Corsairfoxfouruncle Posted April 11, 2021 Posted April 11, 2021 (edited) Hello everybody... Well Im a fan of non-warbird Mustangs always have been. So Im going to modify and repaint the great airfix kit into an high speed executive personal plane. In the late 1940’s and early 1950’s there were several companies modifying war surplus aircraft. They were modified to be used as executive or personal aircraft. Some like the P-51 were used as high speed point to point single passenger aircraft by executives. Ive added a couple of links to give you an idea. http://www.mustangsmustangs.net/p-51/who/case/227 Scroll down to the second photo. http://www.warbirdregistry.org/p51registry/p51-4511633.html Some used the drop tank mounts to carry baggage pods others used the gun bays. I plan on using the gun bays for extra fuel as I will be reducing the size of the fuselage tank. I may or may not have a baggage pod. I will post the sprue shots later. Dennis Edited April 15, 2021 by Corsairfoxfouruncle 9
Corsairfoxfouruncle Posted April 15, 2021 Author Posted April 15, 2021 (edited) Hello everyone... So Ive found this description from the Wiki Cavalier Mustang page. https://en.m.wikipedia.org/wiki/Cavalier_Mustang There is a good description of the different types of mods done to these aircraft. Im planning on the gun bay fuel tanks, possibly wing tanks, and a baggage door added behind the second seat. I have changed the dates so this becomes a Cavalier Mustang. Ok so here we go with the required sprue shots. Even get a bit of my sausage finger in the shot. ⬆️ So if there are any questions please ask, or if you need to please post comments. Dennis P.S. - If anyone has any ideas for colors I’m open to suggestions. Edited April 15, 2021 by Corsairfoxfouruncle 8
Corsairfoxfouruncle Posted April 17, 2021 Author Posted April 17, 2021 Good morning everyone ... As Good as it can be with the Funeral today. I spent a good chink of the night working on this. Now I did photograph the interior before installing it, but somehow lost the photo’s ? So had to take the interior shits from outside. Not the best second seat but from what can be seen it will do. I found a set of F-80 tanks which is what Cavalier based there wing-tip tanks on. Next up I clipped the wing tips and tail feathers in preparation of adding the tanks and tall tail. It still needs some more shaping but the glue needs to set-up more. I’ve started to grind away the panel lines on the top and bottom of the wings. Once that was done I got the tanks to a smooth state and pinned them. Ive gone and adjusted the ailerons and glued the tanks on to the wings. If anyone has any ideas for a color scheme please feel free to post them. Please also feel free to ask questions or comment. Dennis 13
TonyW Posted April 17, 2021 Posted April 17, 2021 Nice idea for a build. Looking at the overhead shot, I was reminded of the Northrop Scorpion, only piston engined. 1 1
PattheCat Posted April 18, 2021 Posted April 18, 2021 You build faster than I read instructions! I like the Mustang (but who doesn't?) and I'm especially happy to see a somewhat different one. Cheers. Pat. 1
Corsairfoxfouruncle Posted April 18, 2021 Author Posted April 18, 2021 5 minutes ago, PattheCat said: You build faster than I read instructions! I like the Mustang (but who doesn't?) and I'm especially happy to see a somewhat different one. Cheers. Pat. Thank you, It helps when you're Medically retired aka disabled and have loads of time to do research and build. Ive been a fan of the concept and style of these mustangs for years Id like to do another in 1/48 someday to get better detail in the office.
rob Lyttle Posted April 18, 2021 Posted April 18, 2021 This is a great little kit, Dennis, and that's good progress already on a good idea. Colour scheme wise the field is wide open..... Do you want historical accuracy or are you up for imaginative schemes? That pea-green example looked OK I guess, though probably not the one I'd choose. Hmmmmm.... Keep looking 👍😎 1
Corsairfoxfouruncle Posted April 19, 2021 Author Posted April 19, 2021 (edited) 40 minutes ago, rob Lyttle said: This is a great little kit, Dennis, and that's good progress already on a good idea. Colour scheme wise the field is wide open..... Do you want historical accuracy or are you up for imaginative schemes? That pea-green example looked OK I guess, though probably not the one I'd choose. Hmmmmm.... Keep looking 👍😎 Thanks Rob ... Historical style but maybe different colors ? Somehow bright Red with black, white, and copper trim is where my head is at right now ? Edited April 19, 2021 by Corsairfoxfouruncle
Corsairfoxfouruncle Posted April 19, 2021 Author Posted April 19, 2021 Slowly getting the wings smooth. Ive since added Tamiya fine white putty in the gun shell ports snd other openings. More sanding and polishing tonight. 7
PattheCat Posted April 19, 2021 Posted April 19, 2021 At least in this case no one will quibble about smooth wings or not. Keep the good work on. 1
TonyW Posted April 20, 2021 Posted April 20, 2021 Looking good. Colour wise, how about using one of the late fifties two tone car colour schemes? Ford did a very period looking golden yellow and black that might suit. Anything that says 'automobile' would place the airplane firmly in the civil sphere. Cadillac or Lincoln colours would go along with the expensive personal transportation angle as well. Whatever you go for, it's going to look spectacular. Tony. 1
Corsairfoxfouruncle Posted April 20, 2021 Author Posted April 20, 2021 (edited) Morning everyone ... Well shes ready for paint Shes as smooth as Im going to get her. Prop was taken from the Korean war kit. Not a big deal as I have a Quickboost replacement square tip prop in the box for it. As for colors I was going to go with Red but now I may go with Green, Blue, or Black. I have a pattern in mind and an ID number. Please feel free to ask questions, post comments or add thoughts. Dennis Edited April 20, 2021 by Corsairfoxfouruncle 8
Corsairfoxfouruncle Posted April 24, 2021 Author Posted April 24, 2021 Hello everyone ... Well I was able to get a lot of work done today. I weathered three planes and sprayed the base color on this. Dk.Green metallic. Once this is cured I need to seal it as the next color will be enamel. Im thinking art deco sunburst on top of the wings, and one possibly two chevrons on the fuselage. Please feel free to ask questions, post comments or add thoughts. Dennis 12
CliffB Posted April 25, 2021 Posted April 25, 2021 I'm loving the wing tanks Dennis - quite a transformation 1
Tim R-T-C Posted April 25, 2021 Posted April 25, 2021 Looks rather like a P80 at the moment! Fascinating project, look forward to seeing more. 1
Corsairfoxfouruncle Posted April 26, 2021 Author Posted April 26, 2021 Good morning everyone ... I was able to get the next color on today. Might still do a third color but not sure ? First up was the masking. Prop is painted with matching color spinner and white tips. Ive seen mostly black/yellow props. However on one or two Ive seen nothing and one had red, white, and blue. Though I may go with red, white, red. Please feel free to ask questions, post comments or add thoughts. Dennis 12
Brad Posted April 26, 2021 Posted April 26, 2021 Nice masking. It's most satisfying when you do something complex and then remove the mask. 1
Robin Posted April 27, 2021 Posted April 27, 2021 Hi. just a tad late to the party. I built one of these several years ago using a 1/48 model from the Revel Mustang/Harvard Air Race Dual kit. Not sure if you are aware that Gerald Scarborough did a conversion of the Cavalier Mustang that used a R R Dart for power, this was described in the 1974 hard-back Airfix Magazine Annual 4, using the Airfix 1/24 scale Mustang kit. In the article he provided 1/24 and 1/72 scale plans. I would remind you that this conversion was done in the days of carved balsa wood. Robin. 1 1
Corsairfoxfouruncle Posted April 27, 2021 Author Posted April 27, 2021 43 minutes ago, Robin said: Hi. just a tad late to the party. I built one of these several years ago using a 1/48 model from the Revel Mustang/Harvard Air Race Dual kit. Not sure if you are aware that Gerald Scarborough did a conversion of the Cavalier Mustang that used a R R Dart for power, this was described in the 1974 hard-back Airfix Magazine Annual 4, using the Airfix 1/24 scale Mustang kit. In the article he provided 1/24 and 1/72 scale plans. I would remind you that this conversion was done in the days of carved balsa wood. Robin. Thanks for the info. Yes Im aware of it and also aware of the similar conversion done in Australia as well. The turbo cavalier is on my to do list along with the PA-48 eventually. I just need the kits. Their are resin sets now for the R.R.Dart conversion and full kits of the PA-48. But I have a pretty good set of detailed photo’s and drawings and will attempt to convert a standard kit.
