bootneck Posted May 23, 2021 Author Share Posted May 23, 2021 Hello all, I am still plodding on with the diorama and much of my time has been spent struggling between the design of the pub and the placing of the tracks. I have been told about a track laying program, called Templot, which helps me to position the tracks correctly and I am currently learning about this. I have also worked on dimensioning the pub, by using photo interpretation means, and think I have enough detail to start constructing it. Here is the layout, with some Templot templates pasted into position; plus, the start of the pub construction can be seen in the top left corner. Like most of the layout, the pub is being made from balsa wood, a material I probably last used about 1958! cheers, Mike 8 Link to comment Share on other sites More sharing options...
Mjwomack Posted May 23, 2021 Share Posted May 23, 2021 6 hours ago, bootneck said: much of my time has been spent struggling between the design of the pub There's a joke to be made about organising things in a pub, but even I'm not that low! I'm loving this, it just oozes cramped cityscape, especially with the cutting walls all around it's going to be wonderfully claustrophobic (I think that's a thing) 3 Link to comment Share on other sites More sharing options...
bootneck Posted June 2, 2021 Author Share Posted June 2, 2021 I have spent the last week measuring, cutting and laying a few hundred individual sleepers and now I am making up the rails. The pub is also progressing but it is a complex design and will need more research. cheers, Mike 9 Link to comment Share on other sites More sharing options...
Paul821 Posted June 2, 2021 Share Posted June 2, 2021 Good to see that this build is progressing and has not been derailed or shunted into a siding. After attaching 80 or so wooden beams to the Bull Inn I am in awe of anyone with the patience, nimbleness and ability to lay that many sleepers. Looking forward to more progress on this build. 1 Link to comment Share on other sites More sharing options...
bootneck Posted June 2, 2021 Author Share Posted June 2, 2021 Thanks Paul, here is a closer view of the track laying in progress. I have turned the pub model around to show the work done so far. There's still lots (and lots) more to do, so I had better get a move on. cheers, Mike 6 Link to comment Share on other sites More sharing options...
Pete in Lincs Posted June 2, 2021 Share Posted June 2, 2021 That looks very impressive, Mike. I admire your patience. Pub research? from the inside? Thirsty work 😃 1 Link to comment Share on other sites More sharing options...
bootneck Posted June 6, 2021 Author Share Posted June 6, 2021 This weekend I have been concentrating on some of the other buildings that are situated within the railway setting. This is the larger of two water towers that were to be found on the site. I am using bits from a card model to make up the tower. I have only been able to find one image that shows the construction of the building and am basing my model on that. The water tank itself, which sits on top of the building, has not been made yet; however, I couldn't resist a test fit on the layout. This view is from the opposite direction of the normal views that I have shown so far more to follow, hopefully soon. cheers, Mike 10 Link to comment Share on other sites More sharing options...
Pete in Lincs Posted June 11, 2021 Share Posted June 11, 2021 Mike, I found this and thought of your build. Montreal, 1893 2 1 Link to comment Share on other sites More sharing options...
bootneck Posted June 12, 2021 Author Share Posted June 12, 2021 No thanks Pete, mine is complicated enough! I have been working on adding more track, plus I have started on a scratchbuild of the signal box. There doesn't appear to be much progress on the layout since my last update; however, I have managed to lay down more track and turnouts. I give the completed a section a coat of primer, mainly to show how much has been done; or, conversely, how much still needs to be done! The trackwork is quite complicated for me, especially as I knew nothing about it before I started this build for the GB. I did invest in this book, which covers virtually all aspects of track laying, turnouts/points and crossovers etc., and I am using it as my guide through this build. Here is a closer view of the trackwork so far. I need to get all this trackwork completed just so that I can move 'upstairs' and get on with the roadways and buildings etc. cheers, Mike 5 Link to comment Share on other sites More sharing options...
PeterB Posted June 12, 2021 Share Posted June 12, 2021 The signal box on the cover of your book looks rather familiar - any idea where it is, assuming it is not a model itself? Pete Link to comment Share on other sites More sharing options...
bootneck Posted June 12, 2021 Author Share Posted June 12, 2021 The description says "the triangular junction on the Southern approach to Shrewsbury station. The third side of the triangle is just visible behind the signal box". Mike 1 Link to comment Share on other sites More sharing options...
PeterB Posted June 12, 2021 Share Posted June 12, 2021 (edited) Thanks Mike, We made a family visit to see relatives in Chester a couple of years back, taking the train from Cardiff and went past that box - I just could not remember where! The line splits and goes off to the right towards Wellington and Telford I believe, while the left side goes into Shrewsbury and on towards Liverpool and Chester. Usually these were just triangular junctions between a number of lines, but they could also be used for turning locos and even complete trains - I believe in the states they call them "Wyes" and used them quite a bit for that purpose - possibly because they had a lot of single track working with limited infrastructure on some of their rural lines. Pete Edited June 16, 2021 by PeterB Link to comment Share on other sites More sharing options...
AdrianMF Posted June 27, 2021 Share Posted June 27, 2021 Smashing work Mike! The Multilevel-ness is starting to look really spectacular. Regards, Adrian 2 Link to comment Share on other sites More sharing options...
Pete in Lincs Posted June 27, 2021 Share Posted June 27, 2021 On 6/12/2021 at 2:35 PM, PeterB said: The signal box on the cover of your book looks rather familiar There was a TV series called something like 'the Railways that built Britain' on one of the Sky channels. I think that box was featured in it. Your scratchbuilt signal box is looking good, Mike, as is the trackwork. 3 Link to comment Share on other sites More sharing options...
Paul821 Posted June 27, 2021 Share Posted June 27, 2021 This link is a recent Network Rail video of the signal box. Hope these distractions are not stopping Mike @bootneck working on his excellent diorama/layout 2 1 Link to comment Share on other sites More sharing options...
bootneck Posted June 28, 2021 Author Share Posted June 28, 2021 Hussah!! I have finally completed the trackwork. Outline of the signal box in position. overhead view. All I need to do, in the next 11 days is: - complete the tunnels and bridges - cut out the remaining inspection pits around the turntable - rebuild and enhance the retaining wall - construct the second water tower and linesman's huts etc. - complete the signal box - construct various signal gantries and water pump stations - add parapets on top of retaining walls - complete the Golden Eagle pub model - build the roads and pavements - paint and weather all areas. cheers, Mike 7 Link to comment Share on other sites More sharing options...
Pete in Lincs Posted June 29, 2021 Share Posted June 29, 2021 You won't get much sleep then? Good luck! Link to comment Share on other sites More sharing options...
Paul821 Posted June 29, 2021 Share Posted June 29, 2021 5 minutes ago, Pete in Lincs said: You won't get much sleep then? Good luck! Or watch football, tennis, cricket.... Keep going - you can do it. 1 Link to comment Share on other sites More sharing options...
Mjwomack Posted June 29, 2021 Share Posted June 29, 2021 There's also a lovely little 3D printing project in a lay-by hoping for some attention- nudge nudge; can't believe I'm championing a road vehicle over rail- strange times! Link to comment Share on other sites More sharing options...
Jinxman Posted June 29, 2021 Share Posted June 29, 2021 Lovely stuff - I was at New St on Saturday - it's a little bit less grubby than it was back then, (not much though!) 1 Link to comment Share on other sites More sharing options...
bootneck Posted July 5, 2021 Author Share Posted July 5, 2021 Six days to go, I had better get the signal box finished so that I can get on with all the upper levels work! Mike 4 Link to comment Share on other sites More sharing options...
Paul821 Posted July 5, 2021 Share Posted July 5, 2021 Think of the time remaining as 151 hours (as I write) that's plenty of time to get this one finished. Just keep up the good work and don't get distracted - I am just using glue drying time to catch up with events in the GB, Link to comment Share on other sites More sharing options...
bootneck Posted July 11, 2021 Author Share Posted July 11, 2021 I'm afraid that I am going to admit defeat with this build, there is just too much still to do with it. More work has been done on the pub/hotel, signal box and roadway and it is starting to take shape but work at the back was just a bridge too far. This is the view that I wanted to emulate, it is looking west. but this is all I have been able to manage. Another view, looking south, would also have been nice to complete again, just too much additional detail is required. I shall take a break then resurrect this build and finish it in the Scratchbuilding forum. cheers, Mike 6 1 Link to comment Share on other sites More sharing options...
Mjwomack Posted July 11, 2021 Share Posted July 11, 2021 I hope I'll her able to find it! There's so much in it as a whole diorama. Link to comment Share on other sites More sharing options...
Paul821 Posted July 12, 2021 Share Posted July 12, 2021 On 7/11/2021 at 1:37 PM, bootneck said: I shall take a break then resurrect this build and finish it in the Scratchbuilding forum. I do not want to loose track of this build to my mind the most ambitious of all the builds in the GB, even beating some of the flying oddities we have had and a card university. Could you please at least start a thread somewhere that we could follow so we are informed when you end your well earned break? 2 Link to comment Share on other sites More sharing options...
