Finemolds and Hasegawa 1/72 F-4E Phantom II - the Long Nose saga
On 24/08/2022 at 23:33, keefr22 said:
Another excellent update G, I particularly like your mod to the droptanks and the nose leg details, but good stuff all round!
K
Cheer Keith, thank you - much appreciated :thumbsup:
On 25/08/2022 at 14:28, Spookytooth said:
Great work Giorgio, nice mod on the drop tanks.
And you are right, some P.E. does not look right.
Stay safe.
Simon.
Thanks Simon, glad you like it :thumbsup:
On 25/08/2022 at 14:37, VT Red Sox Fan said:
G, just catching up—really learned a lot from the canopy saga—it turned out great!  I think you made the correct choice on the kit antennas vs PE—even on the WW2 aircraft in 1/72 they can look a little flat—best, Erwin
Agreed on 1/72 PE antennae, Erwin - thanks for the praise! :thumbsup:
On 27/08/2022 at 00:04, The Spadgent said:
Yes. My one has gone exactly the same. It’s almost as if the chrome has curdled. No longer smooth like a mirror but split Ito a strange emulsion of oil and silver bits.  Feels like time has degraded it. Like me. 🤪
The details are looking spot on regardless dear boy. 100% fantastic.
Johnny
So it's not only me, thanks :D And thanks for the praise :thumbsup:
On 30/08/2022 at 21:52, gota said:
The ink within the tip goes bad, pull the tip out and you should find some working ink, you'll see the difference in consistency.
So I did, and in fact the ink inside appeared to be intact. As a matter of fact, I picked some up with the point of a toothpick and laid it down onto some scrap plastic, and it was the usual chrome effect. I noticed that the tip area instead was all filled with the "altered" ink: I wonder if there's a way to clean that out and restore it to normal service...
Anyway, thanks a lot for the tip (see what I did? Oh, well.... :D )
On 30/08/2022 at 23:37, Mark Turk said:
Amazing work!
Mark
Thank you Mark :thumbsup:
On 03/09/2022 at 13:02, Fritag said:
Lovely (of course) detail work G.
Glad you approve of, Steve :thumbsup:
Slowly progressing: the main wheel hubs aren't painted white (just the outer rims). They are instead left in metal; so I used the brush technique to paint them with Model Master Metallizer Burnt Metal
hase_wheels1
I then cut some masks with my Curio out of Oramsk 810
hase_wheels2
Main struts prepped and relevant PE added
hase_uc11
Then I had all these bits ready for painting
bits1
and this, which was airbrushed with MMM Burnt Metal, and buffed a few minutes afterwards
hase_arrestorhook1
All the other bits received a black base coat (Tamiya Flat black, thinned with cellulose thinner, to improve the "bite")
bits2
I then airbrushed Tamiya Flat White on the parts that needed it, such as the wheels
hase_wheels3
The masks didn't quite work on the back side
hase_wheels4
So I had to repaint those by brush. Here they are after some brush painting and weathering
hase_wheels5
Same for the front wheels
hase_wheels6
They are all in need of the final flat clear coat, but I wanted to let the black tempera wash cure thoroughly
White (and some red) on the other bits
bits3
bits4
Followed by the darker camouflage color
bits5
The arrestor hook side plates received a coat of AK Extreme Metal Steel, instead
hase_arrestorhook2
The pylons received some detail painting (launching rails, Italeri Steel by brush) and a black temepra wash
hase_pylons2
They too need a final flat coat (unless there are stencils to put on, I haven't checked yet....)
The little front door instead is completed, flat coat included
hase_uc12
Finally, a gratuitous shot of the whole AC, just because.... :D  (actually I did paint the small dorsal light on the hunch)
hase_detailpainting5
That's it for this update, all comments welcome
Ciao
Edited by giemme
Premature posting
  • Like 24
Well you certainly know how to slosh paint around Giorgio - nicely sloshed too.
I particularly like your aircraft crash diorama where all the bits of aircraft have miraculously ended up on the top of trees that seem to have had all their branches burned off. Very surreal.
  • Haha 9
Cheers Alan, thanks! :thumbsup:  BTW, that is called "parts tree", so I removed them from one tree, just to have them ending up on another... :frantic:  :D
On 05/09/2022 at 08:08, Fritag said:
Nice bits Giorgio 👍 (now why am I uncomfortable with that phraseology? )
Don't know. But there's more bits, see below... :rofl:
On 05/09/2022 at 14:19, Spookytooth said:
A lot of paint going on mate.
Busy, busy.
All looks good from here mate.
Stay safe.
Simon.
Cheers Simon, thanks! :thumbsup: Yet more painting in this update, see below
On 05/09/2022 at 20:10, keefr22 said:
Cracking paint G, looks really good!! :thumbsup:
K
Glad you like it, Keith! :thumbsup:
On 05/09/2022 at 20:15, TheBaron said:
That's alright that is. Like the parts are beginning to swarm for final assembly all on their own. Lovely progress G.
Thank you Tony :thumbsup: Although it feels like a never ending story each time I get to this stage of a build...
On 06/09/2022 at 20:50, rob85 said:
Been away for a bit, glad you didn’t finish before I get back to it!
that paint work is looking brilliant, and it looks like another leap forward is on the cards with all the little bits prepped.
Rob
Not a chance to finish it so soon, Rob :D See more bits prepping below :winkgrin:
On 07/09/2022 at 00:26, VT Red Sox Fan said:
I particularly like how the dark grey appears a little “splotchy”—very appropriate for this aircraft and era—well done, Erwin
Thanks Erwin, that was the idea - glad you like it! :thumbsup:
On 07/09/2022 at 00:51, The Spadgent said:
I love getting to this part of the build where all the bits get finished off. Excellent painting as always.
J
Me, not so much. End in sight but never quite there :frantic:  :D And thanks! :thumbsup:
Alright, here's a 10 days worth of update, albeit I didn't manage that much time at the bench. I've been working on two main subjects. The first, bits that still needed painting; starting with painting chrome the various oleos - I was able to use the paint from the inside of the Molotow Chrome pen, and applied it by brush
bits6
The light in this pic is quite unfavorable, they look way more even and shiny in real life.
It was then time to paint the exhaust cones and cans; first off, Model Master Metallizer Burnt Metal, airbrushed on the turbine faces and the pipes rear ends (and buffed after a few minutes)
hase_exhausts1
Then the cans, airbrushed with MMM Exhaust inside and out (and again, buffed a few minutes afterwards)
hase_exhausts2
The inside of the exhaust pipes on an F-4 shows a typical color pattern, from dark grey to very light brown to very light green, so I masked the metallic area using rolled up post it notes
hase_exhausts3
I then airbrushed Tamiya German Grey
hase_exhausts4
moved up the masking and airbrushed Tamiya Deck Tan
hase_exhausts5
moved up yet again and sprayed Tamiya Sky
hase_exhausts7
The same color was sprayed inside the innermost part of the cans
hase_exhausts8
End result
hase_exhausts9
hase_exhausts10
For the cans, I tried to replicate the discoloration caused by the heat, by drybrushing a couple of shades of grey (dark grey and dark gull grey, to be exact, both Lifecolor) and a black and a silver pencil, all followed by a black tempera wash
hase_exhausts11
The inside for both pipes and cans received a black tempera wash
hase_exhausts12
They are now ready for final assembly (which I have already started, but I'm going to complete probably by tonight)
The other subject I worked on, is......  decals! :frantic: :frantic:
First off, the slime lights: these came from an old Hasegawa decals sheet, kindly donated by @phantom61. I wasn't sure how they'd perform, but I have to say they were flawless
hase_decals1
hase_decals2
Then I wanted to test the HI-DECAL LINE decals that I bought for this subject; so I started with a couple of stencils on the stabialtors
hase_decals3
They are very thin but resistant, and apparently show the carrier film after application, but once gloss coated...
hase_decals4
... no more traces of it whatsoever.
So I pressed on and tried with larger decals
hase_decals5
hase_decals6
All good there too, and not gloss coated yet, so I expect those to blend in properly too. Alright, that's it for this update, I'll get back to the bench for more decals action!
All comments welcome, as usual
Ciao
Edited by giemme
Typos
  • Like 28
12 minutes ago, Fritag said:
Lovely neat work, Giorgio.  Doesn’t just survive the unforgiving macro photography; it positively revels in it :D
Agreed.
Quite remarkable. If I can use such a superla-....err, I mean such a straightforward statement of fact.
  • Haha 6
Nice work on the exhausts! On mine, I think I just painted everything Burnt Iron (or was it Burnt Metal?). I may go back and do some more work on them, per what you've done, since I haven't even glued them into my F-4E yet. I'm just now trying to finish up my white painting, so I'll check what you've painted white to see if I've missed anything.
Regards,
Jason
On 18/09/2022 at 19:05, Terry1954 said:
Nice update Giorgio. This one is coming along very nicely and I assume it's Greek colleague is still ok? Not seen that one for a while.
Terry
Cheers Terry, thank you :thumbsup:  I decide I want to complete this one before going back to he HAF one :)
On 18/09/2022 at 20:48, keefr22 said:
More very nice work G - that method of masking/painting the interior of the exhausts is brilliant! As is the result!
Toom is looking very Toom like - great stuff! :thumbsup:
Keith
Thanks Keith, much appreciated! :thumbsup: The post-it note masking is something I must have picked up online somewhere, I can't remember though...
On 18/09/2022 at 20:52, Cookenbacher said:
That's brilliant - stealing this one immediately Giorgio - yoink!
The exhausts (and everything else) look fantastic!
Steal away, Cookie - as I said above, it's what I did too :winkgrin:
Way too kind, Steve :thumbsup:  To be honest, at normal viewing distance it all looks much better :)
On 18/09/2022 at 22:02, TheBaron said:
Agreed.
You can, of course :D :D  Thanks tony :thumbsup:
On 18/09/2022 at 23:43, corsaircorp said:
Soo, this Phantom is a Devil ??
Well done Maestro !!
Note to self; I must resist the envy to start (restart) another Phantom....:devil::devil:
Sincerely.
CC
Why resisting? Have you gone insane? Or should I say sane? :rofl: :rofl:  Thanks Alain! :thumbsup:
On 19/09/2022 at 00:13, The Spadgent said:
The pressing work on the exhausts is a master stroke. They look great. And I know how much you like decals so I didn’t expect those to be much of an issue. 🫠🤫🥳
 Great stuff G.
 Johnny
See below for decals, Johnny... I still hate them... Thanks for the praise, though :thumbsup:
On 19/09/2022 at 10:04, mark.au said:
Lovely paintwork, a joy to follow along with
Thanks Mark, although I very much envy your paintwork :thumbsup:
On 19/09/2022 at 13:07, hendie said:
a fine job sir. Those markings look very nice and really bring the airframe to life.
More markings below, Alan - in fact, all of them :winkgrin:
On 19/09/2022 at 17:53, billn53 said:
Fine work on the afterburner cans! I'll take a note on your technique, for future reference when I build my next F-4.
The stenciling and decaling look great, as well!
Cheers Bill, thanks! :thumbsup: I have a few very neat pics of F-4E burner cans, I just tried to replicate what I saw. In a bigger, scale, there would be room for some interesting effects  - to be achieved with an airbrush. For 1/72, I'm happy with the way they turned out, considering the normal viewing distance :)
Regards,
Jason
Thanks Jason, glad if I can be of any inspiration :thumbsup: I've probably already asked you, but have you posted any WIP of your build?
Time for WE progress report, gents. Let's see through the end of the exhausts job, shall we? I inserted the PE afterburner rings and glue in the turbine faces
hase_exhausts13
I then glued on the cans
hase_exhausts14
I added a bit of blue pastel along the petals (not very visible here, it's more of a shading) and sealed everything by airbrushing a flat clear coat (W&N Galeria)
hase_exhausts15
Before going back to the model and its decals: remember the canopies? I masked them (cutting files for my Curio kindly supplied by @Gene K) inside and outside
hase_canopies1
hase_canopies2
I then airbrushed them with Tamiya Flat Black, followed by Lifecolor FS36118 Dark Grey only on the outside
hase_canopies3
hase_canopies4
Finally, they received their stenciling (here's only one side of the front canopy, they all look the same, believe me :D )
hase_canopies5
The decals on the main model took four sessions to be posed; port side completed first, with the specific airframe markings
hase_decals7
I was pretty happy with the first half shark mouth
hase_decals8
Laying it down, however, wasn't trouble free: the eye separated from the rest of the decals, but luckily didn't curl up or anything, so I was able to place it properly. But that taught me to cut it out in advance from the other half decal :winkgrin:
Top view
hase_decals9
Starboard main decals done too (that was session two)
hase_decals10
Shark mouth posed sans the eye, which was added later - this went a lot smoother than the other side
hase_decals11
I even managed to align the two halves properly:
hase_decals13
Well. almost...
hase_decals14
Not much going on underneath, as far as markings were concerned
hase_decals15
The only main decal that actually gave me trouble was the fin top one; a bit of the yellow strip came out during handling
hase_decals12
So I fixed it by brush and gloss coated (the whole fin, actually) to avoid any further troubles
hase_decals16
Then it was time for stencils: not the usual myriad of the small blighters, but some if them broke in two while removing them from their backing sheet. I found out that they need to be dipped for far less time than what I usually do; 20 seconds is more than enough, in warm water. After I realized that, it was all downhill - but it took a while to.... :banghead:
Anyway, bottom stencils (again, not much going on there)
hase_decals17
and top ones
hase_decals18
hase_decals19
A few others went onto the main U/C doors, but I'll spare you since they are not that interesting. Now I only need to gloss coat it and then weather it, before the final assembly.
There are, however, still a few bits that need painting:
- nose pitot
- air intake sensors
- canopy lifting arms
- speed brakes actuators - actually, I still need to scratch build these :)
Let's not forget the ordnance: according to the paint and decal scheme that came with the HI-DECALS set, this airframe was used in the Air Defense role, so it should be equipped with AIM9 L or P - I'll have to rummage through the weapons stash... :frantic:
Next time, though; for now, all comments welcome.
Ciao
  • Like 21
hase_exhausts13
hase_exhausts14
hase_exhausts15
hase_canopies1
hase_canopies2
hase_canopies3
hase_canopies4
hase_canopies5
hase_decals7
hase_decals8
Top view
hase_decals9
hase_decals10
hase_decals11
hase_decals13
Well. almost...
hase_decals14
hase_decals15
hase_decals12
hase_decals16
hase_decals17
and top ones
hase_decals18
hase_decals19
- nose pitot
Ciao
Hello Mr G,
I think that I still have some 'winders from an Hasegawa armament set...
So if you need it, I'll take a look
See, decalling is funny.... :dull::dull:
I love that sharmouth and angry eyes....
Sincerely.
CC
