A Couple of Gals - Two Revell B-17Gs
CedB
Glad you have the PE sorted, Ced! :clap:
As for the overspray on red, I know what happened: we all have that urge to spray some color on our models, and sometimes that prevails over careful planning... :shrug: :D
Ciao
4 hours ago, AliGauld said:
Nice re-rolling there.
No you're only human. Stuff happens.
Alistair
Thanks Ali, very kind :)
Ciao
Exactly Giorgio :)
In my head was 'spray the grey and then mask for the Olive' - I'd forgotten about the red!
4 hours ago, perdu said:
Saying nothing...
No Bill, but I can hear what you're thinking from here! :D
2 hours ago, Tcoat said:
Big Bang Theory! One of my favourites. I recorded the complete series re-run on the Sky box and I'm gradually working my way through when I need a giggle.
Like soon, probably.
I remember I had trouble with the nacelle internals when I built Belle and I'd taken a warning from Andy Moore's build of the kit.
This made me nervous.
Not surprising given the instructions:
I'm going to 'practice' on my kit as the bays will be closed up.
Then I can get Jim's right.
Not a good start. Look at these:
Jim's kit on the left, mine on the right. I would call it flash if it wasn't so thick.
Similarly:
Good grief.
Eventually I lost patience and left it all here:
Probably best.
Now for some BBT.
There will be wine tonight!
  • Like 21
Looks like you deserved a bit of relax and a good laugh with BBT, Ced - incidentally, it's my favorite TV series too, I just re-watched series 1 to 11, waiting for 12 to appear on Prime Video :)
Ciao
Just to flesh out the drill bit as rolling tool. The drill bit shanks run up to 1/2” typically for home use. After that, improvise. I live on a farm with a shop, so I have hundreds of bits, a couple of which are actually sharp.... You can typically find cheap sets at your favourite hardware store. As you found, with the larger size, if it’s a tube, you can use it. Where the drill bit’s really shine is rolling things like Wingnut Wings machine gun tubes. You can play with the diameter and roll them to the point where it is a perfect tube with the mating parts just touching.
22 hours ago, CedB said:
Off the Amazon looking for large drill bits… then I realised that not only are they expensive but most have the same shaft size (the non-drilly bit) so they fit in drill chucks.
Ced Surely Robin is referring to sets like these* all different rolling diameters, I have hundreds of blunted ones of such sizes should I burden Bath's postal servants by boxing a few and popping them along?
I am not suggesting you buy a big steel box of engineering drills such as above but I do have several boxes of the tiny toolzone ones too.
Nudge and some of  them will be yours.
I have spent several enjoyable minutes studying the drawing for assembly, designed to allow your brain to warm up then cool down as the steam supercools
I am truly glad I was able to resist all blandishments to join in your crusade, truly...
  • Haha 2
19 hours ago, Cookenbacher said:
The fuselages look splendid Ced, overspray schmoverspray I always say (I'm sure you'll get it tidied up nicely).
Thanks Cookie - it will be tidied! :)
Ciao
Thanks Giorgio :)
Wine and films were had last night so well relaxed.
16 hours ago, The Spadgent said:
I keep looking at that. Then looking away. Then looking again. Then looking away. 🤪 enjoy the wine! 😇 looking good Mr B. The red looks the business.
Johnny. 🤩
Thanks Jont :)
The instructions were a task but done now - see below.
15 hours ago, hendie said:
Those instructions would look out of place in a Hieronymus Bosch painting.
I hope you find Patience soon Ced, she'll be getting lonely out there
Thanks hendie. Patience has been lost and found and lost again, but to after some progress :)
Ah thanks Robin, that's clear now :)
Awww thanks Bill, kind as always :)
I have enough drills though I think so no need to burden the postie.
Revell Instructions should be fun but why oh why do you need a Degree in Quantum Physics to understand them.
Good to see you can walk away when necessary.
Alistair
Thanks Ali - always best to take a rest :)
Says the prime culprit for the phrase "almost time for paint"!
Ian
  • Haha 4
Before we start on the wheel wells I painted my balls again:
I'd done them aluminium by mistake so now corrected.
Right, let's take on the instructions.
Andy's thread showed how part #103 fits in the side of the nacelle - so, without glue, I used that as a reference point:
That gave me the correct location for the rear bulkhead and the front too:
The tank fits into a single locating slot at the front and its bottom lines up with the top of that nacelle half:
With the confidence that gave me I did Jim's:
Note the correctly painted tank.
Everything's had a wash with Nulm Oil:
The next job was to put these in the ends of the intake/vents:
Strangely the parts on the two kits are moulded differently, one sticking up and the other flatter:
I think the sticking up ones are better moulded so I'll use those for Jim's.
Ian
:D
(Sorry Ian, crashed your post)
  • Like 16
All coming together in the nacelles now, Ced - great job! :clap:
Ian
Guilty as charged :winkgrin: :D
Ciao
  • Haha 3
Thanks Giorgio :)
"Time for paint" - again.
Overspray sorted:
Looks like I've missed a bit on the LE of the bottom one but it's a reflection - I've checked!
The intake parts are in:
Impossible to clamp (I tried) I used TET Quick and held each section in place until it dried - not long with that stuff.
Now I can glue the wings together!
Not.
The PE roof fouls on the tank and the rear bulkhead:
Hmmm. "Rats" hardly seems sufficient so just allow me to leave the room for a quick cuss…
That's better.
Hard to cut in-situ so it was ripped off, trimmed and dry-fitted to the lower bit:
… then glued with GG and clamped.
Again.
While waiting for the red and PE to dry I thought I'd check my ball turrets:
Oh look, the BluTak has reacted with the paint which has peeled off when I tried to remove it. :weep:
I'd better paint those then.
Again.
I think I'll have a look at the 1/144 Spits while it settles down.
  • Like 16
  • Sad 2
Again.
Quick Aqua Gloss coat (airbrushed) on them (and let it cure overnight) before you put more BluTak on. :)
Ciao
On 5/15/2021 at 12:46 PM, perdu said:
Saying nothing...
Me neivver, specially as it all happened so long ago in Ced thread terms that it's ancient history.....
Some great saves going on here Ced.  Kasper Schmeichel eat yer heart out....
'cept there's quite a body of work on Bosch-interpretation.    Ced's gotta sort it out hisself.....
  • Haha 6
I will admit I would have dropped a few phrases in the vicinity of "Oh that's unfortunate"  :rant: if I'd put all that work in to find it didn't fit.
Your restraint is remarkable.
Shame about your spherical objects but you will get them sorted I'm sure.
Alistair
  • Haha 2
seems like you've hit a few bumps, could be worse! One of my friends were varnishing their MiG-15 and the varnish reacted with the paint and all the paint peeled off! (Idk if varnish is the correct term, gloss maybe, the clear coat after paint before decals.)
Looking forward to seeing more updates.
Edited by KingTiger435
Ciao
Thanks Giorgio - you and your gloss coats! :)
Thanks Steve - it's certainly taxing my patience (what little I have!) :)
Alistair
Very restrained of you Ali :D
Yikes! Varnish taking paint off is probably the worse; after all that work :)
The wings still won't close.
Time for some serious surgery:
With those trimmed the wings were fitted.
Starting at the inner nacelle, everything needs wiggling until it fits properly. Glue and tape and on to the next bit.
Finally:
  • Like 19
These have certainly been fighting you all the way, but looks like your showing them who's boss!
Coming together nicely now
    Stay safe            Roger
