MASSIMILIANO Posted May 1, 2021 Share Posted May 1, 2021 Hi Guys, After building a Mitsubishi P Zero I thought the moment to build his bitter enemy was arrived. The Eduard model is very well designed. All the model is out of the box a part from the seat belt. I didn't have any problem to build the kit even with horrible instructions. After brushing paint the model (as all my models), I tried to use Tamiya Panel Lines to highlight the details. The results did not satisfy my taste and for this reason I used Tamiya Weathering Master, along the rivets to create a shabby effects. I also added a bit of chipping along the wings and canopy. The worst part was the antenna. I struggled with SuperAttack. Next time I will some sort of accelerator to avoid gluing my fingers instead of the part. I hope you like the results of my work. Thank you for your feedback, 18 Link to comment Share on other sites More sharing options...
rob85 Posted May 1, 2021 Share Posted May 1, 2021 Looks brilliant! Looks even better when I turn my phone upside down 😃 you may when to look at rotating your pictures before posting 👍🏻 Rob Link to comment Share on other sites More sharing options...
dnl42 Posted May 1, 2021 Share Posted May 1, 2021 Nice work! And, it's always good to see Grumman aircraft! The photos looks fine in Chrome. Link to comment Share on other sites More sharing options...
shortCummins Posted May 1, 2021 Share Posted May 1, 2021 look good however upside down in Safari Link to comment Share on other sites More sharing options...
redcap Posted May 1, 2021 Share Posted May 1, 2021 Really nice build and the Sea Blue looks spot on. For the antennas, try using 'E-Z Line' or knitting in elastic which is so simple to use, holds and 'grabs' immediately with a touch of superglue and stays taut permanently. Much better that trying to use fishing line or similar. Gary Link to comment Share on other sites More sharing options...
MASSIMILIANO Posted May 2, 2021 Author Share Posted May 2, 2021 Thank you for your comments and tips.Really appreciated Link to comment Share on other sites More sharing options...
