Elegoo Mars 2 Pro Disaster
Just made a humungous cock-up and tried to start printing more aircraft ladders, but forgot I had the printing plate set for draining another set of ladders.
End result? A cracked LCD screen DOH!!! 😭
I'm now trying to source a replacement LCD screen and sod's law dictates that everywhere is out of stock......
XVTonker :pilot:
  • Sad 1
As far as I know the only place you can get a screen for the Mars 2 Pro is from ChiTu systems here :-
https://www.chitusystems.com/product/6-08-inch-2k-mono-dxq608-x04/
Hope this helps ;-)
All back up and running again.
Purchased a new LCD screen from ChiTu and, after viewing a number of You Tube videos it took me about 20 minutes to change.
One word of warning though. The LCD screen is mounted onto a glass sub-screen. Initially I removed both the LCD and glass screen as a single unit. Fortunately they are only held in position with double sided tape. The actual LCD screen is only about 3 mm thick and they advise you to use a hair dryer as a heat source to soften the adhesive. Something I wish I had done.
I've now gone and got me a mono LCD Mars 2 machine as well as the Mars 2 Pro as it also has the same mono LCD screen and build plate as the Pro so it will be interesting to compare results.
XVTonker :pilot:
Hope this helps 😉
It did and thank you.
Purchased one direct from China and it only took a week to arrive.
ChiTu also said that the replacement screens should be available over here by the end of the month.
Thanks again
XVTonker :pilot:
