This is my belated entry for this GB. It is the Bicentennial version of the Hasegawa TA-4J and will be built OOB. The colour schemes are very simple basically white with all the other colours coming in decal form. There are two options in the kit one from VT-126 and the other from VT-7 with myself preferring the latter, but as the decal sheet has been slightly bent so that it can fit in the box I will see when applying these.
Kit box.
resized_3fc9b3a1-545b-4c27-b5d5-94b8a1ae
What's inside.
resized_1083a6dc-c337-4f09-932e-ce933bc3
Instruction sheet.
resized_d104d57e-b9e8-457c-884e-3668b993
Decal options.
resized_684609b2-731f-4d6e-bc39-c9a47618
Slightly bent decal sheet.
resized_56d1db14-6d56-4955-b9ce-c36a2199
Welcome to the party Mark, and with two seater which is very welcome indeed.
Considering the amount of anniversary and special schemes carried by the Skyhawk I am surprised that this is the first one in the GB, and a rather nice one it is too.
Looking forward to seeing this one come together  mate.
Finally got some work done on this one. I have built up both cockpits, using the kit decals for the instrument panels (my hand painting is not that good even in this scale) filling in what would be the glass with Krystal Klear. The side panels were painted with the bigger buttons with a small brush and the rest dry brushed. I have fitted the air brakes using a method that someone in this GB has already used. It is not as good as theirs but it will do for me. Finally I have got the wings together. I am also in the process of fitting the cockpits to the fuselage and all else that goes in there. I have forgotten to fit the small "T" piece (throttle I think) in each cockpits, but will do so when they are both fully fitted.
resized_09a92e85-c57d-4c62-8f1c-15c395e1
resized_dbf47470-5863-479c-9c2e-49f74597
resized_3e1d092d-4978-4fec-aec0-6a993892
resized_45af2462-54ee-4ab8-acca-f983c8af
resized_7cbd4329-b6d9-4213-8a8d-f9a19e64
Great to see your TA-4 underway Jabba and what a great start it is too.
The cockpits look really good, your detail painting and dry brushing have shown up the details very nicely, and the kit's instrument panel decals have settled down very nicely too. Good job tackling the airbrakes too, they look to be fitting very nicely.
Thank you both kindly. A quick update in that all parts are glued into one fuselage half. For some strange reason I could not find the exhaust that fits at the top of the fuselage that was meant for this kit, it was missing on the sprue and not in any bags that I kept. anyhow I did find a different one that the instructions said not to fit, but as it was the only thing available I fitted it and who follows instructions anyway.
resized_ed53e86e-38cc-48db-be76-731c5ffa
That is quick work Jabba, and looks very good too.
Don't worry about using the "wrong" vent for the top of the fuselage, my kit has two versions in it and I am blowed if I can find any difference between them.
Thanks, it is nice when a kit almost falls together rather than fighting you like the last few that I have built.
Anyhow I have now got the fuselage together and just a few more bits to add before this part is completed. I have done a trial fit of the wings and all seems well with that.
resized_21493679-b2b7-49ef-9f02-6033ea40
resized_2c068bea-c25f-4ab9-a2b9-6867f7c5
resized_2378e05c-1490-4134-95ed-adec7878
Damnit Jabba, you making me itch to drag mine out...though mine will be more of a fight I'm sure (Classic Airframes).  :rofl2:
Very neat job on the fuselage Jabba, you have got all the various bits for it to go together very nicely.
The wing joint is a pretty trouble free experience too, it is nice when kits don't fight you all the way for a change.
Do it Chris, you know you want to.😉
Wish I had one .... lucky you !!! ;)
The wings are now joined to the fuselage. I have filled and sanded down the fuselage before fitting it to the wings, but still have a little work to  do around the intakes.
resized_eb10c6f9-91d9-4f36-b13e-acfaa3c6
resized_9d5a26fc-5ad8-4050-94aa-4a7e84ce
resized_69893264-4083-4032-b34d-1db231d9
resized_b91a8e76-6d5a-42d3-bf05-bd4ca623
resized_82b8b854-03bb-4a61-b59a-5998e266
That is looking very nice indeed.
The wings are faired in really well.
You have sorted the intakes very well too, these are not a good fit as a few of us are finding out.
Almost there so that this can be painted, a few bits and bobs to be fitted and I think I will be there. The wing pylons although fitted are not glued at the moment, I am not sure about the outer ones the inner ones will have fuel tanks. I had to drill the holes for all the pylons and went a bit too far on the R/H outer one as you can see a blob of filler in the slat housing area. I am also not sure whether to fit the refueling probe at this moment, for fear of knocking it off.
resized_6eb64b3c-5cb9-49ad-9381-48253742
resized_20770059-89ae-49eb-8291-1813c1ac
resized_11a1d42c-3f20-4eee-afab-6f98521d
Primer applied and some lines picked out with a grey. I do not know how this will work as I do not do this sort of thing that often.
resized_f7634aa1-3f41-4410-9bed-7bfd5914
resized_00c1b232-d894-4d8c-97eb-1967b2c4
resized_63a68ffa-06a6-4065-a588-2613b1ab
