Hobby Boss A-4 Skyhawk RAN Conversion
I note there have been a number of discussions on 1/48 Skyhawks.
Some older:
https://www.britmodeller.com/forums/index.php?/topic/235020929-best-148-a-4/
Some new:
https://www.britmodeller.com/forums/index.php?/topic/235067811-a-4-skyhawk-in-148/
Some current:
https://www.britmodeller.com/forums/index.php?/topic/235091318-finding-it-difficult-to-track-down-a-148-a-4b-skyhawk/
My questions are specific to the Hobby Boss kits, which I can source easily, with the plan to present as a RAN A-4G most likely from HMAS Melbourne, grey scheme with red checkerboard fin.
For me the shape is key and I will correct if need be. That is if something is correctable and the error is well defined. Therefore, are there any issues with the Hobby Boss in shape, canopy, cockpit depth, and also surface detail representation? I expect I will have to cut, fabricate and deploy slats. What else?
For the A-4G, should I start with the Hobby Boss F (sans avionics pod), like the original, or come up from the E?
Hasegawa ain't an option and besides I do not mind some mod work if the starting kit is modern and fundamentally correct.
Thoughts?
Ray
I don't have the HB kit so can't comment on the accuracy, one thing I noticed however is that both A-4E and A-4F boxes seem to include exactly the same parts, unless I've missed something
https://www.super-hobby.it/products/A-4F-Sky-Hawk.html
https://www.super-hobby.it/products/A-4E-Skyhawk-20194027-1.html
If so, then you may start from either one
I think your're right.  Sensible if they can use the same moulds. I wonder what, if any, sacrifices were made to achieve this?
Funny, checking the sprues it seems little aircraft plastic and a massive amount of ordnance.
Actually there are certainly some slight differences regarding wing (the F variant has wing-top spoilers). This is also reflected in the HB kits.
Since the A-4G was based on the A-4F I would suggest this kit as the base for your build.
@NAVY870
Hi Steve,
I am very interested to know your thoughts on this. Also, any of the intricacies the kit manufacturers miss for a HMAS Melbourne Skyhawk. I think I will commit to the Hobby Boss A-4F as the base kit unless it is horribly wrong.
Ray
I'm aware of the differences between the variants, I'm not sure however I'm seeing these in the HB kit parts. Mind, I do not have the kit in my hands so I can only check sprue pictures, but these and the instructions really look the same to me. If you have seen them then HB did their homework right
5 hours ago, Ray_W said:
@NAVY870
Hi Steve,
Ray
Ray
The Hobbyboss kit looks like a down scaled clone of the Trumpeter 1/32 kit.
Other than the retracted slats theres a couple of other pooches copied from its bigger sister
Main gear legs are way too long, makes it look like its had a parade boot up the jacksie.
Main wheels are all over the shop
Intakes are under nourished
Cockpit is sparse, rear bulkhead shape is well off
No bent IFR probe, Ours had the bent probe before the chequer board fin was applied
It has the rear under fuselage chaff dispenser only
Landing light on each MLG door, should be starboard only
UHF antennae is incorrect shape
No TER and the MK82 are underweight
No nose wheel steering, only the snubber of the A-4E
Its doable but needs help from other sources
  • Thanks 2
Unfortunately for us Douglas thoroughly muddied the waters by backdating the spoilers, nose wheel steering and other goodies to the A-4E.
The only real way to be sure is to check the Bu number
Thanks Steve, a very useful list.
