Marklo Posted April 11, 2021 Share Posted April 11, 2021 (edited) The box The kit. Not a bad kit overall but the engine is awful and the interior needs a bit of detailing. I have a week to mull over the best methods of fixing both Edited April 11, 2021 by Marklo 8 Link to comment Share on other sites More sharing options...
Brad Posted April 11, 2021 Share Posted April 11, 2021 Welcome along Marklo. Yeh this kit is a bit basic in terms of detail, I have one too although it looks like it will build fairly easily. 1 Link to comment Share on other sites More sharing options...
Mjwomack Posted April 11, 2021 Share Posted April 11, 2021 Is the tag, there will be no scratchbuildng a typo? Also, it seems to be a bit low on the wing count by your standards 1 Link to comment Share on other sites More sharing options...
ColonelKrypton Posted April 11, 2021 Share Posted April 11, 2021 2 hours ago, Mjwomack said: Is the tag, there will be no scratchbuildng a typo? It now reads "there will be scratchbuilding". Did it change? I am going to follow along and see where this one goes. cheers, Graham 1 Link to comment Share on other sites More sharing options...
Mjwomack Posted April 11, 2021 Share Posted April 11, 2021 1 minute ago, GrahamCC said: It now reads "there will be scratchbuilding". Did it change? I am going to follow along and see where this one goes. cheers, Graham It's there now- I knew I couldn't believe everything I saw on the internet. 1 Link to comment Share on other sites More sharing options...
Marklo Posted April 11, 2021 Author Share Posted April 11, 2021 (edited) 4 hours ago, Mjwomack said: Is the tag, there will be no scratchbuildng a typo? Also, it seems to be a bit low on the wing count by your standards I thought it said ‘there will be scratchbuilding’ Yes I looked and looked an it’s on of those new fangled monoplanes at least there is some rigging. The challenge here will be to make a reasonable wasp engine and not to make a fingerprint ridden mess of the (apparently) simple colourscheme and of course to do that while building my Oertz, Alcock and Skyhawk, not to mention prep for the Me109 GB. Ah yes the upside of lockdown; having lots of time to do some modelling. And seeing how I’m unlikely to see a vaccination this side of the summer it gives me something to do other than gardening and bickering with the family Edited April 11, 2021 by Marklo 2 Link to comment Share on other sites More sharing options...
Marklo Posted April 14, 2021 Author Share Posted April 14, 2021 (edited) Some small progress; a scale pencil sketch for the wasp cylinder. My plan is to make a one cylinder from either sheet styrene or sculpey then cast the other eight from it. Not sure on the crank case, I may make a buck and plunge mold one, but maybe check the spares box and scrap bin first to see if I have anything close. Edited April 14, 2021 by Marklo 4 Link to comment Share on other sites More sharing options...
Marklo Posted April 16, 2021 Author Share Posted April 16, 2021 (edited) So Plan A is to assemble the cylinder from discs of .5mm styrene sheet to which ends I have spent an hour or so cutting and drilling sheet to mount on mandrels and turn to the required diameters on my little large. Edited April 16, 2021 by Marklo 5 Link to comment Share on other sites More sharing options...
Marklo Posted April 22, 2021 Author Share Posted April 22, 2021 After a bit of fiddling a fairly reasonably lower cylinder. Needs a little more cleanup and then I’ll have to make up the upper portion. 7 Link to comment Share on other sites More sharing options...
Thom216 Posted April 23, 2021 Share Posted April 23, 2021 Cool work on the cylinder. 1 Link to comment Share on other sites More sharing options...
Marklo Posted April 27, 2021 Author Share Posted April 27, 2021 Ok so they’re a little rough but once they’re painted and all the pushrods etc are in place and inside the cowl they’ll look fine. Just four more to cast. 6 Link to comment Share on other sites More sharing options...
Marklo Posted April 30, 2021 Author Share Posted April 30, 2021 Part assembled, some con rods and a bit of fettling, not perfect but much better than the kit item. 7 Link to comment Share on other sites More sharing options...
Brad Posted May 2, 2021 Share Posted May 2, 2021 That looks good mate. 1 Link to comment Share on other sites More sharing options...
Marklo Posted May 2, 2021 Author Share Posted May 2, 2021 Assembled, as you can see the kit goes together fast. But there are quite a few gaps and raised panel lines and demarcation lines for the red that will have to go. 3 Link to comment Share on other sites More sharing options...
Marklo Posted May 2, 2021 Author Share Posted May 2, 2021 Primed, sanded and filled, before sanding, priming and scribing. 7 Link to comment Share on other sites More sharing options...
Marklo Posted May 7, 2021 Author Share Posted May 7, 2021 Primed again and started the scribing. 3 Link to comment Share on other sites More sharing options...
Marklo Posted May 8, 2021 Author Share Posted May 8, 2021 White from a Lidl rattlecan. I need to finish the cockpit next then fit the upper deck properly before doing the red. 1 Link to comment Share on other sites More sharing options...
Marklo Posted May 8, 2021 Author Share Posted May 8, 2021 Some basic interior detailing. Struts, seatbelts and some instrument decals. 6 Link to comment Share on other sites More sharing options...
Marklo Posted May 9, 2021 Author Share Posted May 9, 2021 (edited) Disaster. Attached the upper deck with revel contacts and secured it with masking tape, which lifted some of the white, so I sanded it back intending to reprint it then resorts the white. However about thirty seconds after spraying the primer the white lifted and went all orange peel so nothing else for it but to scrub it back to the primer/ bare plastic ( about half way there atm) then reprint and restart I don’t think I’ll use the rattle can white again, much as I hate to I’ll probably airbrush some Humbrol 130 over the primer. Still on a positive note the surface finish where I’m done is excellent. Edited May 9, 2021 by Marklo 1 Link to comment Share on other sites More sharing options...
Marklo Posted May 9, 2021 Author Share Posted May 9, 2021 And we’re back, that cowling seam probably needs a little filler. 6 Link to comment Share on other sites More sharing options...
Marklo Posted May 12, 2021 Author Share Posted May 12, 2021 On the third attempt I have a semi decent coat of white. Still need to do a bit more work in that upper decking seam and polish the paintwork down a bit, but getting there. 6 Link to comment Share on other sites More sharing options...
Marklo Posted May 15, 2021 Author Share Posted May 15, 2021 Masked up. Unfortunately I dropped the thing after painting the red then the red rattle can reacted with the paint on the fuselage when I retouched it. Im hoping I just need to buff it down a bit then respray it. Lesson learnt …. Don’t mix different brands of rattle cans on the same build. 3 Link to comment Share on other sites More sharing options...
Marklo Posted May 17, 2021 Author Share Posted May 17, 2021 Unmasked. Given the issues, better than I had expected but not as good as I hoped. I will let it dry thoroughly then carefully repair/ retouch the white. 5 Link to comment Share on other sites More sharing options...
Marklo Posted May 19, 2021 Author Share Posted May 19, 2021 (edited) It’s official this is now annoying me, the paintwork is as rough as a badgers back bits and I don’t like the canopy framing. I could spend another week trying to retouch it and polish it an it would still be naff. So it’s going to spend a day or two in disinfectant, get sanded back to bare plastic and painted properly, no rattle cans. I think I’ll also make a new canopy while I’m at it. Edited May 19, 2021 by Marklo 4 1 Link to comment Share on other sites More sharing options...
Marklo Posted May 23, 2021 Author Share Posted May 23, 2021 (edited) The paint just won’t come off, but in trying to remove it it’s actually polished down to a pretty good finish. So I just need to polish down a the last few scratches and blemishes and spot retouch the paint and canopy notwithstanding we’re there !!! Edited May 23, 2021 by Marklo 4 Link to comment Share on other sites More sharing options...
