Small Carts Collection (35621) 1:35
Mike
1:35 MiniArt via Creative Models
MiniArt’s range of diorama accessories in 1:35 are legion, and it keeps getting more legion-y by the month.  This set contains a variety of wheeled carts, and arrives in a shrink-wrapped figure box with five sprues in grey styrene, one for each of the items shown on the box top.  The instructions on the back give a brief run-down of construction, and are accompanied by painting suggestions that relate to a table that gives small swatches, paint codes from Vallejo, Mr.Color, AK Real Color, Mission Models, AMMO, Tamiya, and the colour names in English.  As these are just guides, the world is your oyster, and if you want to paint your cart in different colours then no-one* is going to stop you.
* I do however advise you that someone is bound to be an expert on carts, so if they’re not well-adjusted socially and you’re unlucky enough to come across them, at least I warned you.
From the box you can build what I refer to as a sack truck, often seen on the railways in the 50s and earlier being pushed around by Porters, with two small wheels and a metal bracket to take the weight of the object.  A traditional open-sided wooden wheel-barrow with single wheel, wooden frame and load bed, plus another with a sloping, pressed steel load area are also included.  A four-wheeled wooden trolley with an open framework load area and long pull-handle is really the first true cart, and the last is another wooden cart with large carriage-style wheels and two legs to enable the user to keep the load-bed flat, and two handles for the barrow-man to lift and push/pull his load.  This one is typically used by street vendors to sell groceries, flowers and the like.
Conclusion
Detail is excellent throughout as we’ve come to expect from MiniArt, and moulding is crisp and clean, showing off the wooden texture where appropriate, plus the slight irregularity that is inherent with ageing wooden equipment and lends itself perfectly to some paint weathering and chipping, as shown on the box art.
Highly recommended.
Review sample courtesy of
