mark.au Posted August 9, 2022 Share Posted August 9, 2022 12 hours ago, Fritag said: PE + resin + UV = success. By the looks of things. Don’t want to encourage you to go pinging-off the etch or owt G - but how secure is the bond do you think? compared with say gator’s grip and cyano. Asking for a friend….. Tell your mate that he need to be thinking more about painting than resin… Fabulous work on the Phantom, the paintwork is exquisite. 8 Link to comment Share on other sites More sharing options...
corsaircorp Posted August 9, 2022 Share Posted August 9, 2022 Well done Mister G !! The canopy is amazing !! Great surgery indeed !! Sincerely. CC 1 Link to comment Share on other sites More sharing options...
PlaStix Posted August 9, 2022 Share Posted August 9, 2022 Hi Giorgio. Hope you are well. Fantastic work on the canopy. Lovely job! Kind regards, Stix 1 Link to comment Share on other sites More sharing options...
hendie Posted August 9, 2022 Share Posted August 9, 2022 On 8/2/2022 at 12:58 PM, giemme said: I buy Model Master paints form a Polish online store, they seem to have them in stock quite regualrly. you may want to stock up on what you can get now Giorgio. MM were my goto brand for years but Rustoleum decided in their infinite wisdom to discontinue the line so I'm switching to Mr Color Nice canopy work. Tough luck on the glue seepage but you seem to have made a good recovery 1 1 Link to comment Share on other sites More sharing options...
Spookytooth Posted August 9, 2022 Share Posted August 9, 2022 Well played sir, a very nice rescue of the canopy. Damn good what you can get nowadays. Stays safe. Simon. 1 Link to comment Share on other sites More sharing options...
giemme Posted August 16, 2022 Author Share Posted August 16, 2022 On 08/08/2022 at 21:55, Fritag said: PE + resin + UV = success. By the looks of things. Don’t want to encourage you to go pinging-off the etch or owt G - but how secure is the bond do you think? compared with say gator’s grip and cyano. Asking for a friend….. Now now: I did try some (gentle ) poking and prodding and the PE parts held up quite well. But inquiring minds want to know, so I devised a few tests: I did start with the toughest, which was to glue a PE leftover to a clear part and have at it with a Dremel sanding disc, to make the PE flush with the transparency: I sanded one edge whilst holding the canopy and the PE together with a tweezer, and it worked. Then I tried holding the part only by the plastic and leaving the PE "free" (if you get my gist), and the PE just popped off: This, as I said, is the toughest test possible, and TBH I had the same happening with PE parts glued with GG and CA. So I did another test, to verify the level of adhesion of the clear resin on both PE and styrene (again a clear part). Here: Once cured, I tried to remove them using a sharp blade: they both came off, quite easily from the PE fret, with notably more effort from the plastic So the weak link is resin on PE, I concluded. Not completely happy with that, I tried with CA on PE: Again, with the help of a sharp blade it came off, but opposing more resistance than the resin: Conclusions: I would still rely on CA+GG for general gluing of PE parts to plastic, but for the clear parts, I think the resin is a viable alternative. On 08/08/2022 at 22:54, The Spadgent said: Glad you’re back at it dear boy. Hope you had a splendid holiday. I come in here to get away from clear resin and what do I get? looking fantastic. Johnny I did Johnny, thank you! And thanks for the praise - the resin drift wasn't intended to bother you On 09/08/2022 at 10:37, mark.au said: Tell your mate that he need to be thinking more about painting than resin… Fabulous work on the Phantom, the paintwork is exquisite. Cheers Mark, thank you On 09/08/2022 at 11:18, corsaircorp said: Well done Mister G !! The canopy is amazing !! Great surgery indeed !! Sincerely. CC Thank Alain, glad you like it! On 09/08/2022 at 12:51, PlaStix said: Hi Giorgio. Hope you are well. Fantastic work on the canopy. Lovely job! Kind regards, Stix Cheers Stix, thank you! On 09/08/2022 at 13:08, hendie said: you may want to stock up on what you can get now Giorgio. MM were my goto brand for years but Rustoleum decided in their infinite wisdom to discontinue the line so I'm switching to Mr Color Nice canopy work. Tough luck on the glue seepage but you seem to have made a good recovery Thanks for the heads up, Alan - I'll have a look And thanks for thepraise too On 09/08/2022 at 13:13, Spookytooth said: Well played sir, a very nice rescue of the canopy. Damn good what you can get nowadays. Stays safe. Simon. Thanks Simon! More rescue needed, see below.... Where were we? Front canopy for the Hasegawa kit, right? Well, I'm an idiot. Remember the back canopy I tried to modify in my last post, which got damaged and replaced with the FM one? Guess what? It wasn't the back canopy, it was the front one! I had removed it from its sprue a long time ago, and put in the box where I keep all the loose bits of the build, and when I retrieved it I took for granted it was the back one.... which instead was still happily hanging form its sprue! Long story short, I had to replace it again by cutting off the corresponding part form the FM whole canopy: Which also meant I was forced to replace the hinges with the method I had discarded for the back canopy - aaargh! Using a mix of resin and CA, it sort of worked: I then glued on the PE bits, again with clear resin and dipped it in Aqua Gloss. While that was curing, I did some detail painting: wingtips (there's an annoying ridge there I need to get rid of...) tail chute area (to be completed with washes, weathering etc) Then I remembered I had to scratch build the Auxiliary Intakes Doors; so I quickly cut them out from 0.3 and 0.5mm styrene sheet, using my Curio: Glued together with TeT And finally added a tab to facilitate the positioning Time to deal also with the hanging out bits: drop tanks As you can see, they'll require some sanding (already started), but I also intend to replace the lateral seam joint with something more prominent, as it is on the real thing. Then I assembled the outer pylons, including the launchers and their PE parts I still need to prep all the undercarriage doors, the U/C legs and wheels, and the weapons. But I might start with posing decals in between all of those things. That's it for this update, all comments welcome. Ciao 19 Link to comment Share on other sites More sharing options...
hendie Posted August 16, 2022 Share Posted August 16, 2022 2 hours ago, giemme said: Well, I'm an idiot. Welcome to the club Giorgio! Your membership card is in the post. . I wouldn't worry to much - there's lots of us here and we have idiots ranging from your average dunderheid to the esteemed and exhalted complete numptie with all flavors in between. I tend to hang around in the middle but have been known to wander to either extreme on occasion. regarding to resin/plastic bond: I think the resin bonds better when there's a degree of roughness to the plastic creating more of a mechanical bond. I tried using some resin as a filler last week and was almost at the polishing stage when the resin popped out. It could have been the particular plastic as that did have a waxy feel to it, but as we're talking two entirely different material sets here you're never going to get anything other than a mechanical bond, so the rougher the better. Nice work, and lots of it - looks like you'll be busy over the next few days sorting all that out 2 1 6 Link to comment Share on other sites More sharing options...
Terry1954 Posted August 17, 2022 Share Posted August 17, 2022 9 hours ago, hendie said: Welcome to the club Giorgio! I second that Giorgio, we have all been there! I'm sure you will get that sorted, meanwhile what a fantastic progress update on many fronts. Loving those side mounted sidewinder launch rails and nice work on the scratch built auxiliary doors. Terry 2 1 Link to comment Share on other sites More sharing options...
Brandy Posted August 17, 2022 Share Posted August 17, 2022 You plonker, Rodney! Glad I'm not alone in having those "why on earth did I do that?" moments. Nice save though! Ian 1 2 Link to comment Share on other sites More sharing options...
keefr22 Posted August 17, 2022 Share Posted August 17, 2022 3 hours ago, Brandy said: You plonker, Rodney! I wonder if Giorgio gets that reference? K 1 2 Link to comment Share on other sites More sharing options...
TheBaron Posted August 17, 2022 Share Posted August 17, 2022 20 hours ago, giemme said: Conclusions: I would still rely on CA+GG for general gluing of PE parts to plastic, but for the clear parts, I think the resin is a viable alternative. I would agree with you on this completely Giorgio, I don't find resin likes smooth metal at all, but have switched to it for clear parts, finding even on thin PETG it works nicely. Alan (of course ) has the correct technical description of what I've only been feeling my way round as a process: 17 hours ago, hendie said: regarding to resin/plastic bond: I think the resin bonds better when there's a degree of roughness to the plastic creating more of a mechanical bond. Those PE section on the transparency look wonderfully sharp in structural terms: this cavalcade of detail just gets better and better! 3 1 Link to comment Share on other sites More sharing options...
Terry1954 Posted August 17, 2022 Share Posted August 17, 2022 48 minutes ago, keefr22 said: I wonder if Giorgio gets that reference? K Châteauneuf du Pape as Delboy might say! T 5 Link to comment Share on other sites More sharing options...
keefr22 Posted August 17, 2022 Share Posted August 17, 2022 10 minutes ago, Terry1954 said: Châteauneuf du Pape as Delboy might say! T Mange tout Terry, mange tout.... 1 4 Link to comment Share on other sites More sharing options...
Spookytooth Posted August 17, 2022 Share Posted August 17, 2022 Good to see that I am not the only idiot on this site. LOL. Nice work as usual Giorgio, looking forward to the next instalment. Stay safe. Simon. 1 Link to comment Share on other sites More sharing options...
The Spadgent Posted August 17, 2022 Share Posted August 17, 2022 Excellent progress G. Those rails do look rather crisp and the canopy is all sorted now so no worries about little mistakes. We all make them. Beautiful work as always. Jont. 1 1 Link to comment Share on other sites More sharing options...
Navy Bird Posted August 18, 2022 Share Posted August 18, 2022 I wish I was as smart as some of you idiots! Cheers, Bill 1 6 Link to comment Share on other sites More sharing options...
billn53 Posted August 18, 2022 Share Posted August 18, 2022 I’ve been vax’d and double-boosted against idiocy, but it hasn’t helped. 5 Link to comment Share on other sites More sharing options...
Cookenbacher Posted August 21, 2022 Share Posted August 21, 2022 Details upon details upon details - amazing as always Giorgio! 1 Link to comment Share on other sites More sharing options...
giemme Posted August 24, 2022 Author Share Posted August 24, 2022 On 17/08/2022 at 00:55, hendie said: regarding to resin/plastic bond: I think the resin bonds better when there's a degree of roughness to the plastic creating more of a mechanical bond. I tried using some resin as a filler last week and was almost at the polishing stage when the resin popped out. It could have been the particular plastic as that did have a waxy feel to it, but as we're talking two entirely different material sets here you're never going to get anything other than a mechanical bond, so the rougher the better. Thanks for that Alan, it makes a lot of sense On 17/08/2022 at 10:31, Terry1954 said: I second that Giorgio, we have all been there! I'm sure you will get that sorted, meanwhile what a fantastic progress update on many fronts. Loving those side mounted sidewinder launch rails and nice work on the scratch built auxiliary doors. Terry Cheers Terry, thank you On 17/08/2022 at 14:46, Brandy said: You plonker, Rodney! Glad I'm not alone in having those "why on earth did I do that?" moments. Nice save though! Ian You're definitely not alone, Ian And thank you On 17/08/2022 at 18:02, keefr22 said: I wonder if Giorgio gets that reference? K Definitely too British for me (I googled it and "only fools and horses" came up; I heard of that show, but never actually watched it... ) On 17/08/2022 at 18:19, TheBaron said: I would agree with you on this completely Giorgio, I don't find resin likes smooth metal at all, but have switched to it for clear parts, finding even on thin PETG it works nicely. Alan (of course ) has the correct technical description of what I've only been feeling my way round as a process: Those PE section on the transparency look wonderfully sharp in structural terms: this cavalcade of detail just gets better and better! Cheers Tony, thanks for the corroboration - and the praise! On 17/08/2022 at 19:37, Spookytooth said: Good to see that I am not the only idiot on this site. LOL. Nice work as usual Giorgio, looking forward to the next instalment. Stay safe. Simon. Thanks Simon, much appreciated! On 17/08/2022 at 21:52, The Spadgent said: Excellent progress G. Those rails do look rather crisp and the canopy is all sorted now so no worries about little mistakes. We all make them. Beautiful work as always. Jont. Thanks Johnny Sometimes I could do without mistakes, even little ones..... On 21/08/2022 at 05:37, Cookenbacher said: Details upon details upon details - amazing as always Giorgio! Cheers Cookie, glad you approve of Alright, here's some more detailing: drop tanks sanded, polishes and rescribed As I mentioned earlier, I wanted to do something for the side longitudinal joint, looking pretty anorexic in the kit offering; I decided to use it as a guide to scribe a seam for its replacement, in the form of 0.5mm brass pipe: One done, one to do: The brass pipe was glued in with CA; once set, I went along its length with GG (by brush), to reinforce the bond. Here are the two of them done With those ready for paint, I went on with U/C bits: front strut received some PE bits Front door #1: I glued in the clear lens and painted it from the back, using a Molotow Chrome pen Awful pic from the front, sorry For some reason, the chrome is no longer chrome, it looks just some sort of silver; has anyone ever had this happening with a Molotow pen? Anyway, the kit sport an additional clear part for this little door, while Eduard's PE fret proposes a replacement, shown here Now, the PE part is obviously more detailed, but hasn't got the landing light. Plus, that detail is going to be invisible once in place, so I opted for keeping the kit part. I glued it in with TeT and painted with the Molotow Chrome pen again Not much of a pic there, hopefully next one should show it better As you can see, the landing light is quite a relevant feature here. Front door#2: this is made of three parts - inside, outside and blade antenna Not much of a blade antenna, right? More a squarish chunk of plastic. So I reshaped it a bit (again, Eduard supplies this and other antennae in the form of PE part, but even at this scale they just look to flat and thin to me) Then of course there was this big hole that would show up on a frontal view So I riveted a small chunk of brass sheet, shaped to fit the recess, flipped it around and glued in place (with the help of a blob of blue tack on the back, to prevent it from falling inside that pocket) In between gluing/setting times, I removed the seam lines from the wing tips and repainted the black areas, because I noticed on some pics they were different from what I did initially This round panel on the hunch received a base brownish color, to be properly weathered later That's it for the day, all comments welcome Ciao 17 Link to comment Share on other sites More sharing options...
keefr22 Posted August 24, 2022 Share Posted August 24, 2022 Another excellent update G, I particularly like your mod to the droptanks and the nose leg details, but good stuff all round! K 1 Link to comment Share on other sites More sharing options...
Spookytooth Posted August 25, 2022 Share Posted August 25, 2022 Great work Giorgio, nice mod on the drop tanks. And you are right, some P.E. does not look right. Stay safe. Simon. 1 Link to comment Share on other sites More sharing options...
VT Red Sox Fan Posted August 25, 2022 Share Posted August 25, 2022 G, just catching up—really learned a lot from the canopy saga—it turned out great! I think you made the correct choice on the kit antennas vs PE—even on the WW2 aircraft in 1/72 they can look a little flat—best, Erwin 1 Link to comment Share on other sites More sharing options...
The Spadgent Posted August 26, 2022 Share Posted August 26, 2022 On 24/08/2022 at 22:27, giemme said: For some reason, the chrome is no longer chrome, it looks just some sort of silver; has anyone ever had this happening with a Molotow pen? Yes. My one has gone exactly the same. It’s almost as if the chrome has curdled. No longer smooth like a mirror but split Ito a strange emulsion of oil and silver bits. Feels like time has degraded it. Like me. The details are looking spot on regardless dear boy. 100% fantastic. Johnny 1 1 Link to comment Share on other sites More sharing options...
gota Posted August 30, 2022 Share Posted August 30, 2022 On 24/08/2022 at 23:27, giemme said: For some reason, the chrome is no longer chrome, it looks just some sort of silver; has anyone ever had this happening with a Molotow pen? The ink within the tip goes bad, pull the tip out and you should find some working ink, you'll see the difference in consistency. 2 Link to comment Share on other sites More sharing options...
Mark Turk Posted August 30, 2022 Share Posted August 30, 2022 Amazing work! Mark 1 Link to comment Share on other sites More sharing options...
