On 29/11/2021 at 02:11, Cookenbacher said:
Already looking like a modern Phantom with bird slicers and bumps!
Thanks Cookie, glad you like it! :thumbsup: Although it is looking more like a sports convertible Phantom, at the moment... :D :D
18 hours ago, Spookytooth said:
Coming along quite nicely Giorgio.
We hope that you are all safe and warm?
Simon and Lady R.
Thanks Simon :thumbsup: Safe yes, warm not really, at least outside - winter came in quite abruptly :cold: My bests to Lady Rose :)
Ciao
G, incredible work--really enjoyed catching up--the cockpit is stellar and the work you did on the airbrakes is solid.  Like many on here, you inspired me to take the plunge and buy an FM F-4 to join my Hasegawa F-4s--taking notes--Bravo!  Erwin
Hi Giorgio. Hope you and yours are keeping well. Lovely progress as always!  :thumbsup:
Kind regards,
Stix
Wow! I wish my (scale) Phantoms would look half as good as yours 👏 Well done!
Thanks Erwin! :thumbsup:  Good job on buying the FM kit!
Kind regards,
Stix
Cheers Stix, thank you :thumbsup:
Thanks Desk Flyer, and welcome on board :thumbsup:
Not a lot of time for modelling during the last two weeks, so even if there are a lot of pics on this update, there isn't really much work behind them... :shrug:
Let's see: FM wings, the inserts near the wing root left some gaps, and the area in general had a few minor gaps to deal with
fm_wings17
Here after some PPP
fm_wings18
I did glue in the radome, as you can see. The fit is good, the only thing I had to do is to give a quick swipe with a file to the mating surface on the main fuselage, port side, to have it sitting flush with the rest.
Speaking of the radome/nose area: here's Hasegawa version, in which I integrated the resin gun vents I cast from the FM part
hase_nose1
After a bit of surgery, I glued the two halves with the resin bit in the middle, and added some sprue goo to the join
hase_nose4
hase_nose5
and after sanding and polishing (and some rescribing)
hase_nose6
hase_nose7
and glued  to the fuselage
hase_nose8
There was a bit of a step all around that joint, but especially on one side of the cannon fairing, so some sanding was required
hase_nose9
The FM cannon fairing got glued in too
hase_nose3
As you can see, there's a bit of a gap around it too, but again a smear of PPP will fix it.
Gun muzzles: just like the whole area, the difference between Hasegawa and Finemolds here are pretty evident, also in size. I didn't check which one is correct, but judging form pics it appears that Hasegawa is on the fat side, while FM might be a tad too skinny.
hase_nose2
The front apertures are quite different too. I drilled them both out:
hase_nose10
and from the above shot you can clearly see the difference in shape too, with the front end of the FM part being pointy and rounded, while the Hasegawa one looks flat and square.
So I sanded the latter to shape (sort of):
hase_nose11
and glued both in place. Hasegawa first:
hase_nose12
hase_nose13
The joint needs some TLC, and I think I'll have to open up the front aperture a bit more. Finemolds:
fm_nose1
fm_nose2
Last task, I completed the FM airbrakes; in the end, I decided to copy the Eduard/Hasegawa PE parts the old way, by sticking them on some plasticard and drawing the profile and holes with a fine tipped marker; I then used a scissors, a knife and some drill bits to refine them (some riveting added too)
fm_airbrakes7
I also traced the bend lines on them, to conform to the outer parts. Front...
fm_airbrakes8
and back
fm_airbrakes9
I lightly scored the lines with a knife, bent along them and superglued to the brass parts
fm_airbrakes10
Very little of this will be seen once in place; still, I'll have to do some tidying up before painting them. Opposite side
fm_airbrakes11
That's it for this update, all comments welcome
Ciao
  • Like 18
Great progress Giorgio. When those undernose cannons go on, you know you have an E!
Terry
On 12/12/2021 at 20:59, giemme said:
fm_nose1
That is a long nose! 🤥😮😀
lovely work on those delicate air brakes. Bravo that man. 😍
Johnny
As above Giorgio. Great work and progress so far. Now christmas has arrived here and of course also a merry christmas to you and yours from me here. Stay safe and healthy all.
Cheers Benedikt
Edited by bbudde
  • 5 weeks later...
Terry
Agreed! Thanks Terry :thumbsup:
Johnny
Thank you Johnny, glad you like it! :thumbsup:
Cheers Benedikt
Thanks Ben!
Apologies guys, no progress to report - I just wanted to say that I haven't forgotten this build, it's just that I'm almost to the final stretch of my Mustang build and all my modelling time is going into that.
As for this build, I'm actually pondering on how to scratch build the DIAS antenna mounted on the gun fairing for the HAF Phantom; a quite composite shape really - but the truth is that I'm trying to gather all the courage I need to tackle the modification of the outer wings, in order to better represent the slats.
Ciao
I wondered where you had gone, I thought you had gone skiing.
Simon
Simon
No Simon, not yet :winkgrin: I've been here:
Ciao
  • 1 month later...
Boy, it's been a while!
On 25/01/2022 at 03:03, billn53 said:
How did I miss your Mustang build??? You’re doing a yeoman’s job with it!!!
That one is completed now, Bill. RFI here:
Now back to this - before I start my second (and last) entry for the museum, that is :winkgrin:
Not much of a progress, I only scratch built the DIAS ECM fairing that sits under the gun fairing. To do that, I taped some Tamiya Millimetre tape in place and traced the outline of the faring base with a fine tipped marker
DIAS1
I then transferred that onto a piece of very thin styrene, and cut it to shape following the traced outline
DIAS2
Glued in place with fast setting TeT
DIAS3
Then using Oramask, I did the same to trace the outline of the bulky part of the fairing
DIAS
In this case I needed a thicker bit of plastic, so I used an old phone card support
DIAS5
DIAS6
This needed to be tapered in thickness front to back, and then glued in place with Gator's Grip
DIAS7
DIAS8
I had to do some filling with PPP and CA, and some filing/sanding to get to the correct shape, but nothing dramatic. The last bit to be added was a rounded protuberance; you can make out the appearance from the pic at this link:
https://www.milavia.net/specials/greek-airforce-patron-saint-flight/img960/haf-tanagra_16.jpg
To reproduce that, I cut out the corner part of a bit of sprue
DIAS9
It's rounded enough to be a starting base to work with. After some sanding and reshaping, I got this
DIAS10
DIAS11
DIAS12
Right, now I really need to tackle the outer wings, but also the speed brakes and auxiliary air doors on the Hasegawa kit. Plenty of fun ahead! :)
All comments welcome
Ciao
  • Like 19
G, I love it--"nothing dramatic", while everyone is taking notes 🤣  Seriously, I know this is not your most intense scratch work but I greatly appreciate you sharing your tricks in making some of these important details pop--bravo!  Best, Erwin
  • Haha 2
Nice work Giorgio, and good to see the Phantoms back on the bench.
I'm similarly distracted from my Fine Molds 'MiG Killer' F-4D by the MiG-21 STGB. Quite fitting really! ^_^
Yeah.  Unconscionable delay G.  At least I’ve not missed owt. :whistle:
Typically nice skills :D
I need to go and check out the Mustang now.  Looking forward to this….
:D Thanks Erwin :thumbsup: Glad if I can be of any help :winkgrin:
Thank you Charlie :thumbsup: It's a good distraction, anyway :D
On 07/03/2022 at 15:50, Spookytooth said:
Nice detailing there Giorgio, as per norm.
Good to see her again.
Stay safe.
Simon.
Thanks Simon, glad you like it :thumbsup:
On 07/03/2022 at 19:31, Thom216 said:
Awesome lil bit of scratching!
Thank you! :thumbsup:
On 08/03/2022 at 00:18, The Spadgent said:
Nice to see this lot back in action. Great work. 👏
Indeed! Still lots to do! :frantic: Thanks Johnny! :thumbsup:
On 08/03/2022 at 01:31, hendie said:
Sheesh.  You're taking your time getting paint on this one are you not Giorgio?  :D
Beg to differ: both cockpit were fully colored, and so were the air intakes interiors.... :D  :D
Unconscionable, no less.... new word for me, thank you :D  :D  Thanks Steve :thumbsup:
Alright, belated WE progress report; not a lot, still it's progress. I glued the small air intake in on the FM kit
fm_airscoops1
fm_airscoops2
Far better represented parts than the Hasegawa correspondents, and they have aligning tabs on the back, so gluing them on was super easy. Port one had a scratch on the visible side, but it was an easy fix. I then dry fit the auxiliary air doors, trying to determine if it was worth cloning them for the Hasegawa kit
fm_auxdoors1
They are brilliantly engineered, in that they have a solid reference for gluing them in place and at the right angle, as you can see here
fm_auxdoors2
So I think I'll just scratch build two for the Hase kit, but using the same concept. Onward, time to hack some plastic; first the bumps marked in red had to go
hase_wings1
Then I drilled out all the holes for pylons and slat actuators
hase_wings2
Then, with my favorite Dremel tool, I opened up the aux air doors and air brakes bays
hase_wings3
After some refining
hase_wings4
and with the air brakes bays PE interior superglued in place
hase_wings5
I then scratch built the tail fuel dump, to replace the (rather poor) Hase offering. Setup:
hase_fueldump1
After a few failed attempts, I remembered that it's always the case to use a mild abrasive ton the surface you want to solder :banghead:
Here's the result, compared to the kit part
hase_fueldump2
You don't see much, right? How about now?
hase_fueldump3
Still in need of some refining, but definitely getting there.
All comments welcome, as usual
Ciao
  • Like 16
