬
I still have one of the Seafires to complete, not sure whether to continue with the Seafire III though as the wings are a bit untidy for me and slightly smaller than the wingroot area so will consider my options there.
I will be doing the Nimrod and some non FAA projects, the cockpit of one of them, an RAAF machine can be seen in the last Hurricane image.
Thanks for looking
Chris
  • Like 15
That's a proper matt finish on the Sea Hurri. I knew you would achieve a perfect finish after the initial varnish didn't work out. Those are great exhaust stains, very convincing.
Corsairs, to me, are among the funkiest of WWII fighters. Yours is looking fab, a perfect canvas for your well honed weathering techniques.
So many builds going on, can't believe the mojo got misplaced a few weeks back!
Richie
Richie
Thanks Richie, finally got the matt to work,  the staining is Humbrol weathering powders.  I just hope I can weather the Corsair now😬 , I think the issues with the Seafire conversions and the Hurricane drained the Mojo, but it's back.
Thanks
Chris
Great stuff, Chris.  The flat coat stage of your builds is always the moment they cease to be plastic models and become quality replicas, they get their identity so to speak. Looking forward to the Corsair taking on its persona soon.
Thanks Mark,  love this part all the work comes together and the flat coat ties all the paint together nicely.
, although the RAAF build coming up will be slightly glossy!!! Fingers crossed the Corsair weathering goes well😬
Chris
Waow, waow waoooow !!
Congratulations Chris !!
I really love the Corsair !!
The Sea Hurri is a beauty too !!!
I stay in :gobsmacked::gobsmacked:
Can't wait to see the RFIs
Sincerely.
CC
