Hello, this is a late entry for a subject very rarely seen built in modelling forums. I had this kit in my stash for nearly twenty years and I thought this could be the right chance to finally build it.
Let's start with an overview of the box contents:
P_20210329_223237 P_20210329_223703 P_20210329_223726 P_20210329_223335
The package is really rich, but coming to the really important things you need a good stomach!
P_20210329_223351 P_20210329_224212
On top of this I have two fantastic canopies, still perfectly transparent after all this time but...   badly crushed!
Unfortunately the flimsy box did nothing to protect them and when I received the kit (second hand) I could do nothing to replace them from the manufacturer since the kit was already out of production. So plan A always was to mould my copy after duplicating with Milliput the original shape as best as I could. More of that later.
P_20210329_224318
Ok, this is the starting point and here below you can see the main pieces after a quick clean up.
Thank you for looking!
P_20210329_225936
  • Like 10
Very Nice Choice, and not an oft seen subject.
I certainly remember these at Wigram with the CFS (Central Flying School), the sound
of the Lycoming engines very much softer than the snarl of the Pratt & Whitney of the Harvard
NZ1931 in formation with fellow Red Checkers
(RNZAF Official - RNZAF Museum - Used with Permissions)
A lot of folks outside of New Zealand probably don't know this, but there was another aircraft similar
to the Air Trainer, and that was the AESL Airtourer - only 4 were BOC and flew operationally
NZ1761
Later on the Air Trainers had a different scheme as below at RNZAF  Base Whenuapai, during an Air Show
Still with the Red Checkers
Look forward to your build progressing :thumbsup:
Regards
Alan
Edited by LDSModeller
Hello,
   Nice subject , I'll sit in on this if I  may got a feeling there's something like this lurking in my man cave .
                                                          Cheers Andrew
Thank you @Corsairfoxfouruncle !
@LDSModeller Hi Alan, I'm glad there is some interest in this airplane: it is quite confusing to sort through all the variations and you just showed in a few images the main ones. I plan to do it in the first Red Chequers livery as per your first image, later yellow/black colors are ruled due to being CT-4Es.
Anyway, before speaking of painting schemes I discovered there is quite some work ahead. @Rob S pointed me in the right direction noting that the fuselage is way too narrow, unfortunately he is right and a quick check with images of the aircraft confirmed that. I think it is a mistake related to the only three view available which is completely wrong and the master was done following it....
So, armed with thick plasticard, I added 3mm to the fuselage width to see how it looks.
P_20210405_185416
P_20210405_185429
Not bad. I considered that going this way I will have to make a new canopy, but since mine are already beyond redemption...
I pressed some Milliput inside to have a starting point, will see how to procees once it is dry.
P_20210411_213526
And here is the current status, covered in filler awaiting for sanding. I had to enlarge also the engine face so I went completely through opening the cooling apertures, I will add later a new base for the spinner.
P_20210411_213552
P_20210411_213609
P_20210411_213602
Thanks for looking!
  • Like 9
An interesting approach to this. Having one of these in stock too, I'll be keen to see what you do with it. I hadn't realized it had this problem, I take it the entire front end is too skinny?
Steve.
Hi @Whirly
Really interesting choice and a new on on me.
Sorry about the canopy, but looks like you have a plan.
Best of luck.
Cheers Pat
On 4/13/2021 at 9:42 PM, Anthony in NZ said:
I plan on maybe doing one in 1/32 one day.
Loving your work, keep it up!
Thank you Anthony! A big scale scratchbuilt would be really nice, biggest problem I fear is finding correct plans: all the drawings I saw over the net are wildly inaccurate. Maybe you have one of those treasured Australian books with better drawings?
Steve.
Yes Steve, this seems to be the consensus from the little experience of other modellers I have found. Checking with images of the real plane seems to confirm that.
On 4/15/2021 at 12:51 PM, JOCKNEY said:
Hi @Whirly
Best of luck.
Cheers Pat
Thank you Pat. I have a plan but it's only in my mind, will see how well it develops in reality!  🤞
Boy, what a fight this kit is!
Seems the width problem is just a minor issue counting all the details to rebuild/add.
I managed to add the tailplane after much refining the joint and checking countless times the relative position of fuselage and fin. Lacking a good three view to aid alignment of the pieces is a real problem.
P_20210417_163150
I cleaned up the metal seats and cockpit parts, that's all is provided. Much more is needed with that big clear canopy!
P_20210417_163257
And then the wings. Oh dear! Incredibly thick, I worked a lot to refine the shape of that horrid soapy plastic. Panel lines are nearly invisible, maybe better given the delicate nature of the subject so I hust filled the few traces remaining. Much to add here too: big wingtip lights you can see in raw status, then we need a landing light in the left wing and those tiny wing fences...
P_20210417_163241
I see the deadline approaching, hope to gain speed.
Thanks for looking!
Some more progress to report, however at glacial pace!
The canopy was treated just like the front fuselage, much filing and sanding will follow.
P_20210424_163822
I added some furnitures to the cockpit for a start: a central console, a rear shelf and a "bulkhead" behind the seats.
P_20210426_230848
Now the fin... I sawed away the front part since it is thick like a brick. I patiently shaped some brass sheet from an old etched ladder with a much better effect as you can see with all glued and treated with Mr Surfacer 500.
P_20210426_230839
Then I finally glued the wings to the fuselage with a couple of metal pins to reinforce the joint. Unfortuantely there is a big difference in thickness between the wings (which are already less than refined) and the stubs on the fuselage, so I had to remove a lot of material with a scalpel and a riffler file to level the joint.
P_20210428_224500
The underacarriage mounts too need some care. I removed the plates under the wings as they were an obstacle to refining the wing roots and appeared anyway wrongly shaped. Then I roughly cut the shape of the front u/c "well", I will refine it later.
P_20210428_230126
And finally the wing landing lights, I'm quite happy of the result.
P_20210428_224519
Thanks for looking!
Hi Steve, thank you!
Looking ahead to the painting stage: the instructions specify Grey 16440 and Orange 12199. The latter seems too orange compared to images but I know reds and oranges can be really treacherous in photographs. Anyone who have seen this paintscheme in the flesh can confirm the correct hues?
I'm pretty sure the Grey was Gull Grey (equivalent FS16440), the Orange type colour was
International Orange/Dayglo -Bear in mind these colours would have been manufactured here in New Zealand
to Defence Force DTD's, (still reference FS Number though).
Humbrol (years ago made a pretty close rendition of Int Orange Dayglo, They still make one (Humbrol 18).
but can't vouch for its actual color, as I haven't used it recently.
I can check with, some folks I know, that were around then, who were Airframe Riggers (Aircraft Safety/Surface Technicians) for you?
Regards
Alan
Hi Alan,
no need to check: I'm pretty convinced by your recollections. I also found this recent post where the builder added some red to International Orange which seems quite correct to my eyes.
By the way, I appreciated your photo contributions: I plan to build soon a Red Chequers Harvard in the Group Build so they will be most useful!
Hi Alan,
It was MRP paints for interest. Looks like you're making great progress 👍
