pheonix Posted April 7, 2021 Share Posted April 7, 2021 Evening All, I have already written in the chat thread that I am keeping up the habit of a lifetime: I am late to the party. However I have only just started on this project, so under the 20% completion rule I honestly think that I am eligible to enter with what I have done so far. Before I reveal all however i will show you some images of my kit and instructions. First the kit: I know that these limited run kits are a bit basic these days, the more so as some parts may be missing - I will need some rod, hardwood for a propellor, and some wood for a plunge mould, but I am sure that you know what those parts look like. (I am aware that there is a vacuform of the SP 3 variant but as I do not like vacuforms I am building one of my own). So on to the instructions/plans: There are two small problems with the above image. First it does not show the plans - I am not doing so because I do not wish to infringe copyright, but there are good 1/72 scale plans in this monograph which I will be using. Second problem, the aircraft shown on the cover is an SP 3, a development of the SP 2 which had a two bay wing, (the SP 3 had a three bay wing), and the shape of the nacelle on the SP 2 was different. So here is a photo of an SP 2 so thet you have a better idea of what I am going to try to build: http://www.ww1-planes.com/Italy/Savoia.php Scroll down to the second photograph on the above link. Photographs of the SP 2 on the net are unfortunately in short supply because this is not a well known type - indeed I only found it via the WS DataFile catalogue. So far I have cut out the blanks for the flying surfaces, (wings and horizontal tail unit), from 30 thou card which has been bent in hot water in a plastic pipe: Also shown are the rudders, a plate for the engine base, (most of the engine was buried in the nacelle and will not be visible on the completed model so I am not making a sump which will never be seen), and some laminated card for the radiators. I have added 10 x 20 thou plastic strip to the wings which I am in the process of sanding down to represent the ribs: I have scribed the radiator blocks and added 10 x 20 thou strip to represent the metal straps and cemented the header and bottom units: So I am off to a flying start, well at least for the moment. Thanks for looking. P 13 Link to comment Share on other sites More sharing options...
Mjwomack Posted April 8, 2021 Share Posted April 8, 2021 Another one by the limited run manufacturer Evergreen😉. Starting to think that I missed a trick here and should have asked them to sponsor this GB🤔. Accuracy aside, the cover of the book is so evocative 1 Link to comment Share on other sites More sharing options...
Jonners Posted April 8, 2021 Share Posted April 8, 2021 Another pheonix scratchbuild! Excellent! Jon 1 Link to comment Share on other sites More sharing options...
AdrianMF Posted April 10, 2021 Share Posted April 10, 2021 Trouble with those sorts of kits is that you spend all your time cutting off flash! Adrian 2 Link to comment Share on other sites More sharing options...
Brandy Posted April 10, 2021 Share Posted April 10, 2021 Another pusher? You're so predictable P! Along for the ride though! Ian 2 Link to comment Share on other sites More sharing options...
Paul821 Posted April 10, 2021 Share Posted April 10, 2021 On 4/8/2021 at 9:20 AM, Mjwomack said: Another one by the limited run manufacturer Evergreen😉. Starting to think that I missed a trick here and should have asked them to sponsor this GB🤔. Accuracy aside, the cover of the book is so evocative I think Evergreen have been rather busy of late with one of their ships stuck in the Suez canal. Before anyone corrects me I know they are different companies. 2 Link to comment Share on other sites More sharing options...
pheonix Posted April 10, 2021 Author Share Posted April 10, 2021 1 hour ago, Brandy said: Another pusher? You're so predictable P! Along for the ride though! Ian I know Ian, but so few other modellers make them that I must step into the breach and fill the gap! They are real aeroplanes after all. 1 Link to comment Share on other sites More sharing options...
John Masters Posted April 10, 2021 Share Posted April 10, 2021 Very fun! 1 Link to comment Share on other sites More sharing options...
pheonix Posted April 14, 2021 Author Share Posted April 14, 2021 Evening All, Many thanks all for your encouraging and supportive comments - I have been in need of those recently as this update will show. Well I nearly lost my mojo again. I finished sanding down the ribs on the horizontal surfaces and then turned to constructing the nacelle. My original intention was to push mould it in two halves, so I dutifully carved the male mould from basswood and after a couple of attempts I had two halves. Then I saw the problems which I had not given sufficient thought to, namely that I had a seam down the nose and the leading edge on the nose was rather blunt. I then did what I should have done at the start - look at a similar nacelle which I had made for a previous build. I refer to a Voisin III model which I made some years ago which has similarities in shape with this one: The leading edge of the nacelle is sharp and the sides are flat so that the angles are quite sharp. The front of the nacelle is slightly curved and very prominent - any joint there is going to be a b.... to fill and hide. When I looked up how I had made the nacelle the answer was a blinding flash of the b.....obvious: Make the sides and bottom from flat card and mould the top surface! This method means that the sharp edges of the lower part of the nacelle are easily reproduced, (no rounded corners resulting form the push mould which have to be sharpened), and the top surface has no seams! Easy when a little thought is given to the problem, or even simpler if I look up how I did something in the past....! So back to square one and start again... by making the sides and bottom from 30 and 20 thou card respectively. This also made the cutting of the two rectangular and one round window in the bottom of the nacelle easy - no trying to match holes on each half of a nacelle moulding. I could curve the rear of the underside by repeatedly bending it with a pair of tweezers. I put some supports along the fuselage sides to hold the floor in the correct place, added some simple framing, painted the insides, made a blanking piece which represents the fuel tank behind the observer and a throttle quadrant, and it was ready to be assembled: The seat in the image is a spare resin from Barracuda - I am not sure if it is accurate but as nobody is likely to see it I am not too concerned. Similarly I have left the interior details to a minimum - I will add an IP and control wheel but nothing else will be visible. The fuel tank blank helps to support the fuselage sides until I can fix the top in place. The rear of the fuselage was blanked off with 60 thou card to allow for the necessary filing and shaping. Filler will be needed here later too. I moulded the top using the male fuselage mould and a new hole cut in plywood sheet. At this point I again ran into problems. Generally I can get a decent mould after two or three tries - not this time. Male moulds made from balsa wood seems to need a smaller gap than those made from basswood so I had to keep sanding down the male mould. Then I could not get the front of the nacelle to mould properly: I was close to putting this project on hold and starting something else. I decided that I would give it one more try and slightly change the angle when I pushed the male mould into the plastic sheet - and it worked immediately! I think that I am beginning to lose my touch with this moulding process as I have never had quite so many failures before. Quite a lot of plastic had to be removed but that was straightforward so that I am at last at this stage: The engine will consist of a row of rod pieces glued together with the top of the engine detail: I do not intend to make the lower parts as they will be completely concealed on the finished model. This was dropped into the fuselage so that I could measure the size of the hole which I need to cut into the moulding later. I am hoping that I can now complete the nacelle and engine details and proceed with painting. Thanks for looking. p 9 Link to comment Share on other sites More sharing options...
Torbjorn Posted April 15, 2021 Share Posted April 15, 2021 On 4/14/2021 at 11:08 PM, pheonix said: Well I nearly lost my mojo again. Please don’t. Never heard of the type before and I would sure like to see it built. The fuselage top does look convoluted with its curves, but you seems to have pulled it off. I gave up on balsa except as femal moulds, it’s too soft to give enough definition. Maybe for very round forms it’s good? 1 Link to comment Share on other sites More sharing options...
Mjwomack Posted April 16, 2021 Share Posted April 16, 2021 Yes! Rescue the mojo! Easier said than done, but you're purring along with progress on this, and it has a lovely charm to it. 1 Link to comment Share on other sites More sharing options...
Marklo Posted April 16, 2021 Share Posted April 16, 2021 Loving the build far. If it’s any consolation I find molding can be hit or miss sometimes impossible sometimes a breeze although I think it does come down to how well thought out the molds are and having the right plastic at the right temperature. I now have a new homemade vacuum box, a little grill that I acquired and an old Hoover as well as an oven thermometer all living in the garage and I’m finding my molding sessions go a lot smoother these days. 2 Link to comment Share on other sites More sharing options...
pheonix Posted April 16, 2021 Author Share Posted April 16, 2021 Thanks for the supportive comments: I can assure you that my mojo has returned now that I seem to have got past the most recent awkward bit. I can foresee some problems coming up with the booms and tail unit, but I am already thinking about possible solutions. Will have to wait until the time when I get there and try out some dummy runs. P 1 Link to comment Share on other sites More sharing options...
AdrianMF Posted April 17, 2021 Share Posted April 17, 2021 A good choice on changing the orientation of the moulding. The more you can build as a box, the better! Regards, Adrian 2 Link to comment Share on other sites More sharing options...
pheonix Posted April 21, 2021 Author Share Posted April 21, 2021 Evening All, Thanks for the advice Adrian: I usually try to build simple structures wherever possible, but for some reason I got it into my head that the whole of the nacelle should be moulded. It was not until I tried to do so that I realised my mistake. I glued the new nacelle top to the sides while the rear of the nacelle was blocked off with thick card and filed to shape. A liberal amount of filler was applied to the joint between the moulding on the top of the nacelle and the sides and rear where the fit was not perfect. The obligatory sanding and filling followed... The nose now has the sharp edge and corners similar to those I managed to achieve on the Voisin. I have opened up the apertures for the cockpit and engine compartment in the nacelle. I cut around the outline of the openings with a new scalpel and finished the edges by carefully scarping and filing. The latter was a bit delicate as I did not want to damage the interior of the cockpit, although the pilot's seat was not in place at the time: After fitting the pilot's seat I added some detail to the top of the engine: ie the part that will be just visible on the completed model. Basically I added the cam shaft from small pieces of rod between small cubes of card, the latter representing the housing for the valves on the top of the cylinders. Some thin pieces of rod on the side of the cylinders represent the carburretor intakes and I have drilled holes on the opposite side to take rod for the exhausts later. The engine was fixed into the rear of the nacelle so that I can now start painting. Thanks for looking. P. 10 Link to comment Share on other sites More sharing options...
pheonix Posted April 28, 2021 Author Share Posted April 28, 2021 Evening All, I had to make a new top wing as the old one suffered badly from banana syndrome and I was quite unable to straighten it out: the one in the photo has been discarded and the new wing is still being painted. A coaming was added around the cockpit from 20 thou rod and I have carved a propellor from wood. I have been coating plastic with acrylic paints over the past week - mainly mixed colours (Revell white and beige 314) for the CDL on the wings and flying surfaces and white and Mittlegrau (46) for the struts and nacelle. The wood sides of the nacelle are Revell brown (381). I applied many coats of the CDL and grey (probably 10 on the flying surfaces and nearly as many for the grey on the nacelle), to build up a solid layer of colour which has a smooth semi-matt finish. The national colours were Humbrol enamel red (60) which also needed several coats as the paint is rather thin, and Humbrol enamel Dragoon Green (MC 7) which I have had since the mid-1970's! The national colours may not be an exact match but given the variations in pigments and fading which took place, I am claiming that these are probably close enough to be acceptable. The tyres were Mittlegrau. I have received the serial transfers from Arctic Decals and will apply them to the fuselage before I continue with construction. When the new wing is finished (hopefully tomorrow), I can start on the final construction phase - wings, tail unit and undercarriage. Thanks for looking. P 10 Link to comment Share on other sites More sharing options...
pheonix Posted May 4, 2021 Author Share Posted May 4, 2021 (edited) Evening All, Construction has restarted and I have now made the nacelle ready to be fixed to the lower wing. I have thought long and hard about the order of assembly of the major components and have decided to follow the sequence described here. More will follow later. The first step was to put the radiators on to the sides of the nacelle. I had pre-drilled holes in the nacelle and radiators to take small pins to provide a strong joint, so a drop of cement and they were on. This was followed by the pipes to the top of the engine which were made from 20 thou rod which had been bent to shape and then painted: The cabane struts were cemented to the fuselage sides and allowed to set properly. The length of these is the same but the front end of the nacelle is supposed to be slightly lower when mounted to the wing - getting the lengths right was a bit of a fiddle. Having got the cabanes in place there were awkward cross struts to add between the lower parts of the cabanes - I used 10 x 20 thou strip for those. The return pipes from the bottom of the radiators to the engine had to be added to the bottom of the nacelle after the struts were in place as the pipes ran outside of the struts: The serlal was now fixed in place - it was from Arctic Decals and made to order. It is slightly oversize (my fault, not Arctic Decals!), but I do not think anyone will notice if I do not mention it. I also added the exhaust pipes but some of these are too long and I will have to remove and trim them later before I fix the top wing in place. Now to mount the booms and tail. This is what I have been thinking about for some time. I have decided that the method I am about to describe is as good as any, but it varies somewhat form the method that I have used before. The rear of the booms were fixed to the rudder posts and the horizontal tail section sat on a cross member between the lower booms. The rudder posts passed through the horizontal tail surface, so I soldered two small rudder posts to the ends of the lower booms. I drilled two holes in the horizontal tail surface and squared these with the end of a small file and made sure that the posts would pass through properly. The lower booms were epoxied to the slots in the rear of the lower wing and the correct angle achieved by using a standard boom jig - the height had been measured from the plans as described in previous build articles: The above shows the booms set ready to be epoxied, the paint pot was to help keep the rudder posts upright while I fiddled and checked that everything was square and true. After the expoxy had been applied and cured I had this: In the images there is a piece of paper with a line and arrow with 19mm written on it: the line represents the height of the booms at the tail end relative to the rear of the wing - the edge of the paper was used to measure the height of the wood blocks that make the jig. The wing and booms were laid over plans to get accurate alignments. Simple and effective - scratch building does not have to be complicated or difficult. A quick check of the newly installed booms with the horizontal tail surface showed that the rudder posts would pass through the holes in the tail, so the horizontal bar between the rear of the booms was inserted. This was a piece of 20 x 30 thou strip: The nacelle sub-assembly was cemented to the lower wing and the boom bracing at the rear painted. Finally the horizontal tail surface was CA'd to the rudder posts and booms: I have worked out how I intend to fix the upper booms to the top wing and then wing to the above assembly and will describe the process in the next update when I have completed that stage. Thanks for looking. P Edited May 5, 2021 by pheonix 11 Link to comment Share on other sites More sharing options...
stevehed Posted May 4, 2021 Share Posted May 4, 2021 Splendid description of the processes. We can worry ourselves into inertia but breaking the task into smaller units usually simplifies things. Lovely job on the nacelle. 1 Link to comment Share on other sites More sharing options...
Jonners Posted May 4, 2021 Share Posted May 4, 2021 Nicely done! 1 Link to comment Share on other sites More sharing options...
pheonix Posted May 7, 2021 Author Share Posted May 7, 2021 Evening All, Thanks Steve and Jonners for the kind comments. Yes Steve we really can think ourselves into a standstill if we are not careful, but in my experience assembly sequences are rarely as difficult as we imagine them to be. I am sure that it is the imagined, as opposed to actual, difficulties which stop many modellers from scratch building - I know that I had to overcome just that problem before I started scratch building, but now I have done so I have no desire to return to building kits. I have put the top wing and upper booms in place, but followed a different sequence to one which I have used in the past. Formerly I would have attached the booms to the wings and then placed the wing/boom assembly on to the cabane struts and put the rudder post between the rear ends of the upper and lower booms. However in this case the rudder posts were already in place so if I got the angle of the booms on the top wing wrong, or the booms were too long or too short, the assembly would not work. The other problem was that I normally use epoxy to join the booms to the wings, but this would not set quickly enough to guarantee that the booms would remain in the gaps in the wing trailing edge: I had to use relatively quick setting CA instead. The first step was to check that the booms would fit into the gaps in the trailing edge of the top wing and would align accurately with the rudder posts on the lower booms - a bit of filing was needed to enable fine adjustment: The booms are parallel and will fit exactly over the rudder posts - they were measured with dividers. The top wing was placed over the cabane struts and the positions of the strut ends marked on the underside of the wing so that holes could be drilled. This had to be done this way as I could not guarantee that if I drilled these holes based on the drawings, the struts on the model would fit: by using this method the struts do fit even though there is a slight mis-alignment. The misalignment is too small to be noticeable but would have been enough to cause construction problems had I not followed this procedure. With the holes drilled the wing was cemented to the struts. When the wing had set I put CA on one end of a boom bar and a drop of CA on the top of a rudder post. The boom was placed into the slot in the wing trailing edge and gently lowered on to the top of the rudder post. I could hold the boom to wing joint for a couple of minutes while the CA cured. This operation was repeated for the second boom. Before I could damage the structure I cemented the outer and inner wing struts between the wings and left the assembly for an hour to set: The addition of these struts makes the assembly strong enough to handle like any other model under construction and there is little risk of damage unless the model is dropped or struck hard. The remaining wing struts were easy to insert, followed by the boom struts: When I insert the wing and boom struts I always measure the gaps first and cut each strut to fit: when I make sets of struts I always make them too long so that I can cut them to the size needed to fit the gap. This is particularly important for the booms as small errors invariably creep in and there is no guarantee that the gap on the model will be exactly the same as the plans! The tail structure was completed next. First I cut the upper and lower cross bracing between the outer rudder posts from 30 x 40 thou strip. The central rudder post and forward brace were cut from the same material and all glued in place and painted. The outer fins were cut from the fin/rudders and the fins cemented into place: The main undercarriage was next. The struts were made from 30 x 40 thou strip which had been sanded to aerofoil section, and the skids from the same material with the front ends bent and sanded to shape. The axles were cut from a paper clip and the bungee cords represented by thread which was wound around the axle and skid with the end CA'd into place: The wheels are discs of 60 thou card shaped to represent covered spoked wheels, with the tyres made from 60 thou rod wrapped around a paint brush handle and held for 10 seconds in boiling water. The wheels were CA'd to the axles and the bracing pieces cut from 10 x 20 thou strip: There are still some more bits and pieces to add but the next step will be to rig the model with rolled 40 SWG copper wire. I will add control horns, skids and propellor as I rig the model because that reduces the chances of damage. Hopefully in the next post I will be able to show the completed model: however there are approximately 170 -180 wires to be put in place so it may be a little while before I finish this. Thanks for looking. P 9 Link to comment Share on other sites More sharing options...
AdrianMF Posted May 7, 2021 Share Posted May 7, 2021 I’m not sure if it looks more reassuringly stronger or still terrifyingly fragile! Wonderful modelling either way. Regards, Adrian 1 Link to comment Share on other sites More sharing options...
Torbjorn Posted May 8, 2021 Share Posted May 8, 2021 She’s a beauty, and those ear-muffs posing as radiators add to the charm. Thanks for writing your boom fitting procedures, it’s helpful to see what works (and that many orders work - it is as you say easy yo thunk yourself into a corner imagining there is only one solution). 1 Link to comment Share on other sites More sharing options...
pheonix Posted May 16, 2021 Author Share Posted May 16, 2021 (edited) Evening All, Thanks Adrian and Torbjorn for the kind comments. Adrian: I can assure you that the model is actually quite robust except for the undercarriage. I would have been happier if the original had had more bracing but it didn't and so that will be the weak spot on this model. However as it will also be difficult to handle now that it is finished, I intend to fix it to a base permanently so hopefully it will avoid being damaged. I have finished rigging this one and added the final details: propellor, windscreen, control horns, pulley wheels for control cables, gun ring, handle on the top wing. Rigging was straightforward once I had finished the innermost bays: the bracing there is different to the other bays and has 8 independent wires in each bay, excluding the control wires. I am pleased that I do not use thread because it would be impractical in places on this model, unless one has the eyes of a hawk, patience of a saint and lots of time: I have none of those. Being a pusher it has lots of bracing and various control cables, but it was no more difficult that a conventional tractor to rig, just took longer because there are more wires to add. I am pleased that it is finished as it has been on my to do list for a long time, and as there are no kits of this model in 1/72 scale, and none of the SP 2 variant, it is another different type to add to my collection. There are more photos and background to this little known type in the RFI section. I will now start on a second subject for this GB - I will start a new thread when I have something to show. Thanks for looking. P Edited May 16, 2021 by pheonix 5 Link to comment Share on other sites More sharing options...
JWM Posted May 16, 2021 Share Posted May 16, 2021 The essence of modelling - the scratch work . Very impressive Regards J-W 1 Link to comment Share on other sites More sharing options...
Torbjorn Posted May 22, 2021 Share Posted May 22, 2021 Neat! And everything is fine and small looking like it’s to scale. Certainly a different looking contraption. What’s next? 1 Link to comment Share on other sites More sharing options...
