FrankJ Posted May 1, 2021 Share Posted May 1, 2021 Ive never airbrushed metallic paint before, is the metallic flakes ok spraying through H&S infinity, I have a 0.4mm nozzle set and a 0.6mm nozzle set? Ill be using Tamiya paints. Link to comment Share on other sites More sharing options...
dnl42 Posted May 1, 2021 Share Posted May 1, 2021 It depends on the paint. Having written that, i generally airbrush metallic paints with my 0.5mm nozzle. I only airbrush metallic paints with my 0.3mm nozzle for very small parts. Bottom line, try it out. But try the 0.6mm first. Link to comment Share on other sites More sharing options...
bmwh548 Posted May 1, 2021 Share Posted May 1, 2021 I use the 0.4 set. It's more than adequate for metallics. Maybe make the mix just a bit leaner than a normal one though. I haven't sprayed Tamiya metallics in ages, but the flake in the normal acrylic range used to be a bit big compared to other manufacturers. I understand that their lacquers are far better in that department. Link to comment Share on other sites More sharing options...
treker_ed Posted May 1, 2021 Share Posted May 1, 2021 I use a 0.35 needle/nozzle and mainly use Tamiya acrylic paints. Provided they are thinned enough, a 0.4 should be more than adequate. I would say a ratio of at least 60/40 thinner/paint with several light coats to build up the colour should do the trick. For the majority of my metal colours, I tend to use either Vallejo metal color acrylic or (now discontinued) K-Color. These were imported by Model Innovations, but the Italian manufacturer has now discontinued them, so I stocked up on them from the importer last year, so I have enough to last for a while. Link to comment Share on other sites More sharing options...
Ratch Posted May 1, 2021 Share Posted May 1, 2021 Just put the paint in and spray. Link to comment Share on other sites More sharing options...
