Finemolds and Hasegawa 1/72 F-4E Phantom II - the Long Nose saga
Nice resin-work G.  I can’t remember your casting method- but whatever it is there bain’t be any nasty bubbles marring the fin(sh.  Respect (as always) :D
On 25/04/2022 at 16:43, hendie said:
Excellent update G. I'm very impressed with the level of detailing going on here
Thanks Alan, glad you like it! :thumbsup:
On 26/04/2022 at 15:09, Thom216 said:
Phenominal work!
Cheer Thom216, thank you! :thumbsup:
Thanks Steve! :thumbsup: I use vacuum for casting resin, that way all the nasty bubbles come a-floating on the surface of the mould stub.  :)
59 minutes ago, Brandy said:
Did someone say paint?
:shutup:
Ian
Are you sure?
:rofl2:
Ciao
  • Haha 2
Resin with a paint chaser!  Wwwwwaitress where’s my drink? 🤩
Simply beautiful craftsmanship Giorgio. The strake additions are fantastic and a true testament to you’re attention to detail.
Bravo that man. 😎
 Johnny
Bravo that man. 😎
 Johnny
Thank you Johnny, glad you like it! :thumbsup: The waitress should be around any minute with your drink... :rofl:
'evening all, I only have some meager progress to report - busy WE and all :shrug:
There were only two things missing on the HASEGAWA kit before painting, to wit the central fixed canopy portion and the slime lights. The former still needed the addition of the relevant PE frames (which I haven't done as of yet), while for the latter I have PE parts from the Eduard set, like these:
slimelights1
I only have one set for one aircraft, though, so I decided to replicate them with aluminium tape for the other. I cut them out using my Curio (this tape is surprisingly easy to cut)
slimelights2
I decided, for no particular reason, to use these on the HASEGAWA kit (to be completed with their decals), while I will use the PE lights on the FM kit, and paint the lights in. ANyway, here they are in place, port:
slimelights3
and starboard
slimelights4
That's it for this update, I'm afraid. All comments welcome
Ciao
  • Like 19
Lovely doubling up of details. I must get some of that tape. It looks super useful.
Brilliant soo see them coming together. 👌
 Johnny
Nice job and nice replicants !!
Good technique !!
Your Rhinos will look REALLY great !!
Congrats !
Sincerely.
CC
 Johnny
Cheers Johnny, thank you! :thumbsup:  The alu tape is super useful, I can only vouch for that! :)
On 02/05/2022 at 20:52, Spookytooth said:
Not much done, but more than me Giorgio.
Looking all OK from here.
Paint?
Simon.
Thanks Simon! :thumbsup:  Paint, yes, see below... :winkgrin:
Good technique !!
Congrats !
Sincerely.
CC
Thank you Alain, much appreciated! :thumbsup:
On 02/05/2022 at 22:43, Thom216 said:
I believe the term is 'slowly but surely.'
Sometimes too slowly and not surely, but I'll take it, thank you! :thumbsup:
So, paint.... in a minute, bear with me first:
the central (fixed) section of the HASEGAWA canopy took a bath in Aqua Gloss
hase_centralcanopy1
after which it got masked with @Gene K Oramask masks, outside:
hase_centralcanopy2
and inside
hase_centralcanopy3
(I actually used the same masks for the inside as for the outside; they're slightly larger than needed, but that's for the best - the outside paint job will define the correct edges.
I then glued the PE frames in place with Gator's Grip
hase_centralcanopy4
hase_centralcanopy5
and eventually.... paint! :D  I airbrushed Tamiya Flat black on it
hase_centralcanopy6
Internal masks removed
hase_centralcanopy7
hase_centralcanopy8
While I had the airbrush out, I wanted to test the paint method I intend to follow with both the airframes: in order to retain as much as possible the very fine detail (especially for the FM kit), I decided to skip the primer and base coat them with Tamiya Flat Black thinned with cellulose thinner, so that it "bites" into plastic. So I used a scrap resin copy of the FM vari-ramp as paint mule. Black base (a couple of thin coats)
test1
Then two different Lifecolor greys
test2
Then a gloss coat
test3
As you can see, all the variramp holes still show up, so I think I'm onto something here :)
Anyroad up, I glued the central canopy section in place
hase_centralcanopy9
After some refining, I painted and weathered the PE frames
hase_centralcanopy10
The rear view mirror will get painted at a later stage
hase_centralcanopy11
Finally, I glued in the two dorsal antennae: they both come from the HASEGAWA kit, and none of them were intended for the original box schemes
hase_antenne1
They will need refining (thinning, slight reshaping, rounding edges), but I'll do that once they cured.
That's it for this update, all comments welcome
Ciao
  • Like 20
Those cockpits (cockpii?) are looking so... well...  just... like... well... cockpits, Giorgio.
I mean they look like the real thing. Real cockpits.
Excellent detailing as we've come to expect from a modeler of your stature.
Don't know if I'd go as far as to call some dribbles of thinned black and a splatter of grey's actual painting though.  I think you're stretching things a bit there. :D
  • Haha 3
If he hadn’t said it I’d’ve said it.  But seeing as he has said it I’ll just echo it.  If you see what I mean G :D
  • Haha 2
To watch these two evolve is a real pleasure Giorgio. Wonderful stuff.
Terry
Caught up now and wow, those cockpits! Marvellous.
Interesting paint technique too - I think you're right that you're on to something!
He drapes a lovely cable doesn't he?
12 hours ago, giemme said:
ehase_centralcanopy11
Without a doubt Giorgio! :clap2:
Yeah ya did!!!  That’s a stonker of a shot right there.
( A really nice photograph ) 🤩
The dials in particular are spectacular.
 J
Absolutely! Johnny nailed it!
And I know it's always being said, but I did have to check the scale!
On 5/6/2022 at 10:41 PM, hendie said:
Excellent detailing
As hendie said!
Really great work Giorgio.
Cheers Alan, thank you - way too kind :thumbsup:  As for paint, see below :winkgrin:
I think I do, Steve .... :D  Thanks :thumbsup:
Terry
Thank you Terry, glad you like them! :thumbsup:
On 07/05/2022 at 05:30, VT Red Sox Fan said:
G, great work--I agree with Johnny @The Spadgent on the tape trick--that looks super useful--best, Erwin
Thanks Erwin, much appreciated! :thumbsup:  I had seen the alu tape used to great effect by @TheBaron, it was about time I gave it a try :)
Cheers Ced, I'm glad you approve of! :thumbsup:
 J
Thank you Tony and Johnny, but most of the credit for the Hase cockpit goes to Eduard's PE parts, I just added a few cables and over-painted the dark gull grey on the prepainted PEs... :)
As hendie said!
Thanks Johnson, much appreciated! :thumbsup:
On 09/05/2022 at 21:43, Spookytooth said:
Great work going on there Giorgio.
Lovely shots of the "Office`s" sir.
Looking forward to the next update.
Simon.
Thanks Simon! :thumbsup: Wait no longer, see below :winkgrin:
On 10/05/2022 at 07:25, Cookenbacher said:
This is a hundred tiny works of art put together two make two big (but still tiny) works of art.
I'm definitely with you on "tiny", Cookie .... :frantic:  :D  Thanks! :thumbsup:
Alright, here's some progress - but first, slightly OT, a few tests I made with the recently purchased UV resin (following @perdu's advice).  I first tried it onto an Oyumaru mold
uv1
and ?d say it really captured the details
uv2
I then tried it as a glaze, and it definitely worked
uv3
Super clear!
Then I tried some various sized drops on different materials: alu foil first (showing the UV curing setup too :winkgrin: )
uv4
It stuck like hell, no way to remove the resin. I did try on wood too:
uv5
and it came off only removing the paint layer from the wood. The best result was on the Oyumaru paste:
uv6
The resin comes right off and it's smooth and clear. Interesting!
Back to the model: I refined the antennae
hase_antenne2
Then spent quite some time with the nose wheel strut dry fit in place to glue the PE parts and the brass rod in place
hase_nosebay1
Eventually, it was time for some masking: cockpit
hase_masking1
Air intakes
hase_masking2
hase_masking3
Aux air intakes
hase_masking4
I then airbrushed the while model with Tamiya Flat Black, thinned with cellulose thinner. SOme remedial work to do, after that:
hase_primer1
and some areas to respray:
hase_primer2
hase_primer3
So this was her in her black dress:
hase_primer4
hase_primer5
The above pic is over-exposed, just to show that I didn't bother spraying a completely uniform black coat - it helps achieving the weathered effect I'm after.
It was then time to airbrush the first camouflage color, FS36270 in the form of Lifecolor Grey
hase_camo1
hase_camo2
hase_camo3
Again, this was airbrushed in an uneven way, alternating up close with narrow lines and far away with a wider spray pattern. This is now curing, before I spray a protective gloss coat on it and mask for the second camouflage color.
Till then, all comments welcome
Ciao
  • Like 17
interesting experiments with the resin Giorgio. That does open up some future possibilities, and if my brain would wake up I might be able to figure out what some of them were (only on first coffee of the day)
Okay.  That counts as paint I suppose.
  • Haha 3
I use UV resin often. For windows and similar glazing, just cover the hole with a piece of clear packaging tape and apply the resin from the inside. That’s how I did the side windows on my 1/72 O-2 Skymaster:
To make clear lenses, place drops of the resin on a sheet of glass. Once cured, they can be easily pried off with a knife blade.
  • Thanks 5
