CliffB Posted March 27, 2021 Share Posted March 27, 2021 Hi all. Here's the replacement for my failed Safari Rally Ford Focus entry. It's something pretty simple, because I need to make up for lost time. This artwork caught my eye on Wings Palette. It shows what I believe to be one of the South African Airways Ju.52s that were impressed into service during WWII, to provide a ferry transport service between RSA and the North African battlefields. The paint scheme appears to be Dark Earth/Mid Stone over Azure Blue, but I'm not sure. Elsewhere, I've found this reference to a SAAF Ju.52 being Dark Green over Azure Blue. Mind you, this same source says that the SAAF Ju.52s were captured ex. Luftwaffe aircraft (which I don't think is correct, unless there were two fleets of aircraft). So I'm puzzled as to what scheme (or schemes), these aircraft carried. Can anyone help on this please? Likewise, were the markings 'standard RAF' (as the second source says), or would the red parts be orange? I shall be using this 1/200 scale Zvezda kit as the canvas. It should be a simple build, although the starboard side of the kit's fuselage features large cargo doors (which may not be appropriate), and I may also need to add some wheel spats Cheers 7 Link to comment Share on other sites More sharing options...
RidgeRunner Posted March 27, 2021 Share Posted March 27, 2021 A nice subject, Cliff. I know there is a good site on the net covering these machines but my old brain is not remembering at present. I’ll give it some thought .... Martin Link to comment Share on other sites More sharing options...
RidgeRunner Posted March 27, 2021 Share Posted March 27, 2021 This might help? There’s an inflight shot here http://saafww2pilots.yolasite.com/eric-johnson-photographs.php 1 Link to comment Share on other sites More sharing options...
JWM Posted March 27, 2021 Share Posted March 27, 2021 There were different engines (cowlings) variants of Ju 52 in SAAF, both imposed from civil pre-war use. Here is with 3 blades props and NACA cowlings https://www.alamy.com/stock-photo-junkers-ju-52-of-south-african-air-force-89534303.html But some had more regular look http://www.dws-xip.pl/encyklopedia/wp-content/uploads/2014/02/Ju52_1.jpg The other story are he captured one, like that one named "Libyan clipper": Here one will not need any conversion of plastic parts (what can be treated as pros or cons as well, depending what you like ) Regards J-W 6 Link to comment Share on other sites More sharing options...
JOCKNEY Posted March 27, 2021 Share Posted March 27, 2021 Great stuff Cliff Although at 1/200 I'm envious of your eyesight ! Best of luck Cheers Pat 1 Link to comment Share on other sites More sharing options...
CliffB Posted March 27, 2021 Author Share Posted March 27, 2021 Thank you @RidgeRunner and @JWM. The resources you've provided, or directed me to, have been a great help. As a result, I'm currently heading towards "26" a dark green aircraft which is twice described as being a captured machine. Only artwork to go on at the moment, but who knows, a photograph may yet turn up! Cheers Link to comment Share on other sites More sharing options...
CliffB Posted March 27, 2021 Author Share Posted March 27, 2021 1 hour ago, JOCKNEY said: Great stuff Cliff Although at 1/200 I'm envious of your eyesight ! Best of luck Cheers Pat Thanks Pat. Luckily I have a magnifying glass (so that I can more clearly see my hands shaking ). Cheers 3 Link to comment Share on other sites More sharing options...
PeterB Posted March 27, 2021 Share Posted March 27, 2021 Hi Cliff, In my ignorance I did not realise that the SAAF flew these planes - I knew they had a few Ju86 and had ordered a version of the Ju 90 with P&W engines, but never received them. Pete 1 Link to comment Share on other sites More sharing options...
JWM Posted March 27, 2021 Share Posted March 27, 2021 (edited) BTW - the Xtradecals produces decals in 1/72 (not in 1/200) for "Libyan Clipper", a captured Ju52, however with mistake. They suggest A roundels on fuselage But on this take (obviously on orthochromatic film) they are A1. It is clear, that yellow ring exists. Moreover, the inscription "Libyan Clipper: seems to be a bit darker then white (light blue? sky? some grey?). The next observation is that bottom side was not repainted and is left in RLM colors with white wingtips and only overpainted Luftwaffe code letters and crosses. For "26" (still in 1/72) decals exists http://decals.kitreview.com/decals/k716previewbg_1.htm Best regards J-W Edited March 27, 2021 by JWM 3 Link to comment Share on other sites More sharing options...
CliffB Posted March 28, 2021 Author Share Posted March 28, 2021 21 hours ago, PeterB said: Hi Cliff, In my ignorance I did not realise that the SAAF flew these planes - I knew they had a few Ju86 and had ordered a version of the Ju 90 with P&W engines, but never received them. Pete and I didn't know about the Ju.90 order Pete! That would have been impressive had it come to pass. 20 hours ago, JWM said: BTW - the Xtradecals produces decals in 1/72 (not in 1/200) for "Libyan Clipper", a captured Ju52 Thanks J-W. I'm starting to think that 'Libyan Clipper' has been built before on BritModeller - but I may be wrong. I got a few hours on my Ju-52 yesterday and made some good progress. There are 11 parts in this so far and they fit together pretty well. The kit's advertised as being 'snap fit', but fortunately it's not. The parts only hold themselves together because they are a tight fit, which means that you can take easily take them apart again for fettling. Mine's now glued together though. Having previously built a couple of 1/72 Ju.52s, I'm really appreciating the fact that the elevators etc. are moulded integral to wings. If you've ever built a Ju.52, you'll probably understand what I mean! Finally, I should mention that I'll be painting over the transparency. My personal preference in 1/200, is to paint the windows black. Either way, the framework on this one is going to be tricky . Cheers 7 Link to comment Share on other sites More sharing options...
CliffB Posted March 29, 2021 Author Share Posted March 29, 2021 A quick update, as the main colours are now on. Dark Green over Azure Blue (please ignore the colour balance in the photo!). Cheers 2 Link to comment Share on other sites More sharing options...
CliffB Posted April 1, 2021 Author Share Posted April 1, 2021 Another update folks. Detailed painting done (although the photo is showing that I may need to revisit the top of the canopy ), and u/c fitted. Cheers 5 Link to comment Share on other sites More sharing options...
RidgeRunner Posted April 1, 2021 Share Posted April 1, 2021 Wow! That was quick! 1 Link to comment Share on other sites More sharing options...
Grandboof Posted April 2, 2021 Share Posted April 2, 2021 Looking good Cliff Martin H 1 Link to comment Share on other sites More sharing options...
Col. Posted April 3, 2021 Share Posted April 3, 2021 An interesting subject choice Cliff and quick progress. Sure you'll have time for another at this rate 1 Link to comment Share on other sites More sharing options...
CliffB Posted April 4, 2021 Author Share Posted April 4, 2021 Thanks @RidgeRunner @Grandboof and @Col. Well, it's finished now and I'm reasonably pleased with it. Unfortunately though, the orange centres of my homemade roundels do look remarkably red! I'd love to do another African build, but I must stick to a strict timetable if I'm going to support all the GBs this year. I'm broadly on course at the moment . Thanks to all of you that have supported this build and to the hosts for making it happen. Cheers 4 Link to comment Share on other sites More sharing options...
Grandboof Posted April 4, 2021 Share Posted April 4, 2021 Very tidy indeed Cliff Martin H 1 Link to comment Share on other sites More sharing options...
