Vega Gull VP-KCC Beryl Markham 1936 1/48
Grandboof
Hi All
Here I am late to the party as usual with this
now whats in the box
No promises will give it my best shot
Martin H
Beryl Markham- quite a 'character', apparently banned by royal decree from Britain! Read her memoirs after coming across her in the biography of Karen Blixen, mind all those inter-war peeps were 'character's!
This is one to watch
Hi All
Some bits and pieces done . The instructions call for a number of smallish sub assembles to be done early. Given my ability to lose things on regular basis I have left most until required. The tail wheel is at risk though . There are a number of optional pieces ( Props exhausts Etc ) but the instructions are a little vague as to which are required . An internet search solved most problems . The exhaust will be my best guess . The plastic has a different feel but is easy to work with. Dry fitting and a good cleaning is essential here as the part fit is tight in some cases . The first photo etch is fitted ( the compass mount) something I have been dreading . Anyhow here is what has been done . Thanks for looking
Martin H
What a lovely subject choice. I'm looking forward to watching your continued progress on this one Martin :)
Hi All
        Been fitting small bits and pieces . Only 1 offering to the carpet god namely part of the seat belt . Fortunately there was a spare on the etch sheet . Next a quick prime and detail paint then on to the bigger bits . More soon
Martin H
Hi All
What detail painting that will be is done . Next the moment of truth closing up . No locating lugs will be fun . Dry fitting indicates that the cabin and engine can be inserted after the fuselage halves are joined . This should make joining easier .That is the plan What could possibly go wrong?😉  Thanks for looking for soon
Martin H
It's looking good Martin and it's always interesting when a kit builds up in a slightly different manner to normal.
Hi All
        A little more done . The fuselage close up was a little problem due to the lack of locating pins . I found it easier to start  from the rear to the cabin opening letting things set before lining up the forward section. The engine does have to small locating points and was in place easily. Everything is ready for inserting the cabin
Thanks Cliff So far so good
Martin H
Hi All
        Well with a little wriggle here and there the cabin is in place . Two small problems 1 mold fault on the port wing root 2 the prop  shaft is a little short probably due to the initial locating .Both easily fixed . When using this method the engine needs to be fixed in place first ,then the shelf with throttle quadrant and finally the cabin . Thank as usual for dropping by
Martin H
Hi All
        This thing is throwing up problems . The shelf with the throttle quadrant had to be relocated lower . A tiny bit of Blu tac was popped in to hold it in place while the glue settled . A few touch ups required . The lower engine cowl required some major surgery to fit . Most of the exhaust has been removed . I am working on the wings more later .
The kit is fine instructions not so much . More updates soon . Thanks for dropping by
Martin H
I've done a couple of kits where I've lost the instructions and not noticed the difference! I suspect many of us have and you don't seem to be too handicapped by the instructions because it's looking good from here
Hi All
Some more done . First the parts for the wing fold seem to work better if the lower half is set in place on the wing then the upper half added . All control surfaces are tight and need a little trimming . The highlighted bits
Then we have wings
Still plenty to do but it's getting there Thanks all for dropping by
Martin H
  • 3 weeks later...
Hi All
The clear pieces are in place. These are a little fiddly . I found it easier fix the doors to their halves then each half in place on the fuselage individually so as to get an accurate location of the lower joints . Not as per instructions but it worked . I have started masking( the fun bit?) . Should have some paint on soon . Thanks for dropping by
Martin H
Glad to see you've got the extensive glazing sections into place without too much trouble Martin.
  • 3 weeks later...
Evening All
                 Flatt aluminium on despite my spray gun not playing nice . ( The paint was a little beyond it's prime) . More tomorrow with luck .
The missing area on the port wing root is no more . There was a part on the sprue that was not mentioned in the instructions which fitted the gap
Thanks for dropping by . More soon
Martin H
Evening All
Turquoise is done (Mr Color 391 Soviet cockpit turquoise ) . Tail and wings on . The fit was tight only slight trimming needed . Next a coat of clear then decals and the final bits and pieces .
Martin H
Evening All
Getting closer now but not counting chickens just yet . Decals are on .Last bits and pieces should be on tomorrow . The tail wheel will be are spares recruit as the kit part has deserted and joined the carpet legion . Thanks as usual for dropping by
Martin H
That looks a bit awesome, I might have to try & track one of these down too, I bought the Proctor, Vega double kit recently, I don't think it has these decals in it? I was really after the Vega to convert it to a Jean Batten Gull Six.
Steve.
Hi Steve
This one is 1/48 Civil use issue and I believe the decals are different to the 1/72 .Your Gull Six conversion should be great
Martin H
I knew that. ;) :D , least I think I did back when you started, so many details, so little spare memory. :( Thanks for the reminder, something else to look into. :)
Steve
