67th Fsq P-400 interior color question
Greetings
I'm about to start construction on an early P-400 that flew from New Caledonia to Henderson Field on Guadalcanal. I had read something years ago by Dana Bell regarding U.S. substitute colors used by various manufacturers. The Bell interior green for the P-39 was supposedly not the typical zinc chromate /apple green but a color akin to medium green which was used to break up the silhouette of aircraft like te P-40 and B-17 early in the war. My question is did Bell use equivalent/substitute MAP designated colors?  Did Bell try to match the MAP interior green or did they not worry about it? I'm sure there is a link somewhere regading this topic. I have read what I can find but no answer to my exact query. Any help would be appreciated.
I don't have an exact answer for you, but I recall Eduard included some fairly detailed cockpit colour information in the instructions for the P-39 kit released in the early 2000's.
Pretty sure it wasn't a MAP "match" but an in-house Bell preference from a local-ish paint supplier.  IIRC, closer to Dull Dark Green or Medium Green and not much like Interior Green or British cockpit grey-green.
Unfortunately my addled recollections do not a proper reference make, hopefully a more authoritative answer is forthcoming.
What Jackson said is accurate; Bell used a local paint supplier for its interior paint, just like Curtiss did, using paint from Berry Brothers for their "Curtiss green." I have an FS equivalent for the Bell interior/cockpit green somewhere, and I can look for it; this paint was also used on the landing gear struts of P-39's and P-63's.  The standard for interior green, which was FS 34151, was used by paint suppliers, but was not set in stone; a lot of variation was allowed by the inspectors- thus Bell and Curtiss interior greens were allowed and were not the same color. Bell interior green is a little lighter and has a blue tint when compared to the standard FS 34151. I have seen FS 34172 given as a good match for Bell and FS 34248 as a good match for Curtiss interior green.
Mike
That being said, here is a link to photos of a P-39Q in unrestored condition in Finland; I think it is the composite of three airframes that @Antti_Kmentioned in another discussion. Note the photo of the main wheel bay and landing gear- you can see the untinted zinc chromate primer and the Bell green used on the struts and inner surfaces of the fairing doors, which looks a lot darker than other period photos I have seen- just goes to show...
Mike
https://lend-lease.net/gallery-en/p-39q-airacobra-from-tikkakoski-museum-finland/
Hello guys,
Some colour information based on my observations on the example here in Finland (that Mike just mentioned).
Using the Swedish NCS (Natural Colour System) colour fan I got the following codes and closest FS equivalents:
- Olive Drab: S7005-G80Y close to FS 36134
- Neutral Grey: S5503-B close to FS 36270, which is "one step" too light
- "Bell Green": S7020-G70Y close to FS 34097 (landing gear and doors, cockpit)
And some photos:
Bell Green visible on the struts and ZCY in the main gear bay:
Nose landing gear; again Bell Green:
Same dark green colour was used on cockpit interiors.
Antti
  • Thanks 2
In the link in this link, there are images of a recovered EX RAF Airacobra sent to Russia
file.php?id=1313&mode=view
Seems they did not use a MAP equivalent .
