1/48 - Fairchild Republic A-10C Thunderbolt II by Academy - released
Homebee
4 hours ago, salomon said:
Sorry I dorget there's a factory called "Must Have", so it was confusing. I wanna say that Academy's A-10 is my much have kit of 2022.
I understood, I just couldn't miss that one because you wrote it as a proper noun.
  • Homebee changed the title to 1/48 - Fairchild Republic A-10C Thunderbolt II by Academy - 3D renders - release in 2022
Source: https://www.facebook.com/gustav.jung.7/posts/4926637554097420
Quote
Googled:
Forthcoming item - Academy 1/48 A-10C Thunderbolt II
There is a little bit of a good taste in the finish, but I think it can give the fans of Hyunyonggi a bit of satisfaction. I expect to see this this fall.
277368134-4926632387431270-9195817943160
V.P.
Edited by Homebee
  • Homebee changed the title to 1/48 - Fairchild Republic A-10C Thunderbolt II by Academy - 3D renders - release fall 2022
7 hours ago, Christer A said:
The multicolored parts sort of hints at a A-10A at some point, doesn't it?
All you would need is a new "old" instrument panel. A pave penny pylon and your good. all the rest of the antennas were either carried by later "A's" or they can be removed (ALE-47 sensors)
On 3/24/2021 at 11:27 PM, haneto said:
It will be most likely Academy(of course GWH will also release theirs).
Kinetic new item will be an Italian jet aircraft.
Do you know something we don’t know about GWH? 😀
Yes, GWH design is under good progress.
There will be A, A+ and C variants.
I have seen the CAD and they are quite promising with new level of surface detail and accuracy.
  • 1 month later...
This is real? Whooo-hoooooo!
On 29/03/2022 at 10:18, paulsbrown said:
Lets hope they also concentrate on the raised and flush rivets
Hope so as the back end is covered in raised ones
  • 1 month later...
  • Homebee changed the title to 1/48 - Fairchild Republic A-10C Thunderbolt II by Academy - 3D renders+box art - release fall 2022
3 hours ago, Mycapt65 said:
I thought that thing hanging down off the starboard fuselage under the cockpit was the pave penny pod that wasn't used on A-10Cs?
It is and it was used on the A-10C, though I don't know if it is anymore.
Here's a couple of C's with the Pavy Penny fitted.
Here's a C with it and the mount removed.
ed07x6qtqi531.jpg?auto=webp&s=d0299e92f7
The pave penny (AN/AAS-35V) was used pretty extensively in the 80's and 90's but it was phased out once the LITENING and Sniper targeting pods came online. Even though the Pave Penny was phased out, the pylon stayed attached to the jet until the early 2010's at which point it started getting removed altogether, leaving behind the 4 bolts just aft of the nose gear door on the foreword fuselage. So it's possible to have seen an early A-10C fitted with the Pave Penny, but it was probably inoperative at that point. If you're going to build a pre-2010 aircraft you could get away with including it in your build, but if it's a post-2010 Hawg you may want to consider deleting it.
Edited by FinalApproachPhotography
  • 1 month later...
35 minutes ago, Sarawakia said:
I thought Hobbyboss will be releasing one later this year. Saw in on Scalemates.
Forget Scalemates and read Britmodeller Rumourmonger! 😉
Hobbyboss has just re-released its original A-10 kit as a A-10C. Thread is here:
https://www.britmodeller.com/forums/index.php?/topic/235109690-148-fairchild-republic-a-10c-thunderbolt-ii-by-hobbyboss-released/
V.P.
  • 1 month later...
  • 1 month later...
  • Homebee changed the title to 1/48 - Fairchild Republic A-10C Thunderbolt II by Academy - 3D renders+box art - release Q4/2022
Anyone know the story behind the red circle with the Raptor and Viper kills?
Not 100% sure but remember reading it was from Red Flag ? The pilot was able to get into a twisting mock dogfight in two different occasions. Supposedly beat them both to a guns use solution. Here you go.
https://theaviationgeekclub.com/unique-photo-shows-usaf-a-10-with-f-22-and-f-16-kill-marks/amp/
  • Homebee changed the title to 1/48 - Fairchild Republic A-10C Thunderbolt II by Academy - released
