MiG-25PU Soviet Training Aircraft (72178) 1:72 ICM
Julien
1:72 ICM
In the early part of the Cold War, the strategic bomber was seen as the obvious means by which to deliver a nuclear payload. The interceptor - large, heavy and fast - was seen as the equally obvious countermeasure. The MiG-25 Foxbat was, in many ways, the ultimate embodiment of this technology. It wasn't particularly groundbreaking and nor was it particularly sophisticated, but it was capable of incredible speed and could carry four large missiles to high altitudes very quickly indeed. The MiG-25's shortcomings as a combat aircraft were largely addressed through the MiG-31 Foxhound, but the type continued as an effective mission platform in a variety of guises. The PU version being the twin seat trainer for the interceptor version of the Foxbat, though with no radar or armament it was purely a flight trainer.
The Kit
This kit is now the sixth iteration of ICM's new 1/72 MiG-25 family, following on from the other variants. Inside the robust top-opening box are eight frames of light grey plastic and two of clear plastic. The kit is almost identical to the previous iterations, but includes revised parts for the nose (The interceptor nose is also included but only for the pylons which are also on the sprue). The airframe is covered in crisp, recessed panel lines which look very good indeed, and the mouldings are crisp and clean. The instructions are an A4 stapled booklet which has been printed in colour and the decal sheet is clear and well printed. The overall impression is of a well-executed, modern kit which looks like it should be thoroughly enjoyable to build.
Construction begins with the rear cockpit and nose gear bay. Some detail is moulded in place on the sidewalls of the cockpit, with extra parts provided to represent additional details. Before the main structure of the cockpit can be completed, however, you have to add the bulkhead that forms the front wall of the cockpit and the rear wall of the nose gear bay. The instructions have you installing the nose gear leg at this stage, but I can't see any logical reason as to why this can't be done at the end. This would, of course, save you from breaking the leg part way through the build. The cockpit itself is nicely detailed, with the ejector seat alone made up of no fewer than five parts. An instrument panel and control column completes this section. Once the forward fuselage halves have been joined together, the whole sub-assembly fits onto a spar that also holds the huge engine air intakes. I've noticed that kit manufacturers are moving increasingly toward this style of construction, where certain parts are provided for purely structural purposes instead of the older slot and tab style of construction. I guess the main advantage, other than strength, is that everything can be positioned at exactly the right angle - a helpful feature for kits that feature quit a complex breakdown of parts such as this one. Each engine intake is full-length, with engine compressor faces provided. What results is a complete forward section of the aircraft up to the wing roots, with the internal structure of the air intakes protruding from the rear. The lower face of the main fuselage can be joined to this structure once the main landing gear bays have been added. ICM suggest that you add the main landing gear legs at this stage. Again, I can't see any reason why they couldn't be fettled into place after the main construction has been completed.
Once the lower face of the main fuselage is in place, another structural bulkhead can be added, after which the slab-sides of the fuselage, including the outer faces of the air intakes, can be added. The dustbin-like jet exhausts are added at this stage, and very nicely detailed they are too. Once in place, the upper face of the fuselage can be added. Some modellers have noticed that the central spine has a flattened profile instead of a rounded shape. This is true, but I imagine most modellers will choose to live with this flaw. All that remains now is to add the nosecone, flying surfaces and finishing details. Each vertical tail is split vertically, with a seperate rudder. The outer face is moulded with part of the rear fuselage in place, so presumably it will be impossible to fit these parts at the wrong angle. Somewhat surprisingly, the upper wings are not moulded in one part with the upper fuselage. Instead, they are split into separate port and starboard halves, with two separate flaperons and upper wing fences and fittings. The nosecone is simply split vertically and houses the front cockpit. This is made up and added in along with its rear bulkhead, Once closed up the completed nose section can be joined with the rest of the fuselage. The canopies are nice and clear and can be finished in either open or closed position. Even though the wing tip missile rails are present no armament was used, and plugs are provided for the underwing pylon spaces as well.  Other than that, and a few aerials, lumps and bumps, the huge aircraft is now finished.
Decals
Four options are provided for on the decal sheet:
  • MiG-25PU Russian Air Force, Ramenskovsky (Zhukovsky) (UUBW) Russia August 2005
  • MiG-25PU Russian Air Force, MSN N22036241 Russia August 2012
  • MiG-25PU Belarus Air Force, MSN 22037313 1983
  • MIG-25PU Libyan Air Force, Mitiga, Libya Dec 2006
The decals look nicely printed and a full set of stencils is included.
Conclusion
We've waited a while for a new, more more modern kit of the Foxbat in this scale, but the wait has been worth it. ICM's effort is excellent, with high quality mouldings and plenty of detail. Overall this is a well executed and carefully designed kit, while the trainer configuration is very appealing indeed. Highly recommended.
Available in the UK from importers H G Hannants Ltd.
Review sample courtesy of
