Sunderland I v III nacelles
Is there any noticeable difference between the engine  nacelles of these 2 marks? Thinking of tinkering with the Airfix MK. III. Got lots of aftermarket for the Italeri Mk. I.
The Sunderland Mk I had the Pegasus Mk XXII engine, and the
Sunderland Mk III had the Pegasus Mk XVIII engine.
If you compare the chart in link below both the Peggie 22 and Peggie 18
had a similar radius (55.3 inches) so in respect to your question the answer
would be no.
Pegasus Engine Comparison Chart
Caveat though, is that the Mk I had the inner port exhaust which differed in that
the exhaust went through the wing leading edge, through an internally mounted
water filled heating chamber/boiler, which provide hot air for crew warmth.
You can see the exhaust running along the side of the Cowling as opposed to along
the upper cowling in this IWM Photo
Sunderland Mk I
Hope that helps?
Regards
Alan
Edited by LDSModeller
