Julien Posted April 30, 2021 Share Posted April 30, 2021 F-4 Phantom Centre Line Pylon (HMR48035) 1:48 Hypersonic Models The F-4 is usually seen with .a fuel tank on the centreline fuel tank or other store. Four large stabiliser bolts fit the pylon to the airframe (Spare are provided for these as you are bound to loose at least one to the carpet monster). As well as the pylon the set comes with separate sway brace pins so the modeller can fit them. Conclusion One thing common to a lot of F-4 kits is that they expect the modeller to use stores, however many phantoms flew without them. This set remedies this omission. While designed for the ZM kit there is no reason they can not be used on other kits. Jeffrey's attention to detail is legendary, and it shows in every set he makes. Highly recommended. It is a also worth noting that Jeffrey has gone through the time consuming process to register for UK VAT so there are no issues for UK modellers ordering direct. Review sample courtesy of 1 Link to comment Share on other sites More sharing options...
